    Multiple SubDialogs
    24 Posts 0 Posters 15.4k Views
      On 07/04/2014 at 11:19, xxxxxxxx wrote:
      Thanks for the help guys, however I still have a few problems. Using Kiklas' method I got the SubDialogs to behave correctly when I re-open them while they are open and the window becomes active. I still get a Plugin not found while restoring a layout, I think this reason is due to having more than one sub dialog.
      here is the code:
      def Restore(self, PLUGIN_ID, secref) :
           if secref['subid'] == 1:
                return self.sub_dialog1.Restore(PLUGIN_ID,secref)
           elif secref['subid'] == 2:
                return self.sub_dialog2.Restore(PLUGIN_ID,secref)
                return super(MainDialog, self).Restore(PLUGIN_ID,secref)
      How do I correctly look for both subdialogs.
        On 07/04/2014 at 11:23, xxxxxxxx wrote:
        How do you open the subdialogs?
          On 07/04/2014 at 11:26, xxxxxxxx wrote:
          if id == 10017: # Get Render Time
               self.sub_dialog2.Open(c4d.DLG_TYPE_ASYNC, defaulth=200, defaultw=300, subid = 2)
          Oh wait, I think I just figured it out, This has to have the plugin ID as well correct?
            On 07/04/2014 at 11:41, xxxxxxxx wrote:
            No that did not work. Here is what my @properties look like
            @property
            def sub_dialog1(self) :
                 if not hasattr(self, '_sub_dialog1') :
                      self._sub_dialog1 = ColorDialog()
                 return self._sub_dialog1
            @property
            def sub_dialog2(self) :
                 if not hasattr(self, '_sub_dialog2') :
                      self._sub_dialog2 = RenderTimeDialog()
                 return self._sub_dialog2
              On 07/04/2014 at 11:58, xxxxxxxx wrote:
              Here is the code from your exaple made to have 2 sub dialogs: Same problem.
              PLUGIN_ID = 1000004 # Test ID
              class MainDialog(c4d.gui.GeDialog) :
                  # Do not create the object on class-level, although it might
                  # be unimportant since you do not open multiple objects of your
                  # MainDialog, it is contradicting to have one instance of sub
                  # dialog for all instances of the main dialog.
                  # A property that creates the dialog on-demand is perfect for
                  # this purpose.
                  @property
                  def sub_dialog(self) :
                      if not hasattr(self, '_sub_dialog') :
                          self._sub_dialog = SubDialog()
                  @property
                          self._sub_dialog2 = SubDialog2()
                  # c4d.gui.GeDialog
                  def CreateLayout(self) :
                      self.SetTitle('Main Dialog')
                      self.AddButton(1000, 0, name="Open Sub-Dialog")
                  def Command(self, param, bc) :
                      if param == 1000:
                          self.sub_dialog.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=1)
                          self.sub_dialog2.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=2)
                  def Restore(self, pluginid, secref) :
                      # We override this method so we don't have to handle the sub-
                      # dialog from the CommandData plugin. THIS dialog is responsible
                      # for the sub-dialog, do not split such management throughout
                      # your program or it gets confusing.
                          return self.sub_dialog.Restore(pluginid, secref)
                          return self.sub_dialog2.Restore(pluginid, secref)
                          return super(MainDialog, self).Restore(pluginid, secref)
              class SubDialog(c4d.gui.GeDialog) :
                      self.SetTitle('Sub-Dialog')
                      self.AddStaticText(1000, 0, name="This is the sub-dialog.")
              class SubDialog2(c4d.gui.GeDialog) :
                      self.SetTitle('Sub-Dialog2')
                      self.AddStaticText(1000, 0, name="This is the sub-dialog2.")
              class Command(c4d.plugins.CommandData) :
                  def Register(self) :
                      return c4d.plugins.RegisterCommandPlugin(
                              PLUGIN_ID, "Sub-Dialog Docking Test", 0, None, "", self)
                  @property
                  def dialog(self) :
                      if not hasattr(self, '_dialog') :
                          self._dialog = MainDialog()
                      return self._dialog
                  # c4d.plugins.CommandData
                  def Execute(self, doc) :
                      return self.dialog.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID)
                  def RestoreLayout(self, secref) :
                      return self.dialog.Restore(PLUGIN_ID, secref)
                  Command().Register()
                On 07/04/2014 at 13:45, xxxxxxxx wrote:
                OK I got the example to work.
                however I cannot get my plugin to work. could it be that my main window uses a .res file?
                    # this purpose.
                    @property
                    @property
                    # c4d.gui.GeDialog
                        if param == 1000:
                            print "yes"
                    @property
                    def dialog(self) :
                        return self._dialog
                  On 08/04/2014 at 14:11, xxxxxxxx wrote:
                  I think the problem with my plugin has something to do with the main command class, the "RestoreLayout" does not get called at all. I added some print functions to see and nothing. However the example prints just fine. Here is my main command code:
                  class RenderBuddy(c4d.plugins.CommandData) :
                      @property
                      def RBdialog(self) :
                          if not hasattr(self, '_RBdialog') :
                              self._RBdialog = BuddyDialog()
                          return self._RBdialog
                          return c4d.plugins.RegisterCommandPlugin(PLUGIN_ID, "Render Buddy (Beta)",0, bmp, "", self)
                          return self.RBdialog.Open(c4d.DLG_TYPE_ASYNC,PLUGIN_ID)
                      def RestorLayout(self, secref) :
                          print "RB_Main"
                          return self.RBdialog.Restore(PLUGIN_ID, secref)
                      path, fn = os.path.split(__file__)
                      bmp = bitmaps.BaseBitmap()
                      bmp.InitWith(os.path.join(path, "res/icons/", "icon.tif"))
                      RenderBuddy().Register()
                  Everything seems to be right, but the RestoreLayout does not get called.
                    On 08/04/2014 at 14:14, xxxxxxxx wrote:
                    Figured it out! After typing it out above I realized RestoreLayout() was misspelled. Thank you guys for all the help!
                    *Edit there is a new problem the setup:
                                print "Color"
                                return self.RB_ColorDLG.Restore(pluginid,secref)
                                print "Temp"
                                return self.RB_TempDLG.Restore(pluginid,secref)
                                print "Main"
                                return super(BuddyDialog, self).Restore(pluginid,secref)
                    This causes cinema to crash. I will restore the layout but if you launch the sub dialog again everything locks up. This happens with the Example as well. Confused
                      On 08/04/2014 at 16:01, xxxxxxxx wrote:
                      Hi Shawn, I can reproduce the problems you have described. The Example I posted worked though,
                      but funnily broke after a few more times testing it. I'll have to talk to a developer on this, I am pretty
                      sure this is a bug. Especially this message is
                        File "'restore-sub-dialog.pyp'", line 57, in CreateLayout
                      SystemError: error return without exception set
                      Best,
                      -Niklas
                        On 08/04/2014 at 16:19, xxxxxxxx wrote:
                        Thank you Niklas.
                        -Shawn
                          On 08/04/2014 at 19:28, xxxxxxxx wrote:
                          It seems to work just fine for me. No errors or problems at all.
                          Maybe you're trying to do something different than I'm doing?
                          Here is a complete example that works fine for me in R13.
                          Save it as a .pyp file and put it in your plugins folder.
                          The main dialog has buttons to open two other dialogs. And a button that will change the checkbox gizmo in dilaog1.
                          All three dialogs can be docked into the UI and saved in a custom layout.
                          #This is an example of a GeDialog plugin that opens three dialogs
                          #It also allows all three dialogs to be docked and saved in a custom layout
                          import c4d, os
                          from c4d import gui, plugins, bitmaps
                          PLUGIN_ID  = 1000004 #Testing ID
                          SUBDLG_ID1  = 1000005 #Testing ID
                          SUBDLG_ID2 = 1000006 #Testing ID
                          MAINDLG_BUTTON1_ID = 1000
                          MAINDLG_BUTTON2_ID = 1001
                          MAINDLG_BUTTON3_ID = 1002
                          SUBDLG_TEXT_ID     = 1003
                          SUBDLG_CHKBOX_ID   = 1004
                          SUBDLG_RESET_ID    = 1005
                          #The first sub dialog
                          class SubDialog1(c4d.gui.GeDialog) :
                                self.SetTitle('Sub-Dialog1')
                                self.GroupBeginInMenuLine()
                                self.AddCheckbox(SUBDLG_RESET_ID, c4d.BFH_RIGHT, 100, 20, name="Reset")
                                self.GroupEnd()
                                self.GroupBegin(0, c4d.BFH_SCALEFIT, 2, 0, "MyGroup")
                                self.GroupBorderSpace(5, 5, 5, 5)
                                self.GroupBorder(c4d.BORDER_BLACK)
                                self.AddStaticText(SUBDLG_TEXT_ID, c4d.BFH_LEFT, 200, 20, "This is the sub-dialog1")
                                self.AddCheckbox(SUBDLG_CHKBOX_ID, c4d.BFH_LEFT, 20, 20, "myChkbox")
                                self.GroupEnd()
                            def Command(self, id, msg) :
                                if id == SUBDLG_RESET_ID:
                                    self.SetBool(SUBDLG_CHKBOX_ID, False)
                                    self.SetBool(SUBDLG_RESET_ID, False)
                          #The second sub dialog
                                self.GroupEnd()
                                self.AddStaticText(SUBDLG_TEXT_ID, c4d.BFH_LEFT, 200, 20, "This is the sub-dialog2")
                                self.GroupEnd()
                          #The main dialog
                            sub_dialog1 = SubDialog1()
                                self.AddButton(MAINDLG_BUTTON1_ID, 0, name="Open Sub-Dialog1")
                                self.AddButton(MAINDLG_BUTTON2_ID, 0, name="Open Sub-Dialog2")
                                self.AddButton(MAINDLG_BUTTON3_ID, 0, name="Change Sub-Dialog1")
                                if id == MAINDLG_BUTTON1_ID:
                                    self.sub_dialog1.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=SUBDLG_ID1)
                                if id == MAINDLG_BUTTON2_ID:
                                    self.sub_dialog2.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=SUBDLG_ID2)
                                if id == MAINDLG_BUTTON3_ID:
                                    self.sub_dialog1.SetBool(SUBDLG_CHKBOX_ID, True)
                            #Restore the subdialog and the main dialog in the layout
                                if secref['subid'] == SUBDLG_ID1:
                                    return self.sub_dialog1.Restore(pluginid, secref)
                                if secref['subid'] == SUBDLG_ID2:
                          #The Command Data section
                          class MainDialog_CD(c4d.plugins.CommandData) :
                            @property
                            def dialog(self) :
                                return self._dialog
                            fn = os.path.join(dir, "res", "icon.png")
                            bmp.InitWith(fn)
                            plugins.RegisterCommandPlugin(PLUGIN_ID, "Sub-Dialog Docking",0, bmp, "re-open", MainDialog_CD())
