    Python Scripting-Help with GeDialog.AddComboBox add child option
    12 Posts 4 Posters 3.4k Views 2 Watching
    • R Offline
      referent
      Hi Sebastian! Thanks a lot for your reply!!!
      and for clarifying me about posting and categories
      I couldn't figure out at the end to add command and that all complete script works by example that you send me here.
      Maybe I wasn't clear enough of what I trying to do and to get as the final result.
      My goal is that I make preset with names e.g child 0-or final name "Bath" and when I run script and chose from dropping menu of combo box e.g name "Bath" or some other next selection child 2 or final name "Patio" by selection from item with ready name "Patio" script and code automatically rename new spline based on selection from combobox eg I draw new Spline> and when I select from combo box child's selection Patio command will automatically rename spline to Patio,if is that possible? Plugin cafe is simply awesome,and I am happy so happy to discover it.
      Best Wishes
      Nenad
      • S Offline
        s_bach
        a GeDialog of a Python script must be a modal dialog. This means that while this dialog is opened, you can only interact with that dialog.
        Therefore you can use your script to change the name of any previously created (active) object.
        R 1 Reply Last reply Reply Quote 2
        • R Offline
          referent @s_bach
          @s_bach Hello Sebastian!
          The main issue is when I implement command and custom member function into the whole script how you suggest in to previously reply, nothing happening and the script wouldn't work.Or when I just copy your code example in to script manager nothing happening,I am using R17 if that can maybe be one of the reasons why script not work?
          class TestDialog(gui.GeDialog):
          def CreateLayout(self):
              self.AddComboBox(5000, c4d.BFH_LEFT, 100, 10, False)
              self.AddChild(5000, 0, "Child 0")
              self.AddChild(5000, 1, "Child 1")
              self.AddChild(5000, 2, "Child 2")
          def Command(self, id, msg):
              # print currently selected "child""
              if id == 5000:
                  value = self.GetInt32(5000)
                  print("got value: " + str(value))
              return c4d.gui.GeDialog.Command(self, id, msg)
          # custom function
          def GetSelectedChild(self):
              return self.GetInt32(5000)
          dialog = TestDialog()
          dialog.Open(c4d.DLG_TYPE_MODAL_RESIZEABLE, 132456, -1 ,-1 ,400 ,400)
          value = dialog.GetSelectedChild()
          op.SetName(str(value))
          Thank you for reply!
          Regards
          • S Offline
            s_bach
            you have to add
            as usual to execute the script.
            • R Offline
              referent
              • R Offline
                referent
                from c4d import gui
                    if id == 5000:
                # custom function
                if name=='main':
                • R Offline
                  referent
                  It is not working, and script isn't executable as I said in previously message,
                  thank you for your reply,
                  Regards
                  • CairynC Offline
                    Cairyn
                    Working fine for me, once I correct all the indentations. I am not sure whether your script's indents are okay, since the code is broken up into several code-quotes, but in case it's not: the methods of the class need to be indented under the class definition.
                    I don't see anything that would work under R19 (my current test) but not under R17 (your version) so this is a bit of guesswork. What is the console saying when you try to execute the code?
                    You will need to add a line to close the dialog, too, and to transform the returned value into the proper string instead of the index number as string... maybe use a dictionary for value/string pairs.
                    from c4d import gui
                    dropdown_values = {
                                       0:"Child 0",
                                       1:"Child 1",
                                       2:"Child 2"
                        pass_value = 0
                            self.AddChild(5000, 0, dropdown_values.get(0))
                            self.AddChild(5000, 1, dropdown_values.get(1))
                            self.AddChild(5000, 2, dropdown_values.get(2))
                            if id == 5000:
                                print("got index: " + str(value) + ", value: " + dropdown_values.get(value))
                                self.pass_value = value
                                self.Close()
                        # custom function
                            return self.pass_value
                        print "Value after call: ", value
                        op.SetName(dropdown_values.get(value))
                    • R Offline
                      referent
                      Wow! Thank you soooooooooooo much!
                      Those parts were missing. Works like a charm now! 🙂
                      can't thank you enough!
                      We can close now this topic
                        Please do not delete topics once they are resolved, this topic may help other people that have the same issue.
                        Instead, use the Q&A functionality to mark a topic as solved.
