    Multiple SubDialogs
    24 Posts 0 Posters 16.8k Views
      On 07/04/2014 at 09:29, xxxxxxxx wrote:
      You're welcome, Scott.
      You can also find the code at the GitHub py-cinema4sdk repository under gui/restore-sub-dialog.pyp!
      Do also take a look at the respective readme file at gui/restore-sub-dialog.md.
      Best,
      -Niklas
        On 07/04/2014 at 11:19, xxxxxxxx wrote:
        Thanks for the help guys, however I still have a few problems. Using Kiklas' method I got the SubDialogs to behave correctly when I re-open them while they are open and the window becomes active. I still get a Plugin not found while restoring a layout, I think this reason is due to having more than one sub dialog.
        here is the code:
        def Restore(self, PLUGIN_ID, secref) :
             if secref['subid'] == 1:
                  return self.sub_dialog1.Restore(PLUGIN_ID,secref)
             elif secref['subid'] == 2:
                  return self.sub_dialog2.Restore(PLUGIN_ID,secref)
                  return super(MainDialog, self).Restore(PLUGIN_ID,secref)
        How do I correctly look for both subdialogs.
          On 07/04/2014 at 11:23, xxxxxxxx wrote:
          How do you open the subdialogs?
            On 07/04/2014 at 11:26, xxxxxxxx wrote:
            if id == 10017: # Get Render Time
                 self.sub_dialog2.Open(c4d.DLG_TYPE_ASYNC, defaulth=200, defaultw=300, subid = 2)
            Oh wait, I think I just figured it out, This has to have the plugin ID as well correct?
              On 07/04/2014 at 11:41, xxxxxxxx wrote:
              No that did not work. Here is what my @properties look like
              @property
              def sub_dialog1(self) :
                   if not hasattr(self, '_sub_dialog1') :
                        self._sub_dialog1 = ColorDialog()
                   return self._sub_dialog1
              @property
              def sub_dialog2(self) :
                   if not hasattr(self, '_sub_dialog2') :
                        self._sub_dialog2 = RenderTimeDialog()
                   return self._sub_dialog2
                On 07/04/2014 at 11:58, xxxxxxxx wrote:
                Here is the code from your exaple made to have 2 sub dialogs: Same problem.
                PLUGIN_ID = 1000004 # Test ID
                class MainDialog(c4d.gui.GeDialog) :
                    # Do not create the object on class-level, although it might
                    # be unimportant since you do not open multiple objects of your
                    # MainDialog, it is contradicting to have one instance of sub
                    # dialog for all instances of the main dialog.
                    # A property that creates the dialog on-demand is perfect for
                    # this purpose.
                    @property
                    def sub_dialog(self) :
                        if not hasattr(self, '_sub_dialog') :
                            self._sub_dialog = SubDialog()
                    @property
                            self._sub_dialog2 = SubDialog2()
                    # c4d.gui.GeDialog
                    def CreateLayout(self) :
                        self.SetTitle('Main Dialog')
                        self.AddButton(1000, 0, name="Open Sub-Dialog")
                    def Command(self, param, bc) :
                        if param == 1000:
                            self.sub_dialog.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=1)
                            self.sub_dialog2.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=2)
                    def Restore(self, pluginid, secref) :
                        # We override this method so we don't have to handle the sub-
                        # dialog from the CommandData plugin. THIS dialog is responsible
                        # for the sub-dialog, do not split such management throughout
                        # your program or it gets confusing.
                            return self.sub_dialog.Restore(pluginid, secref)
                            return self.sub_dialog2.Restore(pluginid, secref)
                            return super(MainDialog, self).Restore(pluginid, secref)
                class SubDialog(c4d.gui.GeDialog) :
                        self.SetTitle('Sub-Dialog')
                        self.AddStaticText(1000, 0, name="This is the sub-dialog.")
                class SubDialog2(c4d.gui.GeDialog) :
                        self.SetTitle('Sub-Dialog2')
                        self.AddStaticText(1000, 0, name="This is the sub-dialog2.")
                class Command(c4d.plugins.CommandData) :
                    def Register(self) :
                        return c4d.plugins.RegisterCommandPlugin(
                                PLUGIN_ID, "Sub-Dialog Docking Test", 0, None, "", self)
                    @property
                    def dialog(self) :
                        if not hasattr(self, '_dialog') :
                            self._dialog = MainDialog()
                        return self._dialog
                    # c4d.plugins.CommandData
                    def Execute(self, doc) :
                        return self.dialog.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID)
                    def RestoreLayout(self, secref) :
                        return self.dialog.Restore(PLUGIN_ID, secref)
                    Command().Register()
                  On 07/04/2014 at 13:45, xxxxxxxx wrote:
                  OK I got the example to work.
                  however I cannot get my plugin to work. could it be that my main window uses a .res file?
                      # this purpose.
                      @property
                      @property
                      # c4d.gui.GeDialog
                          if param == 1000:
                              print "yes"
                      @property
                      def dialog(self) :
                          return self._dialog
                    On 08/04/2014 at 14:11, xxxxxxxx wrote:
                    I think the problem with my plugin has something to do with the main command class, the "RestoreLayout" does not get called at all. I added some print functions to see and nothing. However the example prints just fine. Here is my main command code:
                    class RenderBuddy(c4d.plugins.CommandData) :
                        @property
                        def RBdialog(self) :
                            if not hasattr(self, '_RBdialog') :
                                self._RBdialog = BuddyDialog()
                            return self._RBdialog
                            return c4d.plugins.RegisterCommandPlugin(PLUGIN_ID, "Render Buddy (Beta)",0, bmp, "", self)
                            return self.RBdialog.Open(c4d.DLG_TYPE_ASYNC,PLUGIN_ID)
                        def RestorLayout(self, secref) :
                            print "RB_Main"
                            return self.RBdialog.Restore(PLUGIN_ID, secref)
                        path, fn = os.path.split(__file__)
                        bmp = bitmaps.BaseBitmap()
                        bmp.InitWith(os.path.join(path, "res/icons/", "icon.tif"))
                        RenderBuddy().Register()
                    Everything seems to be right, but the RestoreLayout does not get called.
                      On 08/04/2014 at 14:14, xxxxxxxx wrote:
                      Figured it out! After typing it out above I realized RestoreLayout() was misspelled. Thank you guys for all the help!
                      *Edit there is a new problem the setup:
                                  print "Color"
                                  return self.RB_ColorDLG.Restore(pluginid,secref)
                                  print "Temp"
                                  return self.RB_TempDLG.Restore(pluginid,secref)
                                  print "Main"
                                  return super(BuddyDialog, self).Restore(pluginid,secref)
                      This causes cinema to crash. I will restore the layout but if you launch the sub dialog again everything locks up. This happens with the Example as well. Confused
                        On 08/04/2014 at 16:01, xxxxxxxx wrote:
                        Hi Shawn, I can reproduce the problems you have described. The Example I posted worked though,
                        but funnily broke after a few more times testing it. I'll have to talk to a developer on this, I am pretty
                        sure this is a bug. Especially this message is
                          File "'restore-sub-dialog.pyp'", line 57, in CreateLayout
                        SystemError: error return without exception set
                        Best,
                        -Niklas
                          On 08/04/2014 at 16:19, xxxxxxxx wrote:
                          Thank you Niklas.
                          -Shawn
                            On 08/04/2014 at 19:28, xxxxxxxx wrote:
                            It seems to work just fine for me. No errors or problems at all.
                            Maybe you're trying to do something different than I'm doing?
                            Here is a complete example that works fine for me in R13.
                            Save it as a .pyp file and put it in your plugins folder.
                            The main dialog has buttons to open two other dialogs. And a button that will change the checkbox gizmo in dilaog1.
                            All three dialogs can be docked into the UI and saved in a custom layout.
                            #This is an example of a GeDialog plugin that opens three dialogs
                            #It also allows all three dialogs to be docked and saved in a custom layout
                            import c4d, os
                            from c4d import gui, plugins, bitmaps
                            PLUGIN_ID  = 1000004 #Testing ID
                            SUBDLG_ID1  = 1000005 #Testing ID
                            SUBDLG_ID2 = 1000006 #Testing ID
                            MAINDLG_BUTTON1_ID = 1000
                            MAINDLG_BUTTON2_ID = 1001
                            MAINDLG_BUTTON3_ID = 1002
                            SUBDLG_TEXT_ID     = 1003
                            SUBDLG_CHKBOX_ID   = 1004
                            SUBDLG_RESET_ID    = 1005
                            #The first sub dialog
                            class SubDialog1(c4d.gui.GeDialog) :
                                  self.SetTitle('Sub-Dialog1')
                                  self.GroupBeginInMenuLine()
                                  self.AddCheckbox(SUBDLG_RESET_ID, c4d.BFH_RIGHT, 100, 20, name="Reset")
                                  self.GroupEnd()
                                  self.GroupBegin(0, c4d.BFH_SCALEFIT, 2, 0, "MyGroup")
                                  self.GroupBorderSpace(5, 5, 5, 5)
                                  self.GroupBorder(c4d.BORDER_BLACK)
                                  self.AddStaticText(SUBDLG_TEXT_ID, c4d.BFH_LEFT, 200, 20, "This is the sub-dialog1")
                                  self.AddCheckbox(SUBDLG_CHKBOX_ID, c4d.BFH_LEFT, 20, 20, "myChkbox")
                                  self.GroupEnd()
                              def Command(self, id, msg) :
                                  if id == SUBDLG_RESET_ID:
                                      self.SetBool(SUBDLG_CHKBOX_ID, False)
                                      self.SetBool(SUBDLG_RESET_ID, False)
                            #The second sub dialog
                                  self.GroupEnd()
                                  self.AddStaticText(SUBDLG_TEXT_ID, c4d.BFH_LEFT, 200, 20, "This is the sub-dialog2")
                                  self.GroupEnd()
                            #The main dialog
                              sub_dialog1 = SubDialog1()
                                  self.AddButton(MAINDLG_BUTTON1_ID, 0, name="Open Sub-Dialog1")
                                  self.AddButton(MAINDLG_BUTTON2_ID, 0, name="Open Sub-Dialog2")
                                  self.AddButton(MAINDLG_BUTTON3_ID, 0, name="Change Sub-Dialog1")
                                  if id == MAINDLG_BUTTON1_ID:
                                      self.sub_dialog1.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=SUBDLG_ID1)
                                  if id == MAINDLG_BUTTON2_ID:
                                      self.sub_dialog2.Open(c4d.DLG_TYPE_ASYNC, PLUGIN_ID, subid=SUBDLG_ID2)
                                  if id == MAINDLG_BUTTON3_ID:
                                      self.sub_dialog1.SetBool(SUBDLG_CHKBOX_ID, True)
                              #Restore the subdialog and the main dialog in the layout
                                  if secref['subid'] == SUBDLG_ID1:
                                      return self.sub_dialog1.Restore(pluginid, secref)
                                  if secref['subid'] == SUBDLG_ID2:
                            #The Command Data section
                            class MainDialog_CD(c4d.plugins.CommandData) :
                              @property
                              def dialog(self) :
                                  return self._dialog
                              fn = os.path.join(dir, "res", "icon.png")
                              bmp.InitWith(fn)
                              plugins.RegisterCommandPlugin(PLUGIN_ID, "Sub-Dialog Docking",0, bmp, "re-open", MainDialog_CD())
