    Graphview OpenDialog id?
    r19python
    4 Posts 3 Posters 572 Views 2 Watching
    • chuanzhenC Offline
      chuanzhen
      graphview OpenDialog(id,master),How to set this id to make the xpresso tag open in the default layout?
      Thanks for any help!☺
      相信我,可以的!
        Assuming with the default layout you mean the layout you get when clicking on an exprsso node, 1001148 (the id of the "XPresso Editor" plugin) seems to do the trick. I did not bother trying to find the symbol for that ID, because I am not sure if there is even one in Python.
        """ All plugins that contain the substring "presso" in their name
        Plugins with the ID 400009000:
        	<c4d.plugins.BasePlugin object called 'Start XPresso Calculation' with ID 4 at 0x00000181C3D07830>
        	child nodes: []
        Plugins with the ID 1001145:
        	<c4d.plugins.BasePlugin object called 'XPresso Manager' with ID 4 at 0x00000181C3D07470>
        	child nodes: []
        Plugins with the ID 1001138:
        	<c4d.plugins.BasePlugin object called 'XPresso Pool' with ID 4 at 0x00000181C3D07BB0>
        	child nodes: []
        Plugins with the ID 1001148:
        	<c4d.plugins.BasePlugin object called 'XPresso Editor' with ID 21 at 0x00000181C3D07EB0>
        	child nodes: []
        Plugins with the ID 1001149:
        	<c4d.plugins.BasePlugin object called 'XPresso' with ID 6 at 0x00000181C3D07F90>
        	child nodes: []
            # get the (first) expresso tag of the selected object
            tag = op.GetTag(c4d.Texpresso)
            if not tag:
            # get the GvNodeMaster of that tag
            master = tag.GetNodeMaster()
            # open the graphview window for that master in the 'XPresso Editor' layout
            c4d.modules.graphview.OpenDialog(1001148, master)
        zipit
        chuanzhenC 1 Reply Last reply Reply Quote 0
          chuanzhen @ferdinand
          @zipit Thanks ,"id = 1001148" it work correctly☺
          相信我,可以的!
            hello,
            ID_TREEVIEW_PLUGIN 1001145
            ID_EXPRESSION_PLUGIN 1001148
            ID_OPERATORPOOL_PLUGIN 1001138
            ID_EXPRESSION_TAG 1001149
            last one should be but it's not defined in python.
            ID_CALCULATE_PLUGIN 400009000
