    Snap object in mouse input
    25 Posts 0 Posters 18.0k Views
      On 09/01/2013 at 11:33, xxxxxxxx wrote:
      You need to use the c4d.utils.GeRayCollider class to find an intersection on the surface of the
      destination-object, intersected by the line defined by the mouse-position in global space and
      the camera position.
      op = doc.GetActiveObject()
            op_next = op.GetNext()
            if not op_next:
      # Convert op_next to a polygon object.
            # Simplified here, just for demonstration purpose.
            op_next = op_next.GetCache()
            if not op_next or not op_next.CheckType(c4d.Opolygon) :
                print "Cache is not existent or is not a polygon object."
            win.MouseDragStart(button=device, mx=int(mx), my=int(my), flags=c4d.MOUSEDRAGFLAGS_DONTHIDEMOUSE)
            result, dx, dy, channel = win.MouseDrag()
            while result==c4d.MOUSEDRAGRESULT_CONTINUE:
                mx += dx
                my += dy
                cursorpos = bd.SW(c4d.Vector(mx,my,500))     #screen to world conversion
                if(axis == 1) :
                    cursorpos.x = 0
                elif(axis == 2) :
                    cursorpos.y = 0                          #Constrain drawing along an axis based on the comboButton's value
                elif(axis == 3) :
                    cursorpos.z = 0
      cam_pos = bd.GetSceneCamera(doc).GetAbsPos()
                collider = c4d.utils.GeRayCollider()
                collider.Init(op_next)
      length = 500000
                direction = -(cam_pos - cursorpos).GetNormalized()
      did_intersect = collider.Intersect(cam_pos, direction, length)
                if did_intersect:
                    position = collider.GetNearestIntersection()['hitpos']
                    print "Intersection at", position
                    print "No intersection."
                    position = cursorpos
                op.SetAbsPos(position)
                op.Message(c4d.MSG_UPDATE)
      c4d.DrawViews(c4d.DA_ONLY_ACTIVE_VIEW|c4d.DA_NO_THREAD|c4d.DA_NO_ANIMATION)
      -Nik
      I again disorder 🙂
      I wanted that the active object changed the axis alignment, as the normal to the surfaced intersection?
      example:
      the current code
      my request:
      The axis changed by surface normal...
        On 09/01/2013 at 11:48, xxxxxxxx wrote:
        What about trying it yourself? 😉
        Slight tip: The dictionary returned by GeRayCollider.GetNearestIntersection() contains information
        like what polygon was interesected. You can then compute the normal of that polygon and rotate
        the destination object accordingly.
        @ littledevil :
        Well, we don't want the closes point on the surface, do we? I'm sorry, I don't see why the green
        line is the one we would like to use instead of the red line.. :// I also don't get how you would
        come to that green line, I don't see any relation to the camera position or view-direction or similar.
        Hope that doesn't sound offending or so, because that was not my intention. I always
        appreciate constructive criticism or questions. 🙂
        Best,
        -Niklas
          On 09/01/2013 at 12:13, xxxxxxxx wrote:
          NiklasR we are successful!🤝  Thank you for your precious help 🍺🍺
            On 12/01/2013 at 03:43, xxxxxxxx wrote:
            i have modified the  **op_next  **with Linkbox but... no work...
            The object is not recognized...
            I've never had much luck with the linkbox 😂
            MY_LINKBOX = 100014
            def CreateLayout(self) :
                    self.GroupBegin(id=1000, flags=c4d.BFH_SCALEFIT, cols=1, rows=1)
                    self.GroupBorderSpace(10, 10, 10, 10)
                    self.element = self.AddStaticText(id=1001, flags=c4d.BFH_MASK, initw=120, name="Inserire Oggetto:", borderstyle=c4d.BORDER_NONE)
                    self.linkBox = self.AddCustomGui(MY_LINKBOX, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0)
                    self.GroupEnd()
            def MouseInput(self, doc, data, bd, win, msg) :
                    mx = msg[c4d.BFM_INPUT_X]
                    my = msg[c4d.BFM_INPUT_Y]
                    device = 0
                    if msg[c4d.BFM_INPUT_CHANNEL]==c4d.BFM_INPUT_MOUSELEFT:
                        device = c4d.KEY_MLEFT
                    elif msg[c4d.BFM_INPUT_CHANNEL]==c4d.BFM_INPUT_MOUSERIGHT:
                         device = c4d.KEY_MRIGHT
                    op_next = self.linkBox.GetLink()
                    if not op_next:
                        mx += dx
                        my += dy
            length = 500000
                        if did_intersect:
                            position = collider.GetNearestIntersection()["hitpos"]
              On 12/01/2013 at 07:22, xxxxxxxx wrote:
              try :
              op_next = self.linkBox.GetLink(c4d.documents.GetActiveDocument(), c4d.Obase)
                try :
                "object has no attribute 'linkBox'"....
                I am beginning to think that linkbox they hate me 😂
                Thanks littledevil, you are a generous person, always ready to help all friends in this forum 👍
                  On 12/01/2013 at 10:37, xxxxxxxx wrote:
                  could be some kind of call order problem. try something like this
                  class myclass(c4d.Something) :
                  	def __init__(self) :
                  		self.linkBox = None
                  	def CreateLayout(self, *args) :
                  		self.linkBox = Something
                  	def AnotherMethod(self) :
                  		if (not self.linkBox) :
                  			return False
                  			x = self.linkBox.Do(blah)
                  MouseInput might be called the first time before CreateLayout has been called and as you
                  haven't defined linkBox as a variable in the class constructor it does not yet exist at that point.
                    On 12/01/2013 at 12:08, xxxxxxxx wrote:
                    littledevil, i have pasted the entire code.
                    You can control it and correct it?
                    I would like to understand where I'm wrong ...
                    Thanks for your help 🍺
                    import os
                    import sys
                    from c4d import plugins, utils, bitmaps, gui, documents
                    PLUGIN_ID = 10000008 # THIS id IS FOR TESTING PUPOSES ONLY!!!
                    #for GeLoadString values must match with the header file
                    IDS_ESTENSIONE = 100000
                    MY_LINKBOX = 100015
                    class SettingsDialog(gui.SubDialog) :
                     **        self.linkBox = self.AddCustomGui(MY_LINKBOX, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0)**
                            self.GroupEnd()
                        def InitValues(self) :
                        def Command(self, id, msg) :
                    class Caleidos(plugins.ToolData) :
                            self.data = 0
                        def KeyboardInput(self, doc, data, bd, win, msg) :
                            key = msg.GetLong(c4d.BFM_INPUT_CHANNEL)
                            cstr = msg.GetString(c4d.BFM_INPUT_ASC)
                            if key==c4d.KEY_ESC:
                                #do what you want
                                #return True to signal that the key is processed
                            return False
                    		if msg.GetLong(c4d.BFM_INPUT_CHANNEL)==c4d.BFM_INPUT_MOUSELEFT:
                    			print "Begin Mouse Left Pressed"
                    			while True:
                    				bc = c4d.BaseContainer()
                    				if gui.GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, bc) :
                    					if bc.GetLong(c4d.BFM_INPUT_CHANNEL)==c4d.BFM_INPUT_MOUSELEFT:
                    						print "Mouse Left Pressed"
                    						device = 0
                    						doc.StartUndo()
                    						myobject = **self.linkBox.GetLink()**
                    						op = myobject
                    						op_next = doc.GetActiveObject()
                    							mx += dx
                    							my += dy
                    							length = 500000
                    							if did_intersect:
                       						if not bc.GetBool(c4d.BFM_INPUT_VALUE) : break
                    			print "End Mouse Left Pressed"
                        def AllocSubDialog(self, bc) :
                            return SettingsDialog(self.data) #always return new instance(self.data)
                        bmp = bitmaps.BaseBitmap()
                        fn = os.path.join(dir, "res", "Icon.tif")
                        bmp.InitWith(fn)
                        plugins.RegisterToolPlugin(id=PLUGIN_ID, str="Caleidos",info=0, icon=bmp, help="Statusbar Text",dat=Caleidos())
                      On 12/01/2013 at 13:03, xxxxxxxx wrote:
                      this obviously won't work. i think you do not really understand what self means in python.
                      it is similar to this in c# or java. it is a referecne to the actual instance of the class from which
                      the code is being executed from. you are doing more or less this :
                      class clsA() :
                      	def __init__(self, x) :
                      		self.X = x
                      class clsB() :
                      	def someMethod() :
                      		# raises a runtime error as class b does not have a memeber called X
                      		print self.X
                      you have either make your dialog class instance a globally available variable (but this
                      could be considered as really bad style) :
                      class clsA() :
                              self.X = x
                      class clsB() :
                          def do (self, classAinstance) :
                              print classAinstance.X
                          A = clsA()
                          B = clsB()
                          B.do(A)
                      or you have to make an instance of your GeDialog class a memeber of your
                      ToolData class.
                      class ToolDataClass() :
                              self.dialog = None
                              self.data = None
                          def doSomething(self) :
                              if (self.dialog) :
                                  print self.Dialog.linkBox.GetLink(document, c4d.Obase)
                                  print 'dialog has not been raised yet.'
                              self.Dialog = SettingsDialog(self.data)
                              return self.Dialog
                      edit : fixed a typo,  should be if (self.dialog) : of course and not if(self.data) :
                        ToolData class.
                                self.dialog = None
                                self.data = None
                                if (self.dialog) :
                                return self.Dialog
                        Work!!! I succeeded! littledevil Thanks!!!!!!! 🤝
                                if not op_next:
                                    mx += dx
                                    my += dy
                                    if(axis == 1) :
                                        cursorpos.x = 0
                                    elif(axis == 2) :
                                    elif(axis == 3) :
                                        cursorpos.z = 0
                          length = 500000
                                    if did_intersect:
                          -Nik
                          an example for snap on point object? thanks 🙂
                            What do you mean with "the snap does not work"? You are not even trying to snap the
                            object, just setting it to the cursor position.
                            joint.SetAbsPos(cursorpos)
                            If you want to to snap to a grid with a spacing of 50 units (just for the sake of example), you
                            need to adjust the position vector.
                            def snap_value(value, step) :
                                  rest = value % step
                                  on_grid = value - rest
                            if rest / float(step) >= 0.5:
                                      on_grid += step
                            return on_grid
                            def snap_grid(vector, gridsize) :
                                  vector = c4d.Vector(vector)
                                  vector.x = snap_value(vector.x, gridsize)
                                  vector.y = snap_value(vector.y, gridsize)
                                  vector.z = snap_value(vector.z, gridsize)
                                  return vector
                            gridsize = 50
                              position = snap_grid(cursorpos)
                              joint.SetAbsPos(position)
                            See the full code here.
                            -Niklas
                            HI NiklasR How do you adjust the cursor position for snap points ? 🙂
                              Assuming you have a coordinate in 3D space, you can just use the nearest mesh point and maybe
                              check if the point is within the snap radius.
                                  def snap_point(point, radius, obj) :
                                      Calculate the snapping point from a coordinate in 3D space
                                      to a point object within the defined \*radius\*. Requires
                                      the \*point\* in global space.
                                      mg = obj.GetMg()
                                      points = obj.GetAllPoints()
                                      point = ~mg \* point
                                      radius \*\*= 2
                                      nearest = None
                                      for p in points:
                                          delta = (p - point).GetLengthSquared()
                                          if delta <= radius and (not nearest or nearest[1] > delta) :
                                              nearest = p, delta
                                      if nearest:
                                          point = nearest[0]
                                      return point
                                      p = c4d.Vector(102, 99, 97)
                                      print snap_point(p, 10, op)
                              Best regards,
                              -Niklas
                                You can not "adjust" the cursor position, the cursor is where the mouse points it to. There is also
                                a snapping mode for snapping to object points, so what exactly do you need?
                                -Niklas
