    Python Scripting-Help with GeDialog.AddComboBox add child option
    12 Posts 4 Posters 3.2k Views 2 Watching
    • R Offline
      referent
      Hi everyone,
      I am new with python scripting so I stuck with this and sorry for my question
      I trying to make a script -later plugin also that will rename automatically e.g.spline by selection from combo box menu with new selected name
      is there a way to add children -6+ options to combo box and send rename command based on a selection from combo box? Here is what I mean and a sample .I find 2 ways for this but I would like to have combobox selection and dropping menu 0_1550960540480_07f88f3d-f799-4997-b4a2-6c88be2cb93a-image.png
      Here are 2 examples that I make:
      Example 1:
      from c4d import gui
      #Dialog settings
      class MyDialogs(gui.GeDialog):
      # Dialog layout settings
      def CreateLayout(self):
      self.SetTitle('Spline Renamer 1.1')
      #Setting widget etc.
      self.GroupBegin(10000, c4d.BFH_SCALEFIT, 1, title = 'Select New Spline Name')
      self.GroupBorder(c4d.BORDER_GROUP_IN)
      self.GroupBorderSpace(20, 5, 20, 5)
          #Drop menu
          self.AddComboBox(1000, c4d.BFH_SCALEFIT, 80, 0, False)
          self.AddChild(1000, 0, 'B1')
          self.AddChild(1000, 1, 'B2')
          self.AddChild(1000, 2, 'B3')
          self.AddChild(1000, 3, 'B4')
          self.AddChild(1000, 4, 'Main')
          self.AddChild(1000, 5, 'Outer')
          self.AddChild(1000, 6, 'Patio')
          self.AddChild(1000, 7, 'Bath 1')
          self.AddChild(1000, 8, 'Bath 2')
          self.AddChild(1000, 9, 'Bath 3')
          self.AddChild(1000, 10, 'WIC')
          self.AddSeparatorV(11)
          self.AddDlgGroup(c4d.DLG_OK|c4d.DLG_CANCEL)
      dlg = MyDialogs()
      dlg.Open(c4d.DLG_TYPE_MODAL)
      if name=='main':
      if name=='main':
      This Example 2 works but I dont have combobox or droping menu:
      from c4d import gui
      objs = doc.GetActiveObjects(1)
      if len(objs) == 0:return
      newName = gui.InputDialog("New Name","B1")
      if newName == "":return
      num = gui.InputDialog("Are you sure?","B1")
      if num == "":return
      doc.StartUndo()
      for obj in objs:
          doc.AddUndo(c4d.UNDOTYPE_CHANGE,obj)
          obj.SetName(newName +" ")
      GeDialog.SetPopup("B 12 ", " B 22")
      doc.EndUndo()
      Thanks you so much for any of your help and for your time,
      have a great day!
      • S Offline
        s_bach
        Hello and welcome to the PluginCafe,
        please post your questions regarding the Cinema 4D APIs in the "Cinema 4D Development" category. Also, please use tags and the Q&A system. You find all that information in "Read Before Posting".
        Is your question how to get the currently selected item of the combo box?
        You can implement the "Command" function of your dialog to be informed when the selected value changed. This way you could rename the object when that happens.
        Alternatively, you can access the selected element using a custom member function of the dialog. You can use the returned value to do what you want in the caller code.
        Something like this:
        class TestDialog(gui.GeDialog):
                self.AddComboBox(5000, c4d.BFH_LEFT, 100, 10, False)
                self.AddChild(5000, 0, "Child 0")
                self.AddChild(5000, 1, "Child 1")
                self.AddChild(5000, 2, "Child 2")
            def Command(self, id, msg):
                # print currently selected "child""
                if id == 5000:
                    value = self.GetInt32(5000)
                    print("got value: " + str(value))
                return c4d.gui.GeDialog.Command(self, id, msg)
            # custom function
            def GetSelectedChild(self):
                return self.GetInt32(5000)
            dialog = TestDialog()
            dialog.Open(c4d.DLG_TYPE_MODAL_RESIZEABLE, 132456, -1 ,-1 ,400 ,400)
            value = dialog.GetSelectedChild()
            op.SetName(str(value))
        • R Offline
          referent
          Hi Sebastian! Thanks a lot for your reply!!!
          and for clarifying me about posting and categories
          I couldn't figure out at the end to add command and that all complete script works by example that you send me here.
          Maybe I wasn't clear enough of what I trying to do and to get as the final result.
          My goal is that I make preset with names e.g child 0-or final name "Bath" and when I run script and chose from dropping menu of combo box e.g name "Bath" or some other next selection child 2 or final name "Patio" by selection from item with ready name "Patio" script and code automatically rename new spline based on selection from combobox eg I draw new Spline> and when I select from combo box child's selection Patio command will automatically rename spline to Patio,if is that possible? Plugin cafe is simply awesome,and I am happy so happy to discover it.
          Best Wishes
          Nenad
          • S Offline
            s_bach
            a GeDialog of a Python script must be a modal dialog. This means that while this dialog is opened, you can only interact with that dialog.
            Therefore you can use your script to change the name of any previously created (active) object.
            R 1 Reply Last reply Reply Quote 2
            • R Offline
              referent @s_bach
              @s_bach Hello Sebastian!
              The main issue is when I implement command and custom member function into the whole script how you suggest in to previously reply, nothing happening and the script wouldn't work.Or when I just copy your code example in to script manager nothing happening,I am using R17 if that can maybe be one of the reasons why script not work?
                  if id == 5000:
              # custom function
              Thank you for reply!
              Regards
              • S Offline
                s_bach
                you have to add
                as usual to execute the script.
                • R Offline
                  referent
                  • R Offline
                    referent
                    from c4d import gui
                        if id == 5000:
                    # custom function
                    if name=='main':
                    • R Offline
                      referent
                      It is not working, and script isn't executable as I said in previously message,
                      thank you for your reply,
                      Regards
                      • CairynC Offline
                        Cairyn
                        Working fine for me, once I correct all the indentations. I am not sure whether your script's indents are okay, since the code is broken up into several code-quotes, but in case it's not: the methods of the class need to be indented under the class definition.
                        I don't see anything that would work under R19 (my current test) but not under R17 (your version) so this is a bit of guesswork. What is the console saying when you try to execute the code?
                        You will need to add a line to close the dialog, too, and to transform the returned value into the proper string instead of the index number as string... maybe use a dictionary for value/string pairs.
                        from c4d import gui
                        dropdown_values = {
                                           0:"Child 0",
                                           1:"Child 1",
                                           2:"Child 2"
                            pass_value = 0
                                self.AddChild(5000, 0, dropdown_values.get(0))
                                self.AddChild(5000, 1, dropdown_values.get(1))
                                self.AddChild(5000, 2, dropdown_values.get(2))
                                if id == 5000:
                                    print("got index: " + str(value) + ", value: " + dropdown_values.get(value))
                                    self.pass_value = value
                                    self.Close()
                            # custom function
                                return self.pass_value
                            print "Value after call: ", value
                            op.SetName(dropdown_values.get(value))
                        • R Offline
                          referent
                          Wow! Thank you soooooooooooo much!
                          Those parts were missing. Works like a charm now! 🙂
                          can't thank you enough!
                          We can close now this topic
                            Please do not delete topics once they are resolved, this topic may help other people that have the same issue.
                            Instead, use the Q&A functionality to mark a topic as solved.
