    c4dpy not working on Windows 10
    13 Posts 2 Posters 4.5k Views 2 Watching
    • mikeudinM Offline
      mikeudin
      Hello guys!
      I have Cinema 4D R20.059 installed and c4dpy.exe updated to latest R20 release.
      A some time ago everything was fine but now c4dpy.exe seems to not working with any command. 🤔
      With R21 it works:
      https://mikeudin.net
        c4dpy is version-specific. Since in Release R20 it was not part of the bundle you should download it from [URL-REMOVED] with the matching R20 version you have.
        • mikeudinM Offline
          mikeudin
          Sure! I know it perfectly. But in case wrong version Cinema4D.exe c4dpy outputs error messages, but i have nothing.
            What's your specific version of Windows 10?
            Can you try to clean the Cinema 4D preference folder.
            Did you already licensed the 20 cinema 4D application? If not could you try to launch Cinema 4D first license it then relaunch c4dpy.
            If it does nothing can you launch c4dpy with the g_console=true parameter and copy the output data.
            • mikeudinM Offline
              mikeudin
              Hm, after removing folder c:\Program Files\MAXON\Cinema 4D R20\plugins\Redshift
              c4dpy works!🤔
                Thanks for the info can you try to launch c4dpy with redshift and with c4dpy g_disableConsoleOutput=false and paste the content.
                Does the CommandLine works with the redshift plugin?
                Thanks in advance.
                mikeudinM 2 Replies Last reply Reply Quote 0
                • mikeudinM Offline
                  mikeudin @m_adam
                  @m_adam
                  Sure! Take it in attachement.
                  c4dpy_output_log.txt
                  • mikeudinM Offline
                    mikeudin @m_adam
                    @m_adam
                    Did you mean c:\Program Files\MAXON\Cinema 4D R20\Commandline.exe?
                      Hi, could you run g_disableConsoleOutput=false With Redshift installed so this way c4dpy does not launch correctly.
                      @mikeudin said in c4dpy not working on Windows 10:
                      Yes
                      mikeudinM 1 Reply Last reply Reply Quote 0
                      • mikeudinM Offline
                        mikeudin @m_adam
                        @m_adam Ok, done. With Redshift installed:
                        CommandLine.exe log:
                        commandline_output_log.txt
                          Which version of Redshift are you using?
                          • mikeudinM Offline
                            mikeudin @m_adam
                            @m_adam v2.6.41
                            • mikeudinM Offline
                              mikeudin @m_adam
                              @m_adam After installing v2.6.48 c4dpy works fine.
                              C:\Users\mikeu>"c:\Program Files\MAXON\Cinema 4D R20\c4dpy.exe" g_disableConsoleOutput=false
                              Application start      : 12/04/19 at 11:53:39
                              Executable             : 64 Bit
                              Version / Build        : 20.059 / RB272827
                              Debugger               : not available
                              Memory model           : release
                              Startup path           : file:///c:/Program Files/MAXON/Cinema 4D R20
                              Application path       : file:///c:/Program Files/MAXON/Cinema 4D R20/c4dpy.exe
                              Application executable : file:///c:/Program Files/MAXON/Cinema 4D R20/c4dpy.exe
                              Resource path          : file:///c:/Program Files/MAXON/Cinema 4D R20/resource
                              Module path(s)         : file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs; file:///c:/Program Files/MAXON/Cinema 4D R20/plugins; file:///C:/Users/mikeu/AppData/Roaming/MAXON/Cinema 4D R20_4FA5020E/plugins; file:///D:/Dropbox/Developer/Plugins/SendPythonCode; file:///D:/Dropbox/Developer/TestingProjects/File Sequence Exporter; file:///D:/Dropbox/Developer/Plugins/Target4D/Dev/1.5
                              Temporary path         : file:///C:/Users/mikeu/AppData/Local/Temp
                              Prefs path             : file:///C:/Users/mikeu/AppData/Roaming/MAXON/Cinema 4D R20_4FA5020E
                              Global Prefs path      : file:///C:/Users/mikeu/AppData/Roaming/MAXON
                              OS version             : Windows 10, 64 Bit, Professional Edition (build 18362)
                              OS languages           : {ru-RU,en-US}
                              App languages          : {en-US,ru-RU}
                              Startup language       : en-US
                              Processor              : 4(8)x Intel Core i7-4770 CPU
                              Computer name          : DESKTOP-60OMRSJ
                              Thread Count           : 8
                              Cpu Speed (MHz)        : 3400.000
                              Application Type       : Modular
                              Command line arguments : "g_disableConsoleOutput=false"
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/asset.module.xdl64 with module(s) net.maxon.asset
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/c4dplugin.xdl64 with module(s) net.maxon.c4dplugin net.maxon.c4d.c4dplugin
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/command.module.xdl64 with module(s) net.maxon.command
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/corenodes.module.xdl64 with module(s) net.maxon.corenodes
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/crashhandler.module.xdl64 with module(s) net.maxon.crashhandler
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/crypt.module.xdl64 with module(s) net.maxon.crypt
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/drawport.module.xdl64 with module(s) net.maxon.drawport
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/drawport_functioncache.module.xdl64 with module(s) net.maxon.drawport_functioncache
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/drawport_general.module.xdl64 with module(s) net.maxon.drawport_general
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/drawport_opengl.module.xdl64 with module(s) net.maxon.drawport_opengl
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/drawport_selector.module.xdl64 with module(s) net.maxon.drawport_selector
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/embree.module.xdl64 with module(s) net.maxon.embree
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/geom.module.xdl64 with module(s) net.maxon.geom
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/glclvk_trace.module.xdl64 with module(s) net.maxon.glclvk_trace
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/gui.module.xdl64 with module(s) net.maxon.gui
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/image.module.xdl64 with module(s) net.maxon.image
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/image_openexr.module.xdl64 with module(s) net.maxon.image_openexr
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/image_winmf.module.xdl64 with module(s) net.maxon.image_winmf
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/math.module.xdl64 with module(s) net.maxon.math
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/mesh.module.xdl64 with module(s) net.maxon.mesh
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/misc.module.xdl64 with module(s) net.maxon.misc
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/mvp.module.xdl64 with module(s) net.maxon.mvp
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/network.module.xdl64 with module(s) net.maxon.network
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/nodes.module.xdl64 with module(s) net.maxon.nodes
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/nodes_corenodes.module.xdl64 with module(s) net.maxon.nodes_corenodes
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/opencl.module.xdl64 with module(s) net.maxon.opencl
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/opensubdiv.module.xdl64 with module(s) net.maxon.opensubdiv
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/pythonconfig.module.xdl64 with module(s) net.maxon.pythonconfig
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/pythonvm.module.xdl64 with module(s) net.maxon.pythonvm
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/reflection.module.xdl64 with module(s) net.maxon.reflection
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/render.module.xdl64 with module(s) net.maxon.render
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/shaderbase.module.xdl64 with module(s) net.maxon.shaderbase
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/shadernodes.module.xdl64 with module(s) net.maxon.shadernodes
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/tessellation.module.xdl64 with module(s) net.maxon.tessellation
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/cadexchangeconfig.xdl64 with module(s) net.maxon.c4d.cadexchangeconfig
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/houdiniconfig.xdl64 with module(s) net.maxon.c4d.houdiniconfig
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/addons.xdl64 with module(s) net.maxon.c4d.addons
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/advanced render.xdl64 with module(s) net.maxon.c4d.advancedrender
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/alembic.xdl64 with module(s) net.maxon.c4d.alembic
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/archigrass.xdl64 with module(s) net.maxon.c4d.archigrass
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/bitmapfilter.xdl64 with module(s) net.maxon.c4d.bitmapfilter
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/bpexchange.xdl64 with module(s) net.maxon.c4d.bpexchange
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/browser.xdl64 with module(s) net.maxon.c4d.browser
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/ca.xdl64 with module(s) net.maxon.c4d.ca
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/ca2.xdl64 with module(s) net.maxon.c4d.ca2
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/cadexchange.xdl64 with module(s) net.maxon.c4d.cadexchange
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/clothilde.xdl64 with module(s) net.maxon.c4d.clothilde
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/collada14.xdl64 with module(s) net.maxon.c4d.collada14
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/collada15.xdl64 with module(s) net.maxon.c4d.collada15
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/colorchoosergui.xdl64 with module(s) net.maxon.c4d.colorchoosergui
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/compositing.xdl64 with module(s) net.maxon.c4d.compositing
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/dwg.xdl64 with module(s) net.maxon.c4d.dwg
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/dwgobjects.xdl64 with module(s) net.maxon.c4d.dwgobjects
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/dynamics.xdl64 with module(s) net.maxon.c4d.dynamics
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/exchanges.xdl64 with module(s) net.maxon.c4d.exchanges
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/expressiontag.xdl64 with module(s) net.maxon.c4d.expressiontag
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/fbx.xdl64 with module(s) net.maxon.c4d.fbx
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/gpurenderer.xdl64 with module(s) net.maxon.c4d.gpurenderer
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/hair.xdl64 with module(s) net.maxon.c4d.hair
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/i_skp.xdl64 with module(s) net.maxon.c4d.i_skp
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/iges.xdl64 with module(s) net.maxon.c4d.iges
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/io_obj.xdl64 with module(s) net.maxon.c4d.io_obj
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/licenseserver.xdl64 with module(s) net.maxon.c4d.licenseserver
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/metrics.xdl64 with module(s) net.maxon.c4d.metrics
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/mkmodeler.xdl64 with module(s) net.maxon.c4d.mkmodeler
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/mocca.xdl64 with module(s) net.maxon.c4d.mocca
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/model.xdl64 with module(s) net.maxon.c4d.model
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/mograph.xdl64 with module(s) net.maxon.c4d.mograph
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/motioncam.xdl64 with module(s) net.maxon.c4d.motioncam
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/motiontracker.xdl64 with module(s) net.maxon.c4d.motiontracker
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/nbp.xdl64 with module(s) net.maxon.c4d.nbp
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/newman.xdl64 with module(s) net.maxon.c4d.newman
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/nodeeditor.xdl64 with module(s) net.maxon.c4d.nodeeditor
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/objects.xdl64 with module(s) net.maxon.c4d.objects
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/onlinehelp.xdl64 with module(s) net.maxon.c4d.onlinehelp
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/onlineupdater.xdl64 with module(s) net.maxon.c4d.onlineupdater
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/python.xdl64 with module(s) net.maxon.c4d.python
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/plugins/Redshift/redshift4c4d.xdl64 with module(s) com.redshift3d.redshift4c4d
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/relaxuv.xdl64 with module(s) net.maxon.c4d.relaxuv
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/sculpt.xdl64 with module(s) net.maxon.c4d.sculpt
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/sculptbrushes.xdl64 with module(s) net.maxon.c4d.sculptbrushes
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/shader.xdl64 with module(s) net.maxon.c4d.shader
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/sketch.xdl64 with module(s) net.maxon.c4d.sketch
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/sky.xdl64 with module(s) net.maxon.c4d.sky
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/sla.xdl64 with module(s) net.maxon.c4d.sla
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/spacemouse.xdl64 with module(s) net.maxon.c4d.spacemouse
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/substance.xdl64 with module(s) net.maxon.c4d.substance
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/teamrender.xdl64 with module(s) net.maxon.c4d.teamrender
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/texturemanager.xdl64 with module(s) net.maxon.c4d.texturemanager
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/thinking particles.xdl64 with module(s) net.maxon.c4d.thinkingparticles
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/tpoperators.xdl64 with module(s) net.maxon.c4d.tpoperators
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/volumes.xdl64 with module(s) net.maxon.c4d.volumes
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/walkthrough.xdl64 with module(s) net.maxon.c4d.walkthrough
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/xpressocore.xdl64 with module(s) net.maxon.c4d.xpressocore
                              Loading file:///c:/Program Files/MAXON/Cinema 4D R20/corelibs/xtensions.xdl64 with module(s) net.maxon.c4d.xtensions
                              >Loaded... QCmds 0.22 by Johannes Kollender (http://www.kollender.com)
                              Binding Remote Code Executor Server to localhost:2900 ...
                              File Sequence Exporter 1.1 initialized.
                              Target4D 1.5.0 initialized successfully
                              0@0<5B@
                              Welcome to the world of C4D and Python 2.7.14 (default, May  3 2018, 18:05:57) [MSC v.1500 64 bit (AMD64)] (c) 2019
