    change drawtext size in GeUserArea [SOLVED]
    18 Posts 0 Posters 1.7k Views
      On 04/05/2015 at 10:09, xxxxxxxx wrote:
      Would be nice if you linked the examples here for the others 🙂
        On 04/05/2015 at 16:35, xxxxxxxx wrote:
        right
        https://developers.maxon.net/forum/topic/7451/9272_geclipmap-in-userarea&KW=geclipmap
        https://developers.maxon.net/forum/topic/7190/8229_bitmap-to-geclipmap&KW=geclipmap
          On 04/05/2015 at 17:15, xxxxxxxx wrote:
          	DrawSetPen(Vector(0.8, 0.2, 0.2));
          	//AutoAlloc<BaseBitmap> bm;
          	AutoFree<MultipassBitmap> bm = MultipassBitmap::Alloc(128, 128, COLORMODE_ARGB);
          	if(!bm) return;
          	bm->AddChannel(TRUE,TRUE);
          	//bm->Init(128, 128, 32);
          	//bm->Clear(0,0,0);
          	BaseBitmap *mAlpha = bm->GetInternalChannel();
          	if(!mAlpha) return;
          	for(Int32 i = 0; i < 128; ++i)
          		for(Int32 j = 0; j < 128; ++j)
          			bm->SetAlphaPixel(mAlpha, i, j, 0);
          	AutoAlloc<GeClipMap> cm;
          	if(!cm) return;
          	cm->Init(bm, mAlpha);
          	BaseContainer mFont;
          	//cm->Init(128, 128, 32);
          	Float mFontSize = cm->GetFont(&mFont);
          	BaseBitmap *mBitmap = cm->GetBitmap();
          	cm->BeginDraw();
          	//cm->SetColor(0, 0, 0, 0);
          	//cm->FillRect(0, 0, 127, 127);
          	cm->SetColor(150, 160, 170, 255);
          	cm->TextAt(4, 4, "Hello World1");
          	cm->EndDraw();
          	Int32 mw = cm->GetBw();
          	Int32 mh = cm->GetBh();
          	DrawBitmap(mBitmap,0,0,mw,mh,0,0,mw,mh,BMP_ALLOWALPHA);
          it draws the text with red background, I want the background to be transparent, what should I do?
            On 05/05/2015 at 19:09, xxxxxxxx wrote:
            no one knows if this is a bug or not? the Bitmap should be empty, but for unknown reason it fills the Bitmap with the last pen color, any idea how to solve this?
              On 05/05/2015 at 22:20, xxxxxxxx wrote:
              Hi Mohamed,
              I'm currently at FMX. I'll be looking into this after my return next Monday.
                On 05/05/2015 at 23:49, xxxxxxxx wrote:
                I've also experienced this. DrawBitmap() seems to use the last pen
                color instead of mixing alpha pixels with the pixels that are already on
                the GeUserArea.
                  On 06/05/2015 at 06:48, xxxxxxxx wrote:
                  No need for the explicit additional bitmap and alpha channel allocation.
                  You can set the transparency value with SetColor(r,g,b,a).
                  i.e. cm->SetColor(r,g,b,128) will give a half transparent output.
                  hth
                    On 06/05/2015 at 13:46, xxxxxxxx wrote:
                    yea Samir, but it remains with an unavoidable bug!! , background is not transparent.
                      On 07/05/2015 at 03:34, xxxxxxxx wrote:
                      I can't confirm. It works. Here is the code:
                      OffScreenOn();
                          	Int32 w = 100;
                          	Int32 h = 100;
                          	AutoAlloc<GeClipMap> bmp;
                          	bmp->Init(w,h,32);
                          	bmp->BeginDraw();
                          	bmp->SetDrawMode(GE_CM_DRAWMODE_COPY,255);
                          	bmp->SetColor(255,255,255,0); //Fully transparent
                          	bmp->FillRect(0,0,w,h); //Set the whole bitmap transparent
                          	bmp->SetColor(255,255,255,128); //50% transparent
                          	bmp->TextAt(10,10,"Katachi rocks.. :-D"); //Draw text
                          	bmp->EndDraw();
                          	DrawBitmap(bmp->GetBitmap(),0,0,w,h,0,0,w,h,BMP_ALLOWALPHA);
                        On 07/05/2015 at 06:43, xxxxxxxx wrote:
                        Hi Samir,
                        try to add DrawSetPen(Vector(0.8, 0.2, 0.2)); "or any other color" after OffScreenOn(); and you will find the bug, I tested your code and the same problem appears.
                          On 07/05/2015 at 10:23, xxxxxxxx wrote:
                          Then don't. Why are you using DrawSetPen?
                            On 07/05/2015 at 14:23, xxxxxxxx wrote:
                            drawing other stuff prior to texts, should I draw everything in one clipmap? not sure about performance, I will test, it may worth a shot!!
                              On 08/05/2015 at 01:19, xxxxxxxx wrote:
                              yes, if you don't have a good reason, you should stay with the clip map drawing functions.
                                On 16/05/2015 at 21:26, xxxxxxxx wrote:
                                after using GeClipMap in all drawings it worked perfectly , thanks all for the help, you can mark this as solved
