    Snap object in mouse input
    25 Posts 0 Posters 17.1k Views
      On 09/01/2013 at 11:48, xxxxxxxx wrote:
      What about trying it yourself? 😉
      Slight tip: The dictionary returned by GeRayCollider.GetNearestIntersection() contains information
      like what polygon was interesected. You can then compute the normal of that polygon and rotate
      the destination object accordingly.
      @ littledevil :
      Well, we don't want the closes point on the surface, do we? I'm sorry, I don't see why the green
      line is the one we would like to use instead of the red line.. :// I also don't get how you would
      come to that green line, I don't see any relation to the camera position or view-direction or similar.
      Hope that doesn't sound offending or so, because that was not my intention. I always
      appreciate constructive criticism or questions. 🙂
      Best,
      -Niklas
        On 09/01/2013 at 12:13, xxxxxxxx wrote:
        NiklasR we are successful!🤝  Thank you for your precious help 🍺🍺
          On 12/01/2013 at 03:43, xxxxxxxx wrote:
          i have modified the  **op_next  **with Linkbox but... no work...
          The object is not recognized...
          I've never had much luck with the linkbox 😂
          MY_LINKBOX = 100014
          def CreateLayout(self) :
                  self.GroupBegin(id=1000, flags=c4d.BFH_SCALEFIT, cols=1, rows=1)
                  self.GroupBorderSpace(10, 10, 10, 10)
                  self.element = self.AddStaticText(id=1001, flags=c4d.BFH_MASK, initw=120, name="Inserire Oggetto:", borderstyle=c4d.BORDER_NONE)
                  self.linkBox = self.AddCustomGui(MY_LINKBOX, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0)
                  self.GroupEnd()
          def MouseInput(self, doc, data, bd, win, msg) :
                  mx = msg[c4d.BFM_INPUT_X]
                  my = msg[c4d.BFM_INPUT_Y]
                  device = 0
                  if msg[c4d.BFM_INPUT_CHANNEL]==c4d.BFM_INPUT_MOUSELEFT:
                      device = c4d.KEY_MLEFT
                  elif msg[c4d.BFM_INPUT_CHANNEL]==c4d.BFM_INPUT_MOUSERIGHT:
                       device = c4d.KEY_MRIGHT
          op = doc.GetActiveObject()
                  op_next = self.linkBox.GetLink()
                  if not op_next:
          win.MouseDragStart(button=device, mx=int(mx), my=int(my), flags=c4d.MOUSEDRAGFLAGS_DONTHIDEMOUSE)
                  result, dx, dy, channel = win.MouseDrag()
                  while result==c4d.MOUSEDRAGRESULT_CONTINUE:
                      mx += dx
                      my += dy
          cursorpos = bd.SW(c4d.Vector(mx,my,500))     #screen to world conversion
          cam_pos = bd.GetSceneCamera(doc).GetAbsPos()
                      collider = c4d.utils.GeRayCollider()
                      collider.Init(op_next)
          length = 500000
                      direction = -(cam_pos - cursorpos).GetNormalized()
          did_intersect = collider.Intersect(cam_pos, direction, length)
                      if did_intersect:
                          position = collider.GetNearestIntersection()["hitpos"]
                          print "Intersection at", position
                          print "No intersection."
                          position = cursorpos
                      op.SetAbsPos(position)
                      op.Message(c4d.MSG_UPDATE)
          c4d.DrawViews(c4d.DA_ONLY_ACTIVE_VIEW|c4d.DA_NO_THREAD|c4d.DA_NO_ANIMATION)
            On 12/01/2013 at 07:22, xxxxxxxx wrote:
            try :
            op_next = self.linkBox.GetLink(c4d.documents.GetActiveDocument(), c4d.Obase)
              On 12/01/2013 at 09:11, xxxxxxxx wrote:
              try :
              "object has no attribute 'linkBox'"....
              I am beginning to think that linkbox they hate me 😂
              Thanks littledevil, you are a generous person, always ready to help all friends in this forum 👍
                On 12/01/2013 at 10:37, xxxxxxxx wrote:
                could be some kind of call order problem. try something like this
                class myclass(c4d.Something) :
                	def __init__(self) :
                		self.linkBox = None
                	def CreateLayout(self, *args) :
                		self.linkBox = Something
                	def AnotherMethod(self) :
                		if (not self.linkBox) :
                			return False
                			x = self.linkBox.Do(blah)
                MouseInput might be called the first time before CreateLayout has been called and as you
                haven't defined linkBox as a variable in the class constructor it does not yet exist at that point.
                  On 12/01/2013 at 12:08, xxxxxxxx wrote:
                  littledevil, i have pasted the entire code.
                  You can control it and correct it?
                  I would like to understand where I'm wrong ...
                  Thanks for your help 🍺
                  import os
                  import sys
                  from c4d import plugins, utils, bitmaps, gui, documents
                  PLUGIN_ID = 10000008 # THIS id IS FOR TESTING PUPOSES ONLY!!!
                  #for GeLoadString values must match with the header file
                  IDS_ESTENSIONE = 100000
                  MY_LINKBOX = 100015
                  class SettingsDialog(gui.SubDialog) :
                   **        self.linkBox = self.AddCustomGui(MY_LINKBOX, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0)**
                          self.GroupEnd()
                      def InitValues(self) :
                      def Command(self, id, msg) :
                  class Caleidos(plugins.ToolData) :
                          self.data = 0
                      def KeyboardInput(self, doc, data, bd, win, msg) :
                          key = msg.GetLong(c4d.BFM_INPUT_CHANNEL)
                          cstr = msg.GetString(c4d.BFM_INPUT_ASC)
                          if key==c4d.KEY_ESC:
                              #do what you want
                              #return True to signal that the key is processed
                          return False
                  		if msg.GetLong(c4d.BFM_INPUT_CHANNEL)==c4d.BFM_INPUT_MOUSELEFT:
                  			print "Begin Mouse Left Pressed"
                  			while True:
                  				bc = c4d.BaseContainer()
                  				if gui.GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, bc) :
                  					if bc.GetLong(c4d.BFM_INPUT_CHANNEL)==c4d.BFM_INPUT_MOUSELEFT:
                  						print "Mouse Left Pressed"
                  						device = 0
                  						doc.StartUndo()
                  						myobject = **self.linkBox.GetLink()**
                  						op = myobject
                  						op_next = doc.GetActiveObject()
                  							mx += dx
                  							my += dy
                  							length = 500000
                  							if did_intersect:
                     						if not bc.GetBool(c4d.BFM_INPUT_VALUE) : break
                  			print "End Mouse Left Pressed"
                      def AllocSubDialog(self, bc) :
                          return SettingsDialog(self.data) #always return new instance(self.data)
                      bmp = bitmaps.BaseBitmap()
                      fn = os.path.join(dir, "res", "Icon.tif")
                      bmp.InitWith(fn)
                      plugins.RegisterToolPlugin(id=PLUGIN_ID, str="Caleidos",info=0, icon=bmp, help="Statusbar Text",dat=Caleidos())
                    On 12/01/2013 at 13:03, xxxxxxxx wrote:
                    this obviously won't work. i think you do not really understand what self means in python.
                    it is similar to this in c# or java. it is a referecne to the actual instance of the class from which
                    the code is being executed from. you are doing more or less this :
                    class clsA() :
                    	def __init__(self, x) :
                    		self.X = x
                    class clsB() :
                    	def someMethod() :
                    		# raises a runtime error as class b does not have a memeber called X
                    		print self.X
                    you have either make your dialog class instance a globally available variable (but this
                    could be considered as really bad style) :
                    class clsA() :
                            self.X = x
                    class clsB() :
                        def do (self, classAinstance) :
                            print classAinstance.X
                        A = clsA()
                        B = clsB()
                        B.do(A)
                    or you have to make an instance of your GeDialog class a memeber of your
                    ToolData class.
                    class ToolDataClass() :
                            self.dialog = None
                            self.data = None
                        def doSomething(self) :
                            if (self.dialog) :
                                print self.Dialog.linkBox.GetLink(document, c4d.Obase)
                                print 'dialog has not been raised yet.'
                            self.Dialog = SettingsDialog(self.data)
                            return self.Dialog
                    edit : fixed a typo,  should be if (self.dialog) : of course and not if(self.data) :
                      ToolData class.
                              self.dialog = None
                              self.data = None
                              if (self.dialog) :
                              return self.Dialog
                      Work!!! I succeeded! littledevil Thanks!!!!!!! 🤝
                        You need to use the c4d.utils.GeRayCollider class to find an intersection on the surface of the
                        destination-object, intersected by the line defined by the mouse-position in global space and
                        the camera position.
                              op_next = op.GetNext()
                              if not op_next:
                        # Convert op_next to a polygon object.
                              # Simplified here, just for demonstration purpose.
                              op_next = op_next.GetCache()
                              if not op_next or not op_next.CheckType(c4d.Opolygon) :
                                  print "Cache is not existent or is not a polygon object."
                                  mx += dx
                                  my += dy
                                  if(axis == 1) :
                                      cursorpos.x = 0
                                  elif(axis == 2) :
                                      cursorpos.y = 0                          #Constrain drawing along an axis based on the comboButton's value
                                  elif(axis == 3) :
                                      cursorpos.z = 0
                        length = 500000
                                  if did_intersect:
                                      position = collider.GetNearestIntersection()['hitpos']
                        -Nik
                        an example for snap on point object? thanks 🙂
                          What do you mean with "the snap does not work"? You are not even trying to snap the
                          object, just setting it to the cursor position.
                          joint.SetAbsPos(cursorpos)
                          If you want to to snap to a grid with a spacing of 50 units (just for the sake of example), you
                          need to adjust the position vector.
                          def snap_value(value, step) :
                                rest = value % step
                                on_grid = value - rest
                          if rest / float(step) >= 0.5:
                                    on_grid += step
                          return on_grid
                          def snap_grid(vector, gridsize) :
                                vector = c4d.Vector(vector)
                                vector.x = snap_value(vector.x, gridsize)
                                vector.y = snap_value(vector.y, gridsize)
                                vector.z = snap_value(vector.z, gridsize)
                                return vector
                          gridsize = 50
                            position = snap_grid(cursorpos)
                            joint.SetAbsPos(position)
                          See the full code here.
                          -Niklas
                          HI NiklasR How do you adjust the cursor position for snap points ? 🙂
                            Assuming you have a coordinate in 3D space, you can just use the nearest mesh point and maybe
                            check if the point is within the snap radius.
                                def snap_point(point, radius, obj) :
                                    Calculate the snapping point from a coordinate in 3D space
                                    to a point object within the defined \*radius\*. Requires
                                    the \*point\* in global space.
                                    mg = obj.GetMg()
                                    points = obj.GetAllPoints()
                                    point = ~mg \* point
                                    radius \*\*= 2
                                    nearest = None
                                    for p in points:
                                        delta = (p - point).GetLengthSquared()
                                        if delta <= radius and (not nearest or nearest[1] > delta) :
                                            nearest = p, delta
                                    if nearest:
                                        point = nearest[0]
                                    return point
                                    p = c4d.Vector(102, 99, 97)
                                    print snap_point(p, 10, op)
                            Best regards,
                            -Niklas
                              You can not "adjust" the cursor position, the cursor is where the mouse points it to. There is also
                              a snapping mode for snapping to object points, so what exactly do you need?
                              -Niklas
