    Multiple SubDialogs
    24 Posts 0 Posters 16.4k Views
      On 07/04/2014 at 11:23, xxxxxxxx wrote:
      How do you open the subdialogs?
        On 07/04/2014 at 11:26, xxxxxxxx wrote:
        if id == 10017: # Get Render Time
             self.sub_dialog2.Open(c4d.DLG_TYPE_ASYNC, defaulth=200, defaultw=300, subid = 2)
        Oh wait, I think I just figured it out, This has to have the plugin ID as well correct?
          On 07/04/2014 at 11:41, xxxxxxxx wrote:
          No that did not work. Here is what my @properties look like
          @property
          def sub_dialog1(self) :
               if not hasattr(self, '_sub_dialog1') :
                    self._sub_dialog1 = ColorDialog()
               return self._sub_dialog1
          @property
          def sub_dialog2(self) :
               if not hasattr(self, '_sub_dialog2') :
                    self._sub_dialog2 = RenderTimeDialog()
               return self._sub_dialog2
            On 07/04/2014 at 11:58, xxxxxxxx wrote:
            Here is the code from your exaple made to have 2 sub dialogs: Same problem.
            PLUGIN_ID = 1000004 # Test ID
            class MainDialog(c4d.gui.GeDialog) :
                # Do not create the object on class-level, although it might
                # be unimportant since you do not open multiple objects of your
                # MainDialog, it is contradicting to have one instance of sub
                # dialog for all instances of the main dialog.
                # A property that creates the dialog on-demand is perfect for
                # this purpose.
                @property
                def sub_dialog(self) :
                    if not hasattr(self, '_sub_dialog') :
                        self._sub_dialog = SubDialog()
                @property
                        self._sub_dialog2 = SubDialog2()
                # c4d.gui.GeDialog
                def CreateLayout(self) :
                    self.SetTitle('Main Dialog')
                    self.AddButton(1000, 0, name="Open Sub-Dialog")
                def Command(self, param, bc) :
                    if param == 1000:
                        self.sub_dialog.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=1)
                        self.sub_dialog2.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=2)
                def Restore(self, pluginid, secref) :
                    # We override this method so we don't have to handle the sub-
                    # dialog from the CommandData plugin. THIS dialog is responsible
                    # for the sub-dialog, do not split such management throughout
                    # your program or it gets confusing.
                    if secref['subid'] == 1:
                        return self.sub_dialog.Restore(pluginid, secref)
                    elif secref['subid'] == 2:
                        return self.sub_dialog2.Restore(pluginid, secref)
                        return super(MainDialog, self).Restore(pluginid, secref)
            class SubDialog(c4d.gui.GeDialog) :
                    self.SetTitle('Sub-Dialog')
                    self.AddStaticText(1000, 0, name="This is the sub-dialog.")
            class SubDialog2(c4d.gui.GeDialog) :
                    self.SetTitle('Sub-Dialog2')
                    self.AddStaticText(1000, 0, name="This is the sub-dialog2.")
            class Command(c4d.plugins.CommandData) :
                def Register(self) :
                    return c4d.plugins.RegisterCommandPlugin(
                            PLUGIN_ID, "Sub-Dialog Docking Test", 0, None, "", self)
                @property
                def dialog(self) :
                    if not hasattr(self, '_dialog') :
                        self._dialog = MainDialog()
                    return self._dialog
                # c4d.plugins.CommandData
                def Execute(self, doc) :
                    return self.dialog.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID)
                def RestoreLayout(self, secref) :
                    return self.dialog.Restore(PLUGIN_ID, secref)
                Command().Register()
              On 07/04/2014 at 13:45, xxxxxxxx wrote:
              OK I got the example to work.
              however I cannot get my plugin to work. could it be that my main window uses a .res file?
                  # this purpose.
                  @property
                  @property
                  # c4d.gui.GeDialog
                      if param == 1000:
                          print "yes"
                  @property
                  def dialog(self) :
                      return self._dialog
                On 08/04/2014 at 14:11, xxxxxxxx wrote:
                I think the problem with my plugin has something to do with the main command class, the "RestoreLayout" does not get called at all. I added some print functions to see and nothing. However the example prints just fine. Here is my main command code:
                class RenderBuddy(c4d.plugins.CommandData) :
                    @property
                    def RBdialog(self) :
                        if not hasattr(self, '_RBdialog') :
                            self._RBdialog = BuddyDialog()
                        return self._RBdialog
                        return c4d.plugins.RegisterCommandPlugin(PLUGIN_ID, "Render Buddy (Beta)",0, bmp, "", self)
                        return self.RBdialog.Open(c4d.DLG_TYPE_ASYNC,PLUGIN_ID)
                    def RestorLayout(self, secref) :
                        print "RB_Main"
                        return self.RBdialog.Restore(PLUGIN_ID, secref)
                    path, fn = os.path.split(__file__)
                    bmp = bitmaps.BaseBitmap()
                    bmp.InitWith(os.path.join(path, "res/icons/", "icon.tif"))
                    RenderBuddy().Register()
                Everything seems to be right, but the RestoreLayout does not get called.
                  On 08/04/2014 at 14:14, xxxxxxxx wrote:
                  Figured it out! After typing it out above I realized RestoreLayout() was misspelled. Thank you guys for all the help!
                  *Edit there is a new problem the setup:
                              print "Color"
                              return self.RB_ColorDLG.Restore(pluginid,secref)
                              print "Temp"
                              return self.RB_TempDLG.Restore(pluginid,secref)
                              print "Main"
                              return super(BuddyDialog, self).Restore(pluginid,secref)
                  This causes cinema to crash. I will restore the layout but if you launch the sub dialog again everything locks up. This happens with the Example as well. Confused
                    On 08/04/2014 at 16:01, xxxxxxxx wrote:
                    Hi Shawn, I can reproduce the problems you have described. The Example I posted worked though,
                    but funnily broke after a few more times testing it. I'll have to talk to a developer on this, I am pretty
                    sure this is a bug. Especially this message is
                      File "'restore-sub-dialog.pyp'", line 57, in CreateLayout
                    SystemError: error return without exception set
                    Best,
                    -Niklas
                      On 08/04/2014 at 16:19, xxxxxxxx wrote:
                      Thank you Niklas.
                      -Shawn
                        On 08/04/2014 at 19:28, xxxxxxxx wrote:
                        It seems to work just fine for me. No errors or problems at all.
                        Maybe you're trying to do something different than I'm doing?
                        Here is a complete example that works fine for me in R13.
                        Save it as a .pyp file and put it in your plugins folder.
                        The main dialog has buttons to open two other dialogs. And a button that will change the checkbox gizmo in dilaog1.
                        All three dialogs can be docked into the UI and saved in a custom layout.
                        #This is an example of a GeDialog plugin that opens three dialogs
                        #It also allows all three dialogs to be docked and saved in a custom layout
                        import c4d, os
                        from c4d import gui, plugins, bitmaps
                        PLUGIN_ID  = 1000004 #Testing ID
                        SUBDLG_ID1  = 1000005 #Testing ID
                        SUBDLG_ID2 = 1000006 #Testing ID
                        MAINDLG_BUTTON1_ID = 1000
                        MAINDLG_BUTTON2_ID = 1001
                        MAINDLG_BUTTON3_ID = 1002
                        SUBDLG_TEXT_ID     = 1003
                        SUBDLG_CHKBOX_ID   = 1004
                        SUBDLG_RESET_ID    = 1005
                        #The first sub dialog
                        class SubDialog1(c4d.gui.GeDialog) :
                              self.SetTitle('Sub-Dialog1')
                              self.GroupBeginInMenuLine()
                              self.AddCheckbox(SUBDLG_RESET_ID, c4d.BFH_RIGHT, 100, 20, name="Reset")
                              self.GroupEnd()
                              self.GroupBegin(0, c4d.BFH_SCALEFIT, 2, 0, "MyGroup")
                              self.GroupBorderSpace(5, 5, 5, 5)
                              self.GroupBorder(c4d.BORDER_BLACK)
                              self.AddStaticText(SUBDLG_TEXT_ID, c4d.BFH_LEFT, 200, 20, "This is the sub-dialog1")
                              self.AddCheckbox(SUBDLG_CHKBOX_ID, c4d.BFH_LEFT, 20, 20, "myChkbox")
                              self.GroupEnd()
                          def Command(self, id, msg) :
                              if id == SUBDLG_RESET_ID:
                                  self.SetBool(SUBDLG_CHKBOX_ID, False)
                                  self.SetBool(SUBDLG_RESET_ID, False)
                        #The second sub dialog
                              self.GroupEnd()
                              self.AddStaticText(SUBDLG_TEXT_ID, c4d.BFH_LEFT, 200, 20, "This is the sub-dialog2")
                              self.GroupEnd()
                        #The main dialog
                          sub_dialog1 = SubDialog1()
                              self.AddButton(MAINDLG_BUTTON1_ID, 0, name="Open Sub-Dialog1")
                              self.AddButton(MAINDLG_BUTTON2_ID, 0, name="Open Sub-Dialog2")
                              self.AddButton(MAINDLG_BUTTON3_ID, 0, name="Change Sub-Dialog1")
                              if id == MAINDLG_BUTTON1_ID:
                                  self.sub_dialog1.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=SUBDLG_ID1)
                              if id == MAINDLG_BUTTON2_ID:
                                  self.sub_dialog2.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=SUBDLG_ID2)
                              if id == MAINDLG_BUTTON3_ID:
                                  self.sub_dialog1.SetBool(SUBDLG_CHKBOX_ID, True)
                          #Restore the subdialog and the main dialog in the layout
                              if secref['subid'] == SUBDLG_ID1:
                                  return self.sub_dialog1.Restore(pluginid, secref)
                              if secref['subid'] == SUBDLG_ID2:
                        #The Command Data section
                        class MainDialog_CD(c4d.plugins.CommandData) :
                          @property
                          def dialog(self) :
                              return self._dialog
                          fn = os.path.join(dir, "res", "icon.png")
                          bmp.InitWith(fn)
                          plugins.RegisterCommandPlugin(PLUGIN_ID, "Sub-Dialog Docking",0, bmp, "re-open", MainDialog_CD())
