    Multiple SubDialogs
    24 Posts 0 Posters 16.1k Views
      On 04/04/2014 at 08:47, xxxxxxxx wrote:
      Thanks for the help Niklas,
      I realized I was calling my subdialogs by the same name, so opening one killed the other.
      This is how I am calling the main dialog/window:
      return self.dialog.Restore(pluginid = PLUGIN_ID, secret = sec_ref)
      How do I use the "secret" to restore the submenus? I can't seen to find any information about that parameter.
        On 04/04/2014 at 09:35, xxxxxxxx wrote:
        This is the best information I have found so far but I cant seam to convert it to python correctly.
        https://developers.maxon.net/forum/topic/1393/732_subid-for-dialogs&OB=ASC
        When I save my layout they plugin windows go blank.
          On 04/04/2014 at 12:24, xxxxxxxx wrote:
          Try print the "secret". It's no longer cryptic when you see its actually a dictionary.
          -Niklas
            On 04/04/2014 at 13:01, xxxxxxxx wrote:
            I think I am confusing myself. The fact that this attribute is called "secret" makes it impossible to search for with Google.
            I tried to print the attribute but of course the secret is not defined. (I am pretty sure I am going about this the wrong way.) Do you know where I can find an example of a python plugin consisting of 2 or more windows?
              On 04/04/2014 at 14:48, xxxxxxxx wrote:
              Sorry, the C++ docs refer to it as "secret", but the Python docs say "sec_ref". I was talking about this parameter, it is the only one passed to RestoreLayout() besides "self".
              print sec_ref
              {'subid': 0, 'ptr': <PYCObject ...>}
              See? Theres the subid.
              -Niklas
                On 05/04/2014 at 10:12, xxxxxxxx wrote:
                I'm interested in knowing the answer to this one too.
                Since it's much easier to communicate using a working example. Here's a very basic working example showing the problem of not being able to dock a sub dialog:
                import c4d,os,sys
                from c4d import gui, plugins, bitmaps, documents, utils
                PLUGIN_ID = 1000003    #The plugin's ID#
                MAINDLG   = 1000040    #An ID to be assigned to the main dialog
                SUBDLG    = 1000041    #An ID to be assigned to the sub dialog
                ###### The sub dialog ######
                class MySubDialog(gui.GeDialog) :
                  def CreateLayout(self) :
                      self.SetTitle("Sub Dialog")
                      self.GroupBegin(0, c4d.BFH_SCALEFIT, 2, 0, "MyGroup")
                      self.GroupBorderSpace(5, 5, 5, 5)
                      self.GroupBorder(c4d.BORDER_BLACK)
                      self.AddStaticText(1111, c4d.BFH_LEFT, 0, 0, "Hello World", 0)
                      self.AddEditSlider(2222, c4d.BFH_SCALEFIT, 500, 0)
                      self.GroupEnd()
                  def InitValues(self) :
                      self.SetReal(id = 2222, value = 5.0, min = 0.0, max = 100.0, step = 1.0, format = c4d.FORMAT_METER)
                  def Command(self, id, msg) :
                      if (id == 2222) :
                          print self.GetReal(2222)   #Print the value of the slider
                ###### The main dialog ######
                class MyMainDialog(gui.GeDialog) :
                  subdlg = MySubDialog()
                      self.SetTitle("Main Dialog")
                      self.AddButton(10001, c4d.BFH_CENTER, 150, 0, "Open SubDlg")
                      if (id == 10001) :
                          self.subdlg.Open(dlgtype = c4d.DLG_TYPE_ASYNC, pluginid = SUBDLG, defaultw = 200, defaulth = 100)
                class Dialog_CD(c4d.plugins.CommandData) :
                  mainDialog = None
                  subDialog = None
                  def Init(self, op) :
                  def Execute(self, doc) :
                      if self.mainDialog is None and self.subDialog is None:
                          self.mainDialog = MyMainDialog()
                          self.subDialog = MySubDialog()
                      self.mainDialog.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, -1, -1, 0, 0, MAINDLG)
                      #self.subDialog.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, -1, -1, 0, 0, SUBDLG)  #For reference only...We don't want to open both dialogs here
                ##### This does not work!!!! ########
                #The function stops after it finds the mainDialog. And only restores that dialog!!!
                #The sub dialog results in "plugin not found" in the layout!!!
                  def RestoreLayout(self, sec_ref) :
                      subid = sec_ref["subid"]
                      object = sec_ref["ptr"]
                      if self.mainDialog is None:
                          print subid
                          if subid == MAINDLG:
                              print "subid == MAINDLG"
                              self.mainDialog.Restore(MAINDLG, sec_ref)
                      if self.subDialog is None:
                          print subid
                          if subid == SUBDLG:
                              print "subid == SUBDLG"
                              self.subDialog.Restore(SUBDLG, sec_ref)
                  fn = os.path.join(dir, "res", "icon.tif")
                  bmp.InitWith(fn)
                  result = plugins.RegisterCommandPlugin(PLUGIN_ID, "Dockable SubDialogs", 0, bmp, "Dockable SubDialogs", Dialog_CD())
                  On 06/04/2014 at 09:29, xxxxxxxx wrote:
                  here is an example similar to yours that demonstrates how you can easily restore even sub-dialogs.
                  It also demonstrates a few techniques that are good practice and useful.
                  One big problem of your code, for instance, was that, if restoring the sub dialog would have
                  worked, pressing the button on the main dialog would've opened another dialog than the one
                  that was restored into the layout.
                  Also,
                  a) the subid does not need to be a plugin ID
                  b) for GeDialog.Restore(), the first argument must be the command plugins PLUGIN_ID,
                  same when opening the main and sub dialog.
                  The reason it didn't restore is that the first time RestoreLayout() was called, you create the
                  sub-dialog, but the second time, the block that forwards the restoring to the sub-dialog isn't
                  even executed because of
                  if self.subDialog is None:  # False in the second call
                  Best,
                  -Niklas
                  PLUGIN_ID = 1000004 # Test ID
                  class MainDialog(c4d.gui.GeDialog) :
                      # Do not create the object on class-level, although it might
                      # be unimportant since you do not open multiple objects of your
                      # MainDialog, it is contradicting to have one instance of sub
                      # dialog for all instances of the main dialog.
                      # A property that creates the dialog on-demand is perfect for
                      # this purpose.
                      @property
                      def sub_dialog(self) :
                          if not hasattr(self, '_sub_dialog') :
                              self._sub_dialog = SubDialog()
                          return self._sub_dialog
                      # c4d.gui.GeDialog
                          self.SetTitle('Main Dialog')
                          self.AddButton(1000, 0, name="Open Sub-Dialog")
                      def Command(self, param, bc) :
                          if param == 1000:
                              self.sub_dialog.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=1)
                      def Restore(self, pluginid, secref) :
                          # We override this method so we don't have to handle the sub-
                          # dialog from the CommandData plugin. THIS dialog is responsible
                          # for the sub-dialog, do not split such management throughout
                          # your program or it gets confusing.
                          if secref['subid'] == 1:
                              return self.sub_dialog.Restore(pluginid, secref)
                              return super(MainDialog, self).Restore(pluginid, secref)
                  class SubDialog(c4d.gui.GeDialog) :
                      # c4d.gui.GeDialog
                          self.SetTitle('Sub-Dialog')
                          self.AddStaticText(1000, 0, name="This is the sub-dialog.")
                  class Command(c4d.plugins.CommandData) :
                      def Register(self) :
                          return c4d.plugins.RegisterCommandPlugin(
                                  PLUGIN_ID, "Sub-Dialog Docking Test", 0, None, "", self)
                      @property
                      def dialog(self) :
                          if not hasattr(self, '_dialog') :
                              self._dialog = MainDialog()
                          return self._dialog
                      # c4d.plugins.CommandData
                          return self.dialog.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID)
                      def RestoreLayout(self, secref) :
                          return self.dialog.Restore(PLUGIN_ID, secref)
                      Command().Register()
                    On 06/04/2014 at 11:24, xxxxxxxx wrote:
                    Thanks Niklas.
                    I never thought about using Restore() in the main GeDialog class like that.
                      On 07/04/2014 at 09:29, xxxxxxxx wrote:
                      You're welcome, Scott.
                      You can also find the code at the GitHub py-cinema4sdk repository under gui/restore-sub-dialog.pyp!
                      Do also take a look at the respective readme file at gui/restore-sub-dialog.md.
                      Best,
                      -Niklas
                        On 07/04/2014 at 11:19, xxxxxxxx wrote:
                        Thanks for the help guys, however I still have a few problems. Using Kiklas' method I got the SubDialogs to behave correctly when I re-open them while they are open and the window becomes active. I still get a Plugin not found while restoring a layout, I think this reason is due to having more than one sub dialog.
                        here is the code:
                        def Restore(self, PLUGIN_ID, secref) :
                                  return self.sub_dialog1.Restore(PLUGIN_ID,secref)
                             elif secref['subid'] == 2:
                                  return self.sub_dialog2.Restore(PLUGIN_ID,secref)
                                  return super(MainDialog, self).Restore(PLUGIN_ID,secref)
                        How do I correctly look for both subdialogs.
                          On 07/04/2014 at 11:23, xxxxxxxx wrote:
                          How do you open the subdialogs?
                            On 07/04/2014 at 11:26, xxxxxxxx wrote:
                            if id == 10017: # Get Render Time
                                 self.sub_dialog2.Open(c4d.DLG_TYPE_ASYNC, defaulth=200, defaultw=300, subid = 2)
                            Oh wait, I think I just figured it out, This has to have the plugin ID as well correct?
                              On 07/04/2014 at 11:41, xxxxxxxx wrote:
                              No that did not work. Here is what my @properties look like
                              @property
                              def sub_dialog1(self) :
                                   if not hasattr(self, '_sub_dialog1') :
                                        self._sub_dialog1 = ColorDialog()
                                   return self._sub_dialog1
                              @property
                              def sub_dialog2(self) :
                                   if not hasattr(self, '_sub_dialog2') :
                                        self._sub_dialog2 = RenderTimeDialog()
                                   return self._sub_dialog2
                                On 07/04/2014 at 11:58, xxxxxxxx wrote:
                                Here is the code from your exaple made to have 2 sub dialogs: Same problem.
                                    # this purpose.
                                    @property
                                    @property
                                            self._sub_dialog2 = SubDialog2()
                                    # c4d.gui.GeDialog
                                        if param == 1000:
                                            self.sub_dialog2.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=2)
                                            return self.sub_dialog2.Restore(pluginid, secref)
                                class SubDialog2(c4d.gui.GeDialog) :
                                        self.SetTitle('Sub-Dialog2')
                                        self.AddStaticText(1000, 0, name="This is the sub-dialog2.")
                                    @property
                                    def dialog(self) :
                                        return self._dialog
                                  On 07/04/2014 at 13:45, xxxxxxxx wrote:
                                  OK I got the example to work.
                                  however I cannot get my plugin to work. could it be that my main window uses a .res file?
                                      # this purpose.
                                      @property
                                      @property
                                      # c4d.gui.GeDialog
                                          if param == 1000:
                                              print "yes"
                                      @property
                                      def dialog(self) :
                                          return self._dialog
                                    On 08/04/2014 at 14:11, xxxxxxxx wrote:
                                    I think the problem with my plugin has something to do with the main command class, the "RestoreLayout" does not get called at all. I added some print functions to see and nothing. However the example prints just fine. Here is my main command code:
                                    class RenderBuddy(c4d.plugins.CommandData) :
                                        @property
                                        def RBdialog(self) :
                                            if not hasattr(self, '_RBdialog') :
                                                self._RBdialog = BuddyDialog()
                                            return self._RBdialog
                                            return c4d.plugins.RegisterCommandPlugin(PLUGIN_ID, "Render Buddy (Beta)",0, bmp, "", self)
                                            return self.RBdialog.Open(c4d.DLG_TYPE_ASYNC,PLUGIN_ID)
                                        def RestorLayout(self, secref) :
                                            print "RB_Main"
                                            return self.RBdialog.Restore(PLUGIN_ID, secref)
                                        path, fn = os.path.split(__file__)
                                        bmp = bitmaps.BaseBitmap()
                                        bmp.InitWith(os.path.join(path, "res/icons/", "icon.tif"))
                                        RenderBuddy().Register()
                                    Everything seems to be right, but the RestoreLayout does not get called.
                                      On 08/04/2014 at 14:14, xxxxxxxx wrote:
                                      Figured it out! After typing it out above I realized RestoreLayout() was misspelled. Thank you guys for all the help!
                                      *Edit there is a new problem the setup:
                                                  print "Color"
                                                  return self.RB_ColorDLG.Restore(pluginid,secref)
                                                  print "Temp"
                                                  return self.RB_TempDLG.Restore(pluginid,secref)
                                                  print "Main"
                                                  return super(BuddyDialog, self).Restore(pluginid,secref)
                                      This causes cinema to crash. I will restore the layout but if you launch the sub dialog again everything locks up. This happens with the Example as well. Confused
                                        On 08/04/2014 at 16:01, xxxxxxxx wrote:
                                        Hi Shawn, I can reproduce the problems you have described. The Example I posted worked though,
                                        but funnily broke after a few more times testing it. I'll have to talk to a developer on this, I am pretty
                                        sure this is a bug. Especially this message is
                                          File "'restore-sub-dialog.pyp'", line 57, in CreateLayout
                                        SystemError: error return without exception set
                                        Best,
                                        -Niklas
                                          On 08/04/2014 at 16:19, xxxxxxxx wrote:
                                          Thank you Niklas.
                                          -Shawn
                                            On 08/04/2014 at 19:28, xxxxxxxx wrote:
                                            It seems to work just fine for me. No errors or problems at all.
                                            Maybe you're trying to do something different than I'm doing?
                                            Here is a complete example that works fine for me in R13.
                                            Save it as a .pyp file and put it in your plugins folder.
                                            The main dialog has buttons to open two other dialogs. And a button that will change the checkbox gizmo in dilaog1.
                                            All three dialogs can be docked into the UI and saved in a custom layout.
                                            #This is an example of a GeDialog plugin that opens three dialogs
                                            #It also allows all three dialogs to be docked and saved in a custom layout
                                            import c4d, os
                                            PLUGIN_ID  = 1000004 #Testing ID
                                            SUBDLG_ID1  = 1000005 #Testing ID
                                            SUBDLG_ID2 = 1000006 #Testing ID
                                            MAINDLG_BUTTON1_ID = 1000
                                            MAINDLG_BUTTON2_ID = 1001
                                            MAINDLG_BUTTON3_ID = 1002
                                            SUBDLG_TEXT_ID     = 1003
                                            SUBDLG_CHKBOX_ID   = 1004
                                            SUBDLG_RESET_ID    = 1005
                                            #The first sub dialog
                                            class SubDialog1(c4d.gui.GeDialog) :
                                                  self.SetTitle('Sub-Dialog1')
                                                  self.GroupBeginInMenuLine()
                                                  self.AddCheckbox(SUBDLG_RESET_ID, c4d.BFH_RIGHT, 100, 20, name="Reset")
                                                  self.GroupEnd()
                                                  self.AddStaticText(SUBDLG_TEXT_ID, c4d.BFH_LEFT, 200, 20, "This is the sub-dialog1")
                                                  self.AddCheckbox(SUBDLG_CHKBOX_ID, c4d.BFH_LEFT, 20, 20, "myChkbox")
                                                  self.GroupEnd()
                                                  if id == SUBDLG_RESET_ID:
                                                      self.SetBool(SUBDLG_CHKBOX_ID, False)
                                                      self.SetBool(SUBDLG_RESET_ID, False)
                                            #The second sub dialog
                                                  self.GroupEnd()
                                                  self.AddStaticText(SUBDLG_TEXT_ID, c4d.BFH_LEFT, 200, 20, "This is the sub-dialog2")
                                                  self.GroupEnd()
                                            #The main dialog
                                              sub_dialog1 = SubDialog1()
                                                  self.AddButton(MAINDLG_BUTTON1_ID, 0, name="Open Sub-Dialog1")
                                                  self.AddButton(MAINDLG_BUTTON2_ID, 0, name="Open Sub-Dialog2")
                                                  self.AddButton(MAINDLG_BUTTON3_ID, 0, name="Change Sub-Dialog1")
                                                  if id == MAINDLG_BUTTON1_ID:
                                                      self.sub_dialog1.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=SUBDLG_ID1)
                                                  if id == MAINDLG_BUTTON2_ID:
                                                      self.sub_dialog2.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=SUBDLG_ID2)
                                                  if id == MAINDLG_BUTTON3_ID:
                                                      self.sub_dialog1.SetBool(SUBDLG_CHKBOX_ID, True)
                                              #Restore the subdialog and the main dialog in the layout
                                                  if secref['subid'] == SUBDLG_ID1:
                                                      return self.sub_dialog1.Restore(pluginid, secref)
                                                  if secref['subid'] == SUBDLG_ID2:
                                            #The Command Data section
                                            class MainDialog_CD(c4d.plugins.CommandData) :
                                              @property
                                              def dialog(self) :
                                                  return self._dialog
                                              fn = os.path.join(dir, "res", "icon.png")
                                              bmp.InitWith(fn)
                                              plugins.RegisterCommandPlugin(PLUGIN_ID, "Sub-Dialog Docking",0, bmp, "re-open", MainDialog_CD())
