    Bake Texture within ObjectData
    13 Posts 3 Posters 2.2k Views 3 Watching
      you have to either use a temporary document:
      cache = op.GetCache()
      if not cache:
      cache = cache.GetDown().GetClone() if cache.GetDown() else None
      if not cache:
      temp_doc = c4d.BaseDocument()
      temp_doc.InsertObject(cache)
      bake_init = c4d.utils.InitBakeTexture(*my_setup)
      print bake_init
      bake_status = c4d.utils.BakeTexture(temp_doc, my_data, my_bitmap,
                                          my_thread, my_callback)
      print bake_status
      temp_doc.Flush() # You need to free the document or it will remain in memory
      or tell c4d that the document has been updated before you bake it. I would go for a temporary document.
      I am also not sure what you mean by "I do not know how to bake a parametric object". Just pass the node you did execute GetCache() on, op in this case. However, I cannot stress this enough, my knowledge of Cinema's app functionalities is not the best anymore. I DO NOT KNOW FOR SURE IF THIS IS SUPPORTED. So you should consult the docs on that.
      zipit
      mfersaouiM 1 Reply Last reply Reply Quote 2
      • mfersaouiM Offline
        mfersaoui @ferdinand
        @zipit said in Bake Texture within ObjectData:
        If I go for a temporary document, I must to copy all objects of the current doc (scene) to the temp doc. In my situation I want to bake only the reflection channel of my texture, if there only the cloned object "op.GetCache().GetDown().GetClone()", there no thing to reflecte on my texture reflection.
        # Bake only reflection
        bakeData[c4d.BAKE_TEX_REFLECTION] = True
        For that reason I get a black image in the bake texture result.
        Regards,
        Mustapha
          I do not really understand what you question is. You can copy a document with c4d.C4DAtom.GetClone(), BaseDocument is derived from C4DAtom.
          zipit
            Hi @mfersaoui, may I ask you in which context are you?
            And do you try to bake the things?
            Because if it's a button into an ObjectData, the message since it's sent from the GUI, is sent from the MainThread.
            mfersaouiM 1 Reply Last reply Reply Quote 0
              mfersaoui @m_adam
              Hi @m_adam,
              I have a first button on my ObjectData that call my Bake Texture CommandData plugin (I'm using this example: py-texture_baker_r18.), and then from the CommandData GUI I run the bake texture process to bake the reflection channel of the sphere object texture.
                I am still confused on what you actual question is. When you want to render out the reflection channel, then you obviously have to copy the geometry too. You can copy the whole document as described above.
                However, like @m_adam pointed out, when your code happens in NodeData.Message() you are in the main thread, so you could use an event to just update your document after you have inserted your cache.
                # Snippet from your code above
                doc.InsertObject(obj)
                zipit
                  I guess his issue is that all his stuff is under a virtual document.
                  But since you react to a button click you are in the main thread.
                  So you can retrieve a copy of the cache of your current generator, (Don't forget to call StopAllThread) insert it into the current document, run the baking process, delete everything, that's it 🙂
                    mfersaoui @m_adam
                    @m_adam
                    Yes, it's the method that I'm using, but I don't know if this allowed or no. I explain it above in my second message.
                    And response to @zipit about "I do not know how to bake a parametric object" I mean: I do not know how to bake texture of an object (sphere) without make it editable.
                      m_adam @mfersaoui
                      @mfersaoui Yes it's safe.
                      Find an example below, that does what I described previously:
                      class BakeObject(c4d.plugins.ObjectData):
                          """BakeObject Generator"""
                          def __init__(self, *args):
                              super(BakeObject, self).__init__(*args)
                              self.SetOptimizeCache(True)
                          def GetVirtualObjects(self, op, hierarchyhelp):
                              This method is called automatically when Cinema 4D ask for the cache of an object. This is also the place
                              where objects have to be marked as input object by Touching them (destroy their cache in order to disable them in Viewport)
                              :param op: The Python Generator
                              :type op: c4d.BaseObject.
                              :param hh: The hierarchy helper.
                              :type hh: c4d.HierarchyHelp (currently a PyObject).
                              :return: The Representing object (c4d.LineObject or SplineObject)
                              sphere = c4d.BaseObject(c4d.Osphere)
                              sphere[c4d.PRIM_SPHERE_SUB] = 48
                              sphere.MakeTag(c4d.Tphong)
                              return sphere
                          def Message(self, node, msgId, data):
                              Called by Cinema 4D part to notify the object to a special event
                              :param node: The instance of the ObjectData.
                              :type node: c4d.BaseObject
                              :param msgId: The message ID type.
                              :type msgId: int
                              :param data: The message data.
                              :type data: Any, depends of the message passed.
                              :return: Depends of the message type, most of the time True.
                              if msgId==c4d.MSG_DESCRIPTION_COMMAND:
                                  if data['id'][0].id==1006:
                                      if node.GetCache() is None:
                                      # Make sure no other thread are running
                                      c4d.StopAllThreads()
                                      # Retrieves a clone of the current object's cache.
                                      cacheClone = node.GetCache().GetClone()
                                      # Insert it into the current doc
                                      node.GetDocument().InsertObject(cacheClone)
                                      # Performs a Current State to Object to retrieve a polygonObject.
                                      resultCSTO = c4d.utils.SendModelingCommand(command=c4d.MCOMMAND_CURRENTSTATETOOBJECT, list=[cacheClone], doc=node.GetDocument())
                                      if not isinstance(resultCSTO, list) or not resultCSTO:
                                          cacheClone.Remove()
                                          raise RuntimeError("Failed to perform MCOMMAND_CURRENTSTATETOOBJECT.")
                                      polygonizedCache = None
                                      if resultCSTO[0].CheckType(c4d.Opolygon):
                                          polygonizedCache = resultCSTO[0]
                                      # If the results is a Null, performs a Join command to retrieve only one object.
                                      elif resultCSTO[0].CheckType(c4d.Onull):
                                          resultJoin = c4d.utils.SendModelingCommand(command=c4d.MCOMMAND_JOIN, list=[resultCSTO[0]], doc=node.GetDocument())
                                          if not isinstance(resultJoin, list) or not resultJoin:
                                              cacheClone.Remove()
                                              for obj in resultCSTO:
                                                  obj.Remove()
                                              raise RuntimeError("Failed to perform MCOMMAND_JOIN.")
                                          polygonizedCache = resultJoin[0]
                                      # Remove the cached clone of our Generator from the document since we get the poligonalized version of it
                                      cacheClone.Remove()
                                      if polygonizedCache is None:
                                      # Now that we have a PolygonObject we can perform our baking
                                      # First we need a glossy material, so lets create it
                                      glossyMat = c4d.Material()
                                      # Disables teh color channel
                                      glossyMat[c4d.MATERIAL_USE_COLOR] = False
                                      # Removes the default specular layer
                                      glossyMat.RemoveReflectionLayerIndex(0)
                                      # Adds a layer
                                      layer = glossyMat.AddReflectionLayer()
                                      # Sets the Layer to GGX mode
                                      glossyMat[layer.GetDataID() + c4d.REFLECTION_LAYER_MAIN_DISTRIBUTION] = c4d.REFLECTION_DISTRIBUTION_GGX
                                      # Defines the Roughness float value
                                      glossyMat[layer.GetDataID() + c4d.REFLECTION_LAYER_MAIN_VALUE_ROUGHNESS] = 0.0
                                      # Defines the Reflection float value
                                      glossyMat[layer.GetDataID() + c4d.REFLECTION_LAYER_MAIN_VALUE_REFLECTION] = 1.0
                                      # Inserts glossy mat and the polygonized object into the document
                                      node.GetDocument().InsertMaterial(glossyMat)
                                      node.GetDocument().InsertObject(polygonizedCache)
                                      # Assigns the glossy Mat to the Polygonized Object
                                      textureTag = polygonizedCache.MakeTag(c4d.Ttexture)
                                      textureTag[c4d.TEXTURETAG_MATERIAL] = glossyMat
                                      # Now we can start the bake process
                                      bakeData = c4d.BaseContainer()
                                      bakeData[c4d.BAKE_TEX_WIDTH] = 512
                                      bakeData[c4d.BAKE_TEX_HEIGHT] = 512
                                      bakeData[c4d.BAKE_TEX_USE_PHONG_TAG] = True
                                      bakeData[c4d.BAKE_TEX_CONTINUE_UV] = True
                                      bakeData[c4d.BAKE_TEX_COLORPROFILE] = c4d.bitmaps.ColorProfile.GetDefaultLinearRGB()
                                      bakeData[c4d.BAKE_TEX_FILL_COLOR] = c4d.Vector(0.0)
                                      bakeData[c4d.BAKE_TEX_PIXELBORDER] = 12
                                      bakeData[c4d.BAKE_TEX_UV_LEFT] = 0.0
                                      bakeData[c4d.BAKE_TEX_UV_RIGHT] = 1.0
                                      bakeData[c4d.BAKE_TEX_UV_TOP] = 0.0
                                      bakeData[c4d.BAKE_TEX_UV_BOTTOM] = 1.0
                                      # Initialize the Baking
                                      bakeInfo = c4d.utils.InitBakeTexture(node.GetDocument(), textureTag, polygonizedCache.GetTag(c4d.Tuvw), polygonizedCache.GetTag(c4d.Tuvw), bakeData)
                                      bakeDoc = bakeInfo[0]
                                      bakeStatus = bakeInfo[1]
                                      if bakeStatus != c4d.BAKE_TEX_ERR_NONE or bakeDoc is None:
                                          polygonizedCache.Remove()
                                          glossyMat.Remove()
                                      # Bake as a 32bit
                                      bakeBmp = c4d.bitmaps.MultipassBitmap(512, 512, c4d.COLORMODE_RGBf)
                                      bakeStatus = c4d.utils.BakeTexture(bakeDoc, bakeData, bakeBmp, c4d.threading.GeGetCurrentThread(), self.BakeTextureHook)
                                      if bakeStatus != c4d.BAKE_TEX_ERR_NONE:
                                          glossyMat.Remove()
                                      # Dispay the baking result
                                      c4d.bitmaps.ShowBitmap(bakeBmp)
                                      # Cleanup temp stuff
                                      glossyMat.Remove()
                          def BakeTextureHook(self, info):
                              # Texture Baker hook, currently not used
                              # print info
                              pass
                      mfersaouiM 1 Reply Last reply Reply Quote 1
                        mfersaoui @m_adam
                        @m_adam said in Bake Texture within ObjectData:
                        This example helped me a lot. Thank you so much.
                        Regards,
                        Mustapha
