    Transparent material in editor view
    16 Posts 0 Posters 2.0k Views
      On 25/08/2016 at 00:13, xxxxxxxx wrote:
      since R17 there is MaterialData::HasEditorTransparency() that has to be implemented to inform the editor if the material uses transparency.
        On 25/08/2016 at 08:14, xxxxxxxx wrote:
        Hi Sebastian,
        Many thanks!
        Renato
          On 25/08/2016 at 19:09, xxxxxxxx wrote:
          Hi Sebastian,
          it work but... when i register my materialdata with PLUGINFLAG_MATERIAL_GLIMAGE_WITH_ALPHA, the InitGlImage() is constantly called even i do nothing in the material or in the editor.
          Do you have any idea about that?
          Thanks 🙂
          Renato
            On 25/08/2016 at 23:40, xxxxxxxx wrote:
            off the top of my head I have no idea. Could you open a new thread on the topic with the relevant sections of your source code?
              On 26/08/2016 at 04:57, xxxxxxxx wrote:
              Hi Sebastian,
              I found why, is my problem.
              Renato
                On 06/09/2016 at 03:13, xxxxxxxx wrote:
                I have same issue. Constantly called InitGlImage() with this flag. How could you sorted the issue?
                Best,
                Ahmet
                  On 07/09/2016 at 05:14, xxxxxxxx wrote:
                  Hi, in my case was a setdirty() . was not dependent from the PLUGINFLAG_MATERIAL_GLIMAGE_WITH_ALPHA.
                  I'm sorry
                    On 08/09/2016 at 09:03, xxxxxxxx wrote:
                    it seems that currently (R18 SP1) there is some bug with the PLUGINFLAG_MATERIAL_GLIMAGE_WITH_ALPHA flag. This should be fixed for the next service pack.
                      On 08/09/2016 at 10:02, xxxxxxxx wrote:
                      Thanks a lot 🙂
                        On 18/11/2016 at 08:55, xxxxxxxx wrote:
                        Hi!
                        Is this fixed somehow with new service packs?
