    Transparent material in editor view
    16 Posts 0 Posters 1.8k Views
      On 17/04/2015 at 05:50, xxxxxxxx wrote:
      Hi Sebastian,
      thanks for answer. I look forward for any update, in the meantime, I will try to find some workaround 🙂
        On 24/08/2016 at 18:37, xxxxxxxx wrote:
        Hi, Did you find something about that?
        Thanks 🙂
        Renato T.
          On 25/08/2016 at 00:13, xxxxxxxx wrote:
          since R17 there is MaterialData::HasEditorTransparency() that has to be implemented to inform the editor if the material uses transparency.
            On 25/08/2016 at 08:14, xxxxxxxx wrote:
            Hi Sebastian,
            Many thanks!
            Renato
              On 25/08/2016 at 19:09, xxxxxxxx wrote:
              Hi Sebastian,
              it work but... when i register my materialdata with PLUGINFLAG_MATERIAL_GLIMAGE_WITH_ALPHA, the InitGlImage() is constantly called even i do nothing in the material or in the editor.
              Do you have any idea about that?
              Thanks 🙂
              Renato
                On 25/08/2016 at 23:40, xxxxxxxx wrote:
                off the top of my head I have no idea. Could you open a new thread on the topic with the relevant sections of your source code?
                  On 26/08/2016 at 04:57, xxxxxxxx wrote:
                  Hi Sebastian,
                  I found why, is my problem.
                  Renato
                    On 06/09/2016 at 03:13, xxxxxxxx wrote:
                    I have same issue. Constantly called InitGlImage() with this flag. How could you sorted the issue?
                    Best,
                    Ahmet
                      On 07/09/2016 at 05:14, xxxxxxxx wrote:
                      Hi, in my case was a setdirty() . was not dependent from the PLUGINFLAG_MATERIAL_GLIMAGE_WITH_ALPHA.
                      I'm sorry
                        On 08/09/2016 at 09:03, xxxxxxxx wrote:
                        it seems that currently (R18 SP1) there is some bug with the PLUGINFLAG_MATERIAL_GLIMAGE_WITH_ALPHA flag. This should be fixed for the next service pack.
                          On 08/09/2016 at 10:02, xxxxxxxx wrote:
                          Thanks a lot 🙂
                            On 18/11/2016 at 08:55, xxxxxxxx wrote:
                            Hi!
                            Is this fixed somehow with new service packs?
