    change drawtext size in GeUserArea [SOLVED]
    18 Posts 0 Posters 1.7k Views
      On 04/05/2015 at 01:33, xxxxxxxx wrote:
      Hi Mohamed,
      I don't know any option to influence the font size for GeUserArea::DrawText().
      Instead I recommend to use a GeClipMap. There you have full control over the font and its size.
        On 04/05/2015 at 05:55, xxxxxxxx wrote:
        @Andreas , thanks a lot for the hint
        any idea where to use it in the GeUserArea as there is no examples at all!! "I need a minimum example of just where to use it, may be 2~4 lines of code will do it"
          On 04/05/2015 at 10:00, xxxxxxxx wrote:
          I think I forgot to search, found some examples here on the forums, I guess there won't be a problem now, will ask again here if there is any problem.
            On 04/05/2015 at 10:09, xxxxxxxx wrote:
            Would be nice if you linked the examples here for the others 🙂
              On 04/05/2015 at 16:35, xxxxxxxx wrote:
              right
              https://developers.maxon.net/forum/topic/7451/9272_geclipmap-in-userarea&KW=geclipmap
              https://developers.maxon.net/forum/topic/7190/8229_bitmap-to-geclipmap&KW=geclipmap
                On 04/05/2015 at 17:15, xxxxxxxx wrote:
                	DrawSetPen(Vector(0.8, 0.2, 0.2));
                	//AutoAlloc<BaseBitmap> bm;
                	AutoFree<MultipassBitmap> bm = MultipassBitmap::Alloc(128, 128, COLORMODE_ARGB);
                	if(!bm) return;
                	bm->AddChannel(TRUE,TRUE);
                	//bm->Init(128, 128, 32);
                	//bm->Clear(0,0,0);
                	BaseBitmap *mAlpha = bm->GetInternalChannel();
                	if(!mAlpha) return;
                	for(Int32 i = 0; i < 128; ++i)
                		for(Int32 j = 0; j < 128; ++j)
                			bm->SetAlphaPixel(mAlpha, i, j, 0);
                	AutoAlloc<GeClipMap> cm;
                	if(!cm) return;
                	cm->Init(bm, mAlpha);
                	BaseContainer mFont;
                	//cm->Init(128, 128, 32);
                	Float mFontSize = cm->GetFont(&mFont);
                	BaseBitmap *mBitmap = cm->GetBitmap();
                	cm->BeginDraw();
                	//cm->SetColor(0, 0, 0, 0);
                	//cm->FillRect(0, 0, 127, 127);
                	cm->SetColor(150, 160, 170, 255);
                	cm->TextAt(4, 4, "Hello World1");
                	cm->EndDraw();
                	Int32 mw = cm->GetBw();
                	Int32 mh = cm->GetBh();
                	DrawBitmap(mBitmap,0,0,mw,mh,0,0,mw,mh,BMP_ALLOWALPHA);
                it draws the text with red background, I want the background to be transparent, what should I do?
                  On 05/05/2015 at 19:09, xxxxxxxx wrote:
                  no one knows if this is a bug or not? the Bitmap should be empty, but for unknown reason it fills the Bitmap with the last pen color, any idea how to solve this?
                    On 05/05/2015 at 22:20, xxxxxxxx wrote:
                    Hi Mohamed,
                    I'm currently at FMX. I'll be looking into this after my return next Monday.
                      On 05/05/2015 at 23:49, xxxxxxxx wrote:
                      I've also experienced this. DrawBitmap() seems to use the last pen
                      color instead of mixing alpha pixels with the pixels that are already on
                      the GeUserArea.
                        On 06/05/2015 at 06:48, xxxxxxxx wrote:
                        No need for the explicit additional bitmap and alpha channel allocation.
                        You can set the transparency value with SetColor(r,g,b,a).
                        i.e. cm->SetColor(r,g,b,128) will give a half transparent output.
                        hth
                          On 06/05/2015 at 13:46, xxxxxxxx wrote:
                          yea Samir, but it remains with an unavoidable bug!! , background is not transparent.
                            On 07/05/2015 at 03:34, xxxxxxxx wrote:
                            I can't confirm. It works. Here is the code:
                            OffScreenOn();
                                	Int32 w = 100;
                                	Int32 h = 100;
                                	AutoAlloc<GeClipMap> bmp;
                                	bmp->Init(w,h,32);
                                	bmp->BeginDraw();
                                	bmp->SetDrawMode(GE_CM_DRAWMODE_COPY,255);
                                	bmp->SetColor(255,255,255,0); //Fully transparent
                                	bmp->FillRect(0,0,w,h); //Set the whole bitmap transparent
                                	bmp->SetColor(255,255,255,128); //50% transparent
                                	bmp->TextAt(10,10,"Katachi rocks.. :-D"); //Draw text
                                	bmp->EndDraw();
                                	DrawBitmap(bmp->GetBitmap(),0,0,w,h,0,0,w,h,BMP_ALLOWALPHA);
                              On 07/05/2015 at 06:43, xxxxxxxx wrote:
                              Hi Samir,
                              try to add DrawSetPen(Vector(0.8, 0.2, 0.2)); "or any other color" after OffScreenOn(); and you will find the bug, I tested your code and the same problem appears.
                                On 07/05/2015 at 10:23, xxxxxxxx wrote:
                                Then don't. Why are you using DrawSetPen?
                                  On 07/05/2015 at 14:23, xxxxxxxx wrote:
                                  drawing other stuff prior to texts, should I draw everything in one clipmap? not sure about performance, I will test, it may worth a shot!!
                                    On 08/05/2015 at 01:19, xxxxxxxx wrote:
                                    yes, if you don't have a good reason, you should stay with the clip map drawing functions.
                                      On 16/05/2015 at 21:26, xxxxxxxx wrote:
                                      after using GeClipMap in all drawings it worked perfectly , thanks all for the help, you can mark this as solved
