    Snap object in mouse input
    25 Posts 0 Posters 17.7k Views
      On 08/01/2013 at 10:42, xxxxxxxx wrote:
      Hi Ferdinand,
      I'm not sure what you mean with "camera 'normal' based snappin lead to funny results". Possibly
      I just should get some sleep, but would you mind to elaborate a little bit more on what you are
      talking about? 🙂
      Thanks for the resources, I've always been interested into that topic but these links are new
      to me!
      -Nik
        On 08/01/2013 at 10:48, xxxxxxxx wrote:
        Thank you so much for your help, now everything is much more understandable ^_^
        Thanks NiklasR 👍 and Thanks littledevil 👍
          On 08/01/2013 at 10:53, xxxxxxxx wrote:
          as I already said this might be based on a misconeption of your code,
          but this is what is was talking about. (awesome paint pic inc.) :
          the red line is what your code will return for my understanding, the green line is
          the closest point on surface. at least i would consider the red result as unwanted
          or 'funny'.
          edit : i hope this does make any sense for someone else than me 🙂
            On 09/01/2013 at 11:33, xxxxxxxx wrote:
            You need to use the c4d.utils.GeRayCollider class to find an intersection on the surface of the
            destination-object, intersected by the line defined by the mouse-position in global space and
            the camera position.
            op = doc.GetActiveObject()
                  op_next = op.GetNext()
                  if not op_next:
            # Convert op_next to a polygon object.
                  # Simplified here, just for demonstration purpose.
                  op_next = op_next.GetCache()
                  if not op_next or not op_next.CheckType(c4d.Opolygon) :
                      print "Cache is not existent or is not a polygon object."
                  win.MouseDragStart(button=device, mx=int(mx), my=int(my), flags=c4d.MOUSEDRAGFLAGS_DONTHIDEMOUSE)
                  result, dx, dy, channel = win.MouseDrag()
                  while result==c4d.MOUSEDRAGRESULT_CONTINUE:
                      mx += dx
                      my += dy
                      cursorpos = bd.SW(c4d.Vector(mx,my,500))     #screen to world conversion
                      if(axis == 1) :
                          cursorpos.x = 0
                      elif(axis == 2) :
                          cursorpos.y = 0                          #Constrain drawing along an axis based on the comboButton's value
                      elif(axis == 3) :
                          cursorpos.z = 0
            cam_pos = bd.GetSceneCamera(doc).GetAbsPos()
                      collider = c4d.utils.GeRayCollider()
                      collider.Init(op_next)
            length = 500000
                      direction = -(cam_pos - cursorpos).GetNormalized()
            did_intersect = collider.Intersect(cam_pos, direction, length)
                      if did_intersect:
                          position = collider.GetNearestIntersection()['hitpos']
                          print "Intersection at", position
                          print "No intersection."
                          position = cursorpos
                      op.SetAbsPos(position)
                      op.Message(c4d.MSG_UPDATE)
            c4d.DrawViews(c4d.DA_ONLY_ACTIVE_VIEW|c4d.DA_NO_THREAD|c4d.DA_NO_ANIMATION)
            -Nik
            I again disorder 🙂
            I wanted that the active object changed the axis alignment, as the normal to the surfaced intersection?
            example:
            the current code
            my request:
            The axis changed by surface normal...
              On 09/01/2013 at 11:48, xxxxxxxx wrote:
              What about trying it yourself? 😉
              Slight tip: The dictionary returned by GeRayCollider.GetNearestIntersection() contains information
              like what polygon was interesected. You can then compute the normal of that polygon and rotate
              the destination object accordingly.
              @ littledevil :
              Well, we don't want the closes point on the surface, do we? I'm sorry, I don't see why the green
              line is the one we would like to use instead of the red line.. :// I also don't get how you would
              come to that green line, I don't see any relation to the camera position or view-direction or similar.
              Hope that doesn't sound offending or so, because that was not my intention. I always
              appreciate constructive criticism or questions. 🙂
              Best,
              -Niklas
                On 09/01/2013 at 12:13, xxxxxxxx wrote:
                NiklasR we are successful!🤝  Thank you for your precious help 🍺🍺
                  On 12/01/2013 at 03:43, xxxxxxxx wrote:
                  i have modified the  **op_next  **with Linkbox but... no work...
                  The object is not recognized...
                  I've never had much luck with the linkbox 😂
                  MY_LINKBOX = 100014
                  def CreateLayout(self) :
                          self.GroupBegin(id=1000, flags=c4d.BFH_SCALEFIT, cols=1, rows=1)
                          self.GroupBorderSpace(10, 10, 10, 10)
                          self.element = self.AddStaticText(id=1001, flags=c4d.BFH_MASK, initw=120, name="Inserire Oggetto:", borderstyle=c4d.BORDER_NONE)
                          self.linkBox = self.AddCustomGui(MY_LINKBOX, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0)
                          self.GroupEnd()
                  def MouseInput(self, doc, data, bd, win, msg) :
                          mx = msg[c4d.BFM_INPUT_X]
                          my = msg[c4d.BFM_INPUT_Y]
                          device = 0
                          if msg[c4d.BFM_INPUT_CHANNEL]==c4d.BFM_INPUT_MOUSELEFT:
                              device = c4d.KEY_MLEFT
                          elif msg[c4d.BFM_INPUT_CHANNEL]==c4d.BFM_INPUT_MOUSERIGHT:
                               device = c4d.KEY_MRIGHT
                          op_next = self.linkBox.GetLink()
                          if not op_next:
                              mx += dx
                              my += dy
                  length = 500000
                              if did_intersect:
                                  position = collider.GetNearestIntersection()["hitpos"]
                    On 12/01/2013 at 07:22, xxxxxxxx wrote:
                    try :
                    op_next = self.linkBox.GetLink(c4d.documents.GetActiveDocument(), c4d.Obase)
                      try :
                      "object has no attribute 'linkBox'"....
                      I am beginning to think that linkbox they hate me 😂
                      Thanks littledevil, you are a generous person, always ready to help all friends in this forum 👍
                        On 12/01/2013 at 10:37, xxxxxxxx wrote:
                        could be some kind of call order problem. try something like this
                        class myclass(c4d.Something) :
                        	def __init__(self) :
                        		self.linkBox = None
                        	def CreateLayout(self, *args) :
                        		self.linkBox = Something
                        	def AnotherMethod(self) :
                        		if (not self.linkBox) :
                        			return False
                        			x = self.linkBox.Do(blah)
                        MouseInput might be called the first time before CreateLayout has been called and as you
                        haven't defined linkBox as a variable in the class constructor it does not yet exist at that point.
                          On 12/01/2013 at 12:08, xxxxxxxx wrote:
                          littledevil, i have pasted the entire code.
                          You can control it and correct it?
                          I would like to understand where I'm wrong ...
                          Thanks for your help 🍺
                          import os
                          import sys
                          from c4d import plugins, utils, bitmaps, gui, documents
                          PLUGIN_ID = 10000008 # THIS id IS FOR TESTING PUPOSES ONLY!!!
                          #for GeLoadString values must match with the header file
                          IDS_ESTENSIONE = 100000
                          MY_LINKBOX = 100015
                          class SettingsDialog(gui.SubDialog) :
                           **        self.linkBox = self.AddCustomGui(MY_LINKBOX, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0)**
                                  self.GroupEnd()
                              def InitValues(self) :
                              def Command(self, id, msg) :
                          class Caleidos(plugins.ToolData) :
                                  self.data = 0
                              def KeyboardInput(self, doc, data, bd, win, msg) :
                                  key = msg.GetLong(c4d.BFM_INPUT_CHANNEL)
                                  cstr = msg.GetString(c4d.BFM_INPUT_ASC)
                                  if key==c4d.KEY_ESC:
                                      #do what you want
                                      #return True to signal that the key is processed
                                  return False
                          		if msg.GetLong(c4d.BFM_INPUT_CHANNEL)==c4d.BFM_INPUT_MOUSELEFT:
                          			print "Begin Mouse Left Pressed"
                          			while True:
                          				bc = c4d.BaseContainer()
                          				if gui.GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, bc) :
                          					if bc.GetLong(c4d.BFM_INPUT_CHANNEL)==c4d.BFM_INPUT_MOUSELEFT:
                          						print "Mouse Left Pressed"
                          						device = 0
                          						doc.StartUndo()
                          						myobject = **self.linkBox.GetLink()**
                          						op = myobject
                          						op_next = doc.GetActiveObject()
                          							mx += dx
                          							my += dy
                          							length = 500000
                          							if did_intersect:
                             						if not bc.GetBool(c4d.BFM_INPUT_VALUE) : break
                          			print "End Mouse Left Pressed"
                              def AllocSubDialog(self, bc) :
                                  return SettingsDialog(self.data) #always return new instance(self.data)
                              bmp = bitmaps.BaseBitmap()
                              fn = os.path.join(dir, "res", "Icon.tif")
                              bmp.InitWith(fn)
                              plugins.RegisterToolPlugin(id=PLUGIN_ID, str="Caleidos",info=0, icon=bmp, help="Statusbar Text",dat=Caleidos())
                            On 12/01/2013 at 13:03, xxxxxxxx wrote:
                            this obviously won't work. i think you do not really understand what self means in python.
                            it is similar to this in c# or java. it is a referecne to the actual instance of the class from which
                            the code is being executed from. you are doing more or less this :
                            class clsA() :
                            	def __init__(self, x) :
                            		self.X = x
                            class clsB() :
                            	def someMethod() :
                            		# raises a runtime error as class b does not have a memeber called X
                            		print self.X
                            you have either make your dialog class instance a globally available variable (but this
                            could be considered as really bad style) :
                            class clsA() :
                                    self.X = x
                            class clsB() :
                                def do (self, classAinstance) :
                                    print classAinstance.X
                                A = clsA()
                                B = clsB()
                                B.do(A)
                            or you have to make an instance of your GeDialog class a memeber of your
                            ToolData class.
                            class ToolDataClass() :
                                    self.dialog = None
                                    self.data = None
                                def doSomething(self) :
                                    if (self.dialog) :
                                        print self.Dialog.linkBox.GetLink(document, c4d.Obase)
                                        print 'dialog has not been raised yet.'
                                    self.Dialog = SettingsDialog(self.data)
                                    return self.Dialog
                            edit : fixed a typo,  should be if (self.dialog) : of course and not if(self.data) :
                              ToolData class.
                                      self.dialog = None
                                      self.data = None
                                      if (self.dialog) :
                                      return self.Dialog
                              Work!!! I succeeded! littledevil Thanks!!!!!!! 🤝
                                      if not op_next:
                                          mx += dx
                                          my += dy
                                          if(axis == 1) :
                                              cursorpos.x = 0
                                          elif(axis == 2) :
                                          elif(axis == 3) :
                                              cursorpos.z = 0
                                length = 500000
                                          if did_intersect:
                                -Nik
                                an example for snap on point object? thanks 🙂
                                  What do you mean with "the snap does not work"? You are not even trying to snap the
                                  object, just setting it to the cursor position.
                                  joint.SetAbsPos(cursorpos)
                                  If you want to to snap to a grid with a spacing of 50 units (just for the sake of example), you
                                  need to adjust the position vector.
                                  def snap_value(value, step) :
                                        rest = value % step
                                        on_grid = value - rest
                                  if rest / float(step) >= 0.5:
                                            on_grid += step
                                  return on_grid
                                  def snap_grid(vector, gridsize) :
                                        vector = c4d.Vector(vector)
                                        vector.x = snap_value(vector.x, gridsize)
                                        vector.y = snap_value(vector.y, gridsize)
                                        vector.z = snap_value(vector.z, gridsize)
                                        return vector
                                  gridsize = 50
                                    position = snap_grid(cursorpos)
                                    joint.SetAbsPos(position)
                                  See the full code here.
                                  -Niklas
                                  HI NiklasR How do you adjust the cursor position for snap points ? 🙂
                                    Assuming you have a coordinate in 3D space, you can just use the nearest mesh point and maybe
                                    check if the point is within the snap radius.
                                        def snap_point(point, radius, obj) :
                                            Calculate the snapping point from a coordinate in 3D space
                                            to a point object within the defined \*radius\*. Requires
                                            the \*point\* in global space.
                                            mg = obj.GetMg()
                                            points = obj.GetAllPoints()
                                            point = ~mg \* point
                                            radius \*\*= 2
                                            nearest = None
                                            for p in points:
                                                delta = (p - point).GetLengthSquared()
                                                if delta <= radius and (not nearest or nearest[1] > delta) :
                                                    nearest = p, delta
                                            if nearest:
                                                point = nearest[0]
                                            return point
                                            p = c4d.Vector(102, 99, 97)
                                            print snap_point(p, 10, op)
                                    Best regards,
                                    -Niklas
                                      You can not "adjust" the cursor position, the cursor is where the mouse points it to. There is also
                                      a snapping mode for snapping to object points, so what exactly do you need?
                                      -Niklas
