    Objects created in real time
    pythonr19r21r20
    6 Posts 5 Posters 1.3k Views 2 Watching
    • KantroninK Offline
      Kantronin
      I an converting all my C.O.F.F.E.E scripts to python.
      But I have a problem with python at the real-time display of the objects I create.
      I synthesized this problem in the simplified script below.
      If I press on the button <Creation null polygon> the polygon will only show on the screen when I close the plugin window.
      How to make the polygon appear on the screen without being obliged to close the plugin window ?
      from c4d import gui, documents
      button_1 = 1000
      class MyDialog(c4d.gui.GeDialog):
      	def CreateLayout(self):
      		self.SetTitle("Creation polygon")
      		self.AddButton(button_1, c4d.BFH_LEFT, 300, 24, "Creation null polygon")
      		self.GroupEnd()
      	def Command(self, cid, msg):
      		if cid == button_1:
      			polygon = c4d.BaseObject(c4d.Opolygon)
      			doc.InsertObject(polygon)
      class MyCommandData(c4d.plugins.CommandData):
      	def Execute(self, doc):
      		dlg = MyDialog()
      		dlg.Open(c4d.DLG_TYPE_MODAL, -1, -1, 400, 200)
      		dlg.InitValues(self)
      	c4d.plugins.RegisterCommandPlugin(id=10000015,
                                            str="Creation polygon",
                                            info=0,
                                            icon=c4d.bitmaps.BaseBitmap(),
                                            help="",
                                            dat=MyCommandData())
        have you tried using a non-modal dialog? I am using dialogs not very often, but it could be possible that the modal dialog blocks redraws of your scene.
        dlg.Open(c4d.DLG_TYPE_ASYNC, -1, -1, 400, 200)
        Sometimes you have also to invoke a redraw manually.
        c4d.EventAdd(c4d.EVENT_FORCEREDRAW)
        or
        c4d.DrawViews(c4d.DRAWFLAGS_NONE)
        Cannot say much else, do not have c4d here to test your code.
        zipit
          mp5gosu
          You are calling the Dialog via DLG_TYPE_MODAL. So the Dialog is blocking the main thread until you close it.
          Try opening the dialog with DLG_TYPE_ASYNC.
            Kantronin
            It was indeed the modal window that prevented the real-time display of objects.
            By putting the code below, the display of objects is immediate.
            self.dlg = MyDialog()
            self.dlg.Open(c4d.DLG_TYPE_ASYNC, -1, -1, 400, 200)
            However, the plugin window opens to the left of my screen and to move it to the center of the screen, I must first enlarge it.
            I find that a little strange !
            But it can be considered that my problem is solved.
            Thank you for your answers
            • CairynC Offline
              Cairyn @Kantronin
              @Kantronin said in Objects created in real time:
              The GeDialog manual says:
              If xpos=-1 and ypos=-1 the dialog will be opened at the current mouse position.
              If xpos=-2 and ypos=-2 the dialog will be opened at the center of the screen.
              So, if the dialog opens to the left of your screen, I guess that's where your mouse was? Try -2, -2.
                For your next threads, please help us keeping things organised and clean. I know it's not your priority but it really simplify our work here.
                • Q&A New Functionality.
                • How to Post Questions especially the tagging part.
                @zipit and @Cairyn have already answer here (thanks a lot) nothing to add.
