    Transparent material in editor view
    16 Posts 0 Posters 2.0k Views
      On 16/04/2015 at 10:30, xxxxxxxx wrote:
      Ok, so I have another update. I noticed once I add some object with standard C4D material with enabled transparency, all transparent objects (including those using my material) displays correctly. If I remove the c4d material (or turn off transparency in view panel settings), it starts drawing objects in the wrong order again. So I guess I need to enable "something" in C4D to draw transparenct objects correctly...
      So, does anybody know what is to be called / enabled?
        On 17/04/2015 at 02:15, xxxxxxxx wrote:
        sorry for the late answer. We talked with the developers about this and indeed this is currently a bug in the MaterialData class. We hope to fix this soon so custom materials will work properly.
          On 17/04/2015 at 05:50, xxxxxxxx wrote:
          Hiย Sebastian,
          thanks for answer. I look forward for any update, in the meantime, I will try to find some workaround ๐Ÿ™‚
            On 24/08/2016 at 18:37, xxxxxxxx wrote:
            Hi, Did you find something about that?
            Thanks ๐Ÿ™‚
            Renato T.
              On 25/08/2016 at 00:13, xxxxxxxx wrote:
              since R17 there is MaterialData::HasEditorTransparency() that has to be implemented to inform the editor if the material uses transparency.
                On 25/08/2016 at 08:14, xxxxxxxx wrote:
                Hi Sebastian,
                Many thanks!
                Renato
                  On 25/08/2016 at 19:09, xxxxxxxx wrote:
                  Hi Sebastian,
                  it work but... when i register my materialdata with PLUGINFLAG_MATERIAL_GLIMAGE_WITH_ALPHA, the InitGlImage() is constantly called even i do nothing in the material or in the editor.
                  Do you have any idea about that?
                  Thanks ๐Ÿ™‚
                  Renato
                    On 25/08/2016 at 23:40, xxxxxxxx wrote:
                    off the top of my head I have no idea. Could you open a new thread on the topic with the relevant sections of your source code?
                      On 26/08/2016 at 04:57, xxxxxxxx wrote:
                      Hi Sebastian,
                      I found why, is my problem.
                      Renato
                        On 06/09/2016 at 03:13, xxxxxxxx wrote:
                        I have same issue. Constantly called InitGlImage() with this flag. How could you sorted the issue?
                        Best,
                        Ahmet
                          On 07/09/2016 at 05:14, xxxxxxxx wrote:
                          Hi, in my case was a setdirty() . was not dependent from the PLUGINFLAG_MATERIAL_GLIMAGE_WITH_ALPHA.
                          I'm sorry
                            On 08/09/2016 at 09:03, xxxxxxxx wrote:
                            it seems that currently (R18 SP1) there is some bug with the PLUGINFLAG_MATERIAL_GLIMAGE_WITH_ALPHA flag. This should be fixed for the next service pack.
                              On 08/09/2016 at 10:02, xxxxxxxx wrote:
                              Thanks a lot ๐Ÿ™‚
                                On 18/11/2016 at 08:55, xxxxxxxx wrote:
                                Hi!
                                Is this fixed somehow with new service packs?
