    change drawtext size in GeUserArea [SOLVED]
    18 Posts 0 Posters 1.2k Views
      On 01/05/2015 at 11:44, xxxxxxxx wrote:
      Cinema 4D Version:   15+
      I want to control the drawing text size inside GeUserArea, is this possible? I don't see this in the header functions so it may be hidden somewhere else?
        On 04/05/2015 at 01:33, xxxxxxxx wrote:
        Hi Mohamed,
        I don't know any option to influence the font size for GeUserArea::DrawText().
        Instead I recommend to use a GeClipMap. There you have full control over the font and its size.
          On 04/05/2015 at 05:55, xxxxxxxx wrote:
          @Andreas , thanks a lot for the hint
          any idea where to use it in the GeUserArea as there is no examples at all!! "I need a minimum example of just where to use it, may be 2~4 lines of code will do it"
            On 04/05/2015 at 10:00, xxxxxxxx wrote:
            I think I forgot to search, found some examples here on the forums, I guess there won't be a problem now, will ask again here if there is any problem.
              On 04/05/2015 at 10:09, xxxxxxxx wrote:
              Would be nice if you linked the examples here for the others 🙂
                On 04/05/2015 at 16:35, xxxxxxxx wrote:
                right
                https://developers.maxon.net/forum/topic/7451/9272_geclipmap-in-userarea&KW=geclipmap
                https://developers.maxon.net/forum/topic/7190/8229_bitmap-to-geclipmap&KW=geclipmap
                  On 04/05/2015 at 17:15, xxxxxxxx wrote:
                  	DrawSetPen(Vector(0.8, 0.2, 0.2));
                  	//AutoAlloc<BaseBitmap> bm;
                  	AutoFree<MultipassBitmap> bm = MultipassBitmap::Alloc(128, 128, COLORMODE_ARGB);
                  	if(!bm) return;
                  	bm->AddChannel(TRUE,TRUE);
                  	//bm->Init(128, 128, 32);
                  	//bm->Clear(0,0,0);
                  	BaseBitmap *mAlpha = bm->GetInternalChannel();
                  	if(!mAlpha) return;
                  	for(Int32 i = 0; i < 128; ++i)
                  		for(Int32 j = 0; j < 128; ++j)
                  			bm->SetAlphaPixel(mAlpha, i, j, 0);
                  	AutoAlloc<GeClipMap> cm;
                  	if(!cm) return;
                  	cm->Init(bm, mAlpha);
                  	BaseContainer mFont;
                  	//cm->Init(128, 128, 32);
                  	Float mFontSize = cm->GetFont(&mFont);
                  	BaseBitmap *mBitmap = cm->GetBitmap();
                  	cm->BeginDraw();
                  	//cm->SetColor(0, 0, 0, 0);
                  	//cm->FillRect(0, 0, 127, 127);
                  	cm->SetColor(150, 160, 170, 255);
                  	cm->TextAt(4, 4, "Hello World1");
                  	cm->EndDraw();
                  	Int32 mw = cm->GetBw();
                  	Int32 mh = cm->GetBh();
                  	DrawBitmap(mBitmap,0,0,mw,mh,0,0,mw,mh,BMP_ALLOWALPHA);
                  it draws the text with red background, I want the background to be transparent, what should I do?
                    On 05/05/2015 at 19:09, xxxxxxxx wrote:
                    no one knows if this is a bug or not? the Bitmap should be empty, but for unknown reason it fills the Bitmap with the last pen color, any idea how to solve this?
                      On 05/05/2015 at 22:20, xxxxxxxx wrote:
                      Hi Mohamed,
                      I'm currently at FMX. I'll be looking into this after my return next Monday.
                        On 05/05/2015 at 23:49, xxxxxxxx wrote:
                        I've also experienced this. DrawBitmap() seems to use the last pen
                        color instead of mixing alpha pixels with the pixels that are already on
                        the GeUserArea.
                          On 06/05/2015 at 06:48, xxxxxxxx wrote:
                          No need for the explicit additional bitmap and alpha channel allocation.
                          You can set the transparency value with SetColor(r,g,b,a).
                          i.e. cm->SetColor(r,g,b,128) will give a half transparent output.
                          hth
                            On 06/05/2015 at 13:46, xxxxxxxx wrote:
                            yea Samir, but it remains with an unavoidable bug!! , background is not transparent.
                              On 07/05/2015 at 03:34, xxxxxxxx wrote:
                              I can't confirm. It works. Here is the code:
                              OffScreenOn();
                                  	Int32 w = 100;
                                  	Int32 h = 100;
                                  	AutoAlloc<GeClipMap> bmp;
                                  	bmp->Init(w,h,32);
                                  	bmp->BeginDraw();
                                  	bmp->SetDrawMode(GE_CM_DRAWMODE_COPY,255);
                                  	bmp->SetColor(255,255,255,0); //Fully transparent
                                  	bmp->FillRect(0,0,w,h); //Set the whole bitmap transparent
                                  	bmp->SetColor(255,255,255,128); //50% transparent
                                  	bmp->TextAt(10,10,"Katachi rocks.. :-D"); //Draw text
                                  	bmp->EndDraw();
                                  	DrawBitmap(bmp->GetBitmap(),0,0,w,h,0,0,w,h,BMP_ALLOWALPHA);
                                On 07/05/2015 at 06:43, xxxxxxxx wrote:
                                Hi Samir,
                                try to add DrawSetPen(Vector(0.8, 0.2, 0.2)); "or any other color" after OffScreenOn(); and you will find the bug, I tested your code and the same problem appears.
                                  On 07/05/2015 at 10:23, xxxxxxxx wrote:
                                  Then don't. Why are you using DrawSetPen?
                                    On 07/05/2015 at 14:23, xxxxxxxx wrote:
                                    drawing other stuff prior to texts, should I draw everything in one clipmap? not sure about performance, I will test, it may worth a shot!!
                                      On 08/05/2015 at 01:19, xxxxxxxx wrote:
                                      yes, if you don't have a good reason, you should stay with the clip map drawing functions.
                                        On 16/05/2015 at 21:26, xxxxxxxx wrote:
                                        after using GeClipMap in all drawings it worked perfectly , thanks all for the help, you can mark this as solved
