    Make editable an object generated by GetVirtualObjects()
    19 Posts 3 Posters 3.8k Views 2 Watching
    • mfersaouiM Offline
      mfersaoui @ferdinand
      I'm actually developing a new version of HDRI Studio Generator Tool, is a complex Rig using UserData and Xpresso. So for the new version I want to replace all the UserData by the Description Resource and using the GVO to benefit from the c4d.plugins.ObjectData Automated Handle Interface: GetHandle()/SetHandle()/GetHandleCount() and other advantages.
      If you don't mind, here is a full plugin that use a similar method:
      primitive_objects.zip (I don't know if I am authorized to share zip file here)
      In comparison with this plugin example my actual rig is very complex it contain hundreds of description resource and twenty Handle Count. the plugin example it's only to see the method that I use.
      I hope that is clear. I down know how explain you what I want to do exactly 🙂
        yes, while I still have no c4d here (so I could not use your zip), this does make things a lot more understandable for me.
        Here is a quick sketch on how I would go about implementing, what you want to do.
        class LightRig(c4d.plugins.ObjectData):
            def __init__(self):
                self._light_rig_cache = {}
            def Init(self, op):
                self.SetOptimizeCache(True)
            def _load_first_object_from_file(self, path):
                ''' Returns the first object from a file path interpreted as a c4d
                 document.
                    Args:
                        path (str): The file path.
                    Raises:
                        IOError: When the file path does not exists or could not be red.
                        IOError: When the document does not contain any objects.
                    Returns:
                        c4d.BaseObject: The first object of the document.
                doc = c4d.documents.LoadDocument(path, c4d.SCENEFILTER_NONE, None)
                if doc is None:
                    msg = 'Could not load file.'
                    raise IOError(msg)
                op = doc.GetFirstObject()
                if op is None:
                    msg = 'Target object not found.'
                    raise IOError(msg)
                return op.GetClone()
            def _get_light_rig(self, lid):
                ''' Either loads the light rig with the given id from a file or
                 returns a copy of the local cache.
                    Args:
                        lid (int): The integer identifier for the requested light rig.
                    Raises:
                        IOError: When the hardcoded file path does not exists or could
                         not be red.
                        ValueError: If lid is not a legal light rig id.
                    Returns:
                        c4d.BaseObject: The requested light rig.
                # Return an cached object from our ligth rig hash table
                if lid in self._light_rig_cache:
                    return self._light_rig_cache[lid].GetClone()
                # Or load it from a file and add it to the cache
                if lid == c4d.ID_MY_FANCY_LIGHT_RIG_1:
                    rig = self._load_first_object_from_file(SOME_FRIGGING_FILE_PATH_1)
                    self._light_rig_cache[lid] = rig
                elif lid == c4d.ID_MY_FANCY_LIGHT_RIG_2:
                    rig = self._load_first_object_from_file(SOME_FRIGGING_FILE_PATH_2)
                    msg = 'Illegal light rig id: {}.'
                    raise ValueError(msg.format(lid))
                return rig.GetClone()
            def GetVirtualObjects(self, op, hierarchyhelp):
                ''' Returns the preloaded light rig cache.
                # The more verbose form would be somehing like:
                # if op[c4d.LIGTH_RIG_TYPE] == c4d.ID_MY_FANCY_LIGHT_RIG_1:
                #     return self.get_light_rig(c4d.ID_MY_FANCY_LIGHT_RIG_1)
                # elif ...
                return self._get_light_rig(op[c4d.LIGHT_RIG_TYPE])
        A few notes:
        1. I wrote this on an iPad from my head, so, jeah, view it as a 'draft'.
        2. Using predefined data from a document is still a rather exotic concept. You might have to preload all data, when you run into threading issues.
        3. The preloading / caching of your light rigs is in general a problem, as it will increase the memory footprint of your plugin.
        4. Building your rigs procedurally might be a better option performancewise.
        zipit
        mfersaouiM 1 Reply Last reply Reply Quote 0
          @zipit
          Here is short video capture to compare between the result of my method and the result of your method, in my method the object stay visible when I moving the Handle point or make change in object data instance but with your method the object is not visible when I moving the Handle point or make change in object data instance.
          For this reason I'm using this method.
          Thank you for your time.
            1. I am absolutely fine with it if you prefer something else.
            2. I do not know what you are doing exactly in your video, but yes, "your" side does look better. But that almost has certainly nothing todo how you impement your GVO.
            3. I have to point out again that there is no my method and your method. You are using GVO in a way that is not allowed by the c4d SDK. Read the provided links above on threading. They are crystal clear on that topic. Or contact the the SDK support team, they will tell you the same.
            4. While things might work in your small test environment, they won't in a production environment. Consider how pissed your clients or your company will be when your plugin has corrupted their files.
            Consider yourself to have been warned 😉
            zipit
              @zipit
              Sorry, I said "My method" and "Your method" just to differentiate between the two methods. I don't said that my method is better I'm just searching a legal method that allow me to obtain a similar result as the method that I'm using now.
              in the method that I'm using the preset is loaded in document only one time. So, for example when I move the object handle points the change is applied into the previous loaded object.
              The loaded object has a python tag that contain all object controls.
              here is an example of python tag content:
                  obj = op.GetObject()
                  parent = obj.GetUp()
                  scale = parent[c4d.PRIMITIVEOBJECTS_GLOBAL_SCALE]
                  # Objects scale
                  obj.SetAbsScale(c4d.Vector(scale))
              But with second method at each change the preset object is reloaded from disc or cache with the new changes (the preset object is removed then reloaded with the new changes) and that result that the object is becomes not visible in the View during a few thousandths of a second.
              I'm thinking about another alternative, is the following code cause the same problem:
                      path = os.path.join(os.path.dirname(__file__), "res", "my_scene.c4d")
                      load = c4d.documents.MergeDocument(doc, path, c4d.SCENEFILTER_OBJECTS)
                      if load is False:
                      return c4d.BaseObject(c4d.Onull)
                no need to be sorry, I am / was not offended. I was just trying to be very clear about the implications of your approach.
                1. If you want to have a statically generated object, ObjectData is not the correct base class for you, as its whole purpose is to provide a dynamically generated object when you overwrite GVO.
                2. Loading an object from a preset file is quite an unusal thing to do for the ObjectData type. The more common thing to do, would be to construct your rig procedurally within your GVO. Which would probably also (apart from performance benefits) alleviate the problems you have shown in the video.
                3. Also noteworthy is, that a python scripting tag also calls the draw() function of your script, which you could use to draw / react to to handles with your original xpresso and user data steup.
                zipit
                mfersaouiM 1 Reply Last reply Reply Quote 1
                  @zipit
                  Thank you, I'm trying to rebuild all my rig inside the GVO and I think I will using C++.
                  is it better to use c++?
                  Mustapha
                    ferdinand @mfersaoui
                    I think the answer to that is highly subjective. Both SDKs and languages have their strengths. As your plugin probably is neither going to be computationally expensive, nor will be in need of any of the more advanced features only the C++ SDK does offer, I would say, Python wins this cost/gain comparison by a long shot.
                    But that is subjective 😉
                    zipit
                    • S Offline
                      s_bach
                      just to make some things clear:
                      • The purpose of GetVirtualObjects() is to fill a cache with virtual objects.
                      • It is NOT the purpose of GetVirtualObjects() to modify the document / the scene graph.
                      • It is forbidden to edit the scene graph from within the scene execution pipeline e.g. from within GetVirtualObjects().
                      • One must only edit the scene graph in reaction to some user interaction e.g. after the user pressed some button in the UI or used a tool.
                      • One must never call GetActiveDocument() in a NodeData based function. The active document is the document currently displayed in the viewport; but there is no reason to think that this is the document that hosts the object.
                      • Consequentially, one must never call EventAdd() in a NodeData based function; especially not from within the execution pipeline.
                      • If you want your generator to load a given scene file, you can load that scene with LoadDocument() and just COPY the content into the cache.
                      • The Python API is an incomplete wrapper around the C++ API. So some functions may be missing in the Python API.
                      mfersaouiM 2 Replies Last reply Reply Quote 1
                        mfersaoui @s_bach
                        @s_bach said in Make editable an object generated by GetVirtualObjects():
                        GetVirtualObjects()
                        Thank you, I decided to use C++ to do that, I just post new topic "MAXPORTS GraphView Flags - Description Resource" is a continuity of this topic.
                          mfersaoui @s_bach
                          LoadDocument()
                          I gave up the idea to merge objects from scene file, I had generate my object and all her sub-objects inside the GetVirtualObjects(). But now I'm searching how to assign materials to my sub-objects, I would imagine that is the same as objects, should I use the LoadDocument()? if yes are there examples? and then can I change these materials proprieties from the object description resource or I must to use CommandData dialog?
                          Thank you.
                          • S Offline
                            s_bach
                            a generator (GetVirtualObjects()) cannot create materials. You must generate materials in reaction to user-interaction (Material Manual). Then you can assign materials to your (virtual) objects using a TextureTag (TextureTag Manual).
                            for example, you could detect when your generator object is created from the UI by listening to the MSG_MENUPREPARE message in NodeData.Message(). Then you can create all the materials you want to use later.
                            mfersaouiM 1 Reply Last reply Reply Quote 2
                              mfersaoui @s_bach
                              @s_bach
                              Thank you, As you explained, I create all materials in NodeData.Message() and then I called them in the GVO. I just want to know if is it allowed to edit the called material parameters inside the GVO or not? see example bellow:
                              BaseObject* MyObject::GetVirtualObjects(BaseObject* op, HierarchyHelp* hh) {
                                      BaseObject* container = BaseObject::Alloc(Onull);
                              	if (!container)
                              		return BaseObject::Alloc(Onull);
                              	container->SetName("Container");
                              	BaseMaterial* material = doc->SearchMaterial("my_material");
                              	if (material) {
                              		// create the texture tag
                              		TextureTag* const textureTag = static_cast<TextureTag*>(container->MakeTag(Ttexture));
                              		if (textureTag == nullptr)
                              			return maxon::OutOfMemoryError(MAXON_SOURCE_LOCATION);
                              		const Float Brightness = data->GetFloat(MYOBJECT_LIGHT_INTENSITY);
                              		// Is the following action allowed inside GVO:
                              		material->SetParameter(DescID(MATERIAL_LUMINANCE_BRIGHTNESS), Brightness, DESCFLAGS_SET_0);
                              		textureTag->SetMaterial(material);
                              Best,
                              Mustapha
                                mfersaoui @mfersaoui
                                I think this is not allowed. I've just seen the list of the Forbidden Functions and "Make any changes to materials." is inside.
                                • S Offline
                                  s_bach
                                  as said before, it is not the purpose of GetVirtualObject() to edit the scene or to edit elements of the scene; this includes materials.
