    Snap object in mouse input
    25 Posts 0 Posters 17.7k Views
      On 08/01/2013 at 09:19, xxxxxxxx wrote:
      What do you mean with "the snap does not work"? You are not even trying to snap the
      object, just setting it to the cursor position.
      joint.SetAbsPos(cursorpos)
      If you want to to snap to a grid with a spacing of 50 units (just for the sake of example), you
      need to adjust the position vector.
      def snap_value(value, step) :
            rest = value % step
            on_grid = value - rest
      if rest / float(step) >= 0.5:
                on_grid += step
      return on_grid
      def snap_grid(vector, gridsize) :
            vector = c4d.Vector(vector)
            vector.x = snap_value(vector.x, gridsize)
            vector.y = snap_value(vector.y, gridsize)
            vector.z = snap_value(vector.z, gridsize)
            return vector
      gridsize = 50
        position = snap_grid(cursorpos)
        joint.SetAbsPos(position)
      See the full code here.
      -Niklas
        On 08/01/2013 at 09:41, xxxxxxxx wrote:
        Thanks NiklasR, excuse my bad English ... I would like to know how to snap the active object on another object...
          On 08/01/2013 at 09:45, xxxxxxxx wrote:
          And what do you mean with "snapping it to another object"? To what part of the other object?
          The other objects' position, points, surface, or whatever?
          -Nik
            On 08/01/2013 at 09:56, xxxxxxxx wrote:
            Surface 👍
              On 08/01/2013 at 10:15, xxxxxxxx wrote:
              You need to use the c4d.utils.GeRayCollider class to find an intersection on the surface of the
              destination-object, intersected by the line defined by the mouse-position in global space and
              the camera position.
              op = doc.GetActiveObject()
                    op_next = op.GetNext()
                    if not op_next:
              # Convert op_next to a polygon object.
                    # Simplified here, just for demonstration purpose.
                    op_next = op_next.GetCache()
                    if not op_next or not op_next.CheckType(c4d.Opolygon) :
                        print "Cache is not existent or is not a polygon object."
                    win.MouseDragStart(button=device, mx=int(mx), my=int(my), flags=c4d.MOUSEDRAGFLAGS_DONTHIDEMOUSE)
                    result, dx, dy, channel = win.MouseDrag()
                    while result==c4d.MOUSEDRAGRESULT_CONTINUE:
                        mx += dx
                        my += dy
                        cursorpos = bd.SW(c4d.Vector(mx,my,500))     #screen to world conversion
                        if(axis == 1) :
                            cursorpos.x = 0
                        elif(axis == 2) :
                            cursorpos.y = 0                          #Constrain drawing along an axis based on the comboButton's value
                        elif(axis == 3) :
                            cursorpos.z = 0
              cam_pos = bd.GetSceneCamera(doc).GetAbsPos()
                        collider = c4d.utils.GeRayCollider()
                        collider.Init(op_next)
              length = 500000
                        direction = -(cam_pos - cursorpos).GetNormalized()
              did_intersect = collider.Intersect(cam_pos, direction, length)
                        if did_intersect:
                            position = collider.GetNearestIntersection()['hitpos']
                            print "Intersection at", position
                            print "No intersection."
                            position = cursorpos
                        op.SetAbsPos(position)
                        op.Message(c4d.MSG_UPDATE)
              c4d.DrawViews(c4d.DA_ONLY_ACTIVE_VIEW|c4d.DA_NO_THREAD|c4d.DA_NO_ANIMATION)
              -Nik
                On 08/01/2013 at 10:25, xxxxxxxx wrote:
                what do you mean with surface snapping 🙂
                1. snap onto the polygon polygon centers, which is basically just a weighted
                point snapping. get the vectors between your snap position and  the points of your
                snapping objects, select the three shortest vectors out of that list, get the polygon,
                use the points to calc the center.
                2. actually snap onto the closest point on a polygon (in a retopo fashion). you would
                have to dig yourself through this. i have actually done this once, but i cannot share
                the code but i still have the links i relied on then. you hvae basically do everything like
                for no. 1 and then solve the the closest point in triangle problem.
                http://www.geometrictools.com/Documentation/DistancePoint3Triangle3.pdf
                http://www.gamedev.net/topic/552906-closest-point-on-triangle/
                http://www.blackpawn.com/texts/pointinpoly/default.html
                edit : ok that is also a way. i am usally not so good at this wrap your head arround math stuff,
                but won't a camera 'normal' based snapping lead to funny results ?  the point which is sitting
                perpendicular on the viewplane does not have to be closest point, which at least I would
                associate with polygon snapping. i would call it view dependent obstacle snapping or something
                like that 🙂 or am i missing something here (again) ?
                  On 08/01/2013 at 10:42, xxxxxxxx wrote:
                  Hi Ferdinand,
                  I'm not sure what you mean with "camera 'normal' based snappin lead to funny results". Possibly
                  I just should get some sleep, but would you mind to elaborate a little bit more on what you are
                  talking about? 🙂
                  Thanks for the resources, I've always been interested into that topic but these links are new
                  to me!
                  -Nik
                    On 08/01/2013 at 10:48, xxxxxxxx wrote:
                    Thank you so much for your help, now everything is much more understandable ^_^
                    Thanks NiklasR 👍 and Thanks littledevil 👍
                      On 08/01/2013 at 10:53, xxxxxxxx wrote:
                      as I already said this might be based on a misconeption of your code,
                      but this is what is was talking about. (awesome paint pic inc.) :
                      the red line is what your code will return for my understanding, the green line is
                      the closest point on surface. at least i would consider the red result as unwanted
                      or 'funny'.
                      edit : i hope this does make any sense for someone else than me 🙂
                              if not op_next:
                                  mx += dx
                                  my += dy
                                  if(axis == 1) :
                                      cursorpos.x = 0
                                  elif(axis == 2) :
                                  elif(axis == 3) :
                                      cursorpos.z = 0
                        length = 500000
                                  if did_intersect:
                        -Nik
                        I again disorder 🙂
                        I wanted that the active object changed the axis alignment, as the normal to the surfaced intersection?
                        example:
                        the current code
                        my request:
                        The axis changed by surface normal...
                          On 09/01/2013 at 11:48, xxxxxxxx wrote:
                          What about trying it yourself? 😉
                          Slight tip: The dictionary returned by GeRayCollider.GetNearestIntersection() contains information
                          like what polygon was interesected. You can then compute the normal of that polygon and rotate
                          the destination object accordingly.
                          @ littledevil :
                          Well, we don't want the closes point on the surface, do we? I'm sorry, I don't see why the green
                          line is the one we would like to use instead of the red line.. :// I also don't get how you would
                          come to that green line, I don't see any relation to the camera position or view-direction or similar.
                          Hope that doesn't sound offending or so, because that was not my intention. I always
                          appreciate constructive criticism or questions. 🙂
                          Best,
                          -Niklas
                            On 09/01/2013 at 12:13, xxxxxxxx wrote:
                            NiklasR we are successful!🤝  Thank you for your precious help 🍺🍺
                              On 12/01/2013 at 03:43, xxxxxxxx wrote:
                              i have modified the  **op_next  **with Linkbox but... no work...
                              The object is not recognized...
                              I've never had much luck with the linkbox 😂
                              MY_LINKBOX = 100014
                              def CreateLayout(self) :
                                      self.GroupBegin(id=1000, flags=c4d.BFH_SCALEFIT, cols=1, rows=1)
                                      self.GroupBorderSpace(10, 10, 10, 10)
                                      self.element = self.AddStaticText(id=1001, flags=c4d.BFH_MASK, initw=120, name="Inserire Oggetto:", borderstyle=c4d.BORDER_NONE)
                                      self.linkBox = self.AddCustomGui(MY_LINKBOX, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0)
                                      self.GroupEnd()
                              def MouseInput(self, doc, data, bd, win, msg) :
                                      mx = msg[c4d.BFM_INPUT_X]
                                      my = msg[c4d.BFM_INPUT_Y]
                                      device = 0
                                      if msg[c4d.BFM_INPUT_CHANNEL]==c4d.BFM_INPUT_MOUSELEFT:
                                          device = c4d.KEY_MLEFT
                                      elif msg[c4d.BFM_INPUT_CHANNEL]==c4d.BFM_INPUT_MOUSERIGHT:
                                           device = c4d.KEY_MRIGHT
                                      op_next = self.linkBox.GetLink()
                                      if not op_next:
                                          mx += dx
                                          my += dy
                              length = 500000
                                          if did_intersect:
                                              position = collider.GetNearestIntersection()["hitpos"]
                                On 12/01/2013 at 07:22, xxxxxxxx wrote:
                                try :
                                op_next = self.linkBox.GetLink(c4d.documents.GetActiveDocument(), c4d.Obase)
                                  try :
                                  "object has no attribute 'linkBox'"....
                                  I am beginning to think that linkbox they hate me 😂
                                  Thanks littledevil, you are a generous person, always ready to help all friends in this forum 👍
                                    On 12/01/2013 at 10:37, xxxxxxxx wrote:
                                    could be some kind of call order problem. try something like this
                                    class myclass(c4d.Something) :
                                    	def __init__(self) :
                                    		self.linkBox = None
                                    	def CreateLayout(self, *args) :
                                    		self.linkBox = Something
                                    	def AnotherMethod(self) :
                                    		if (not self.linkBox) :
                                    			return False
                                    			x = self.linkBox.Do(blah)
                                    MouseInput might be called the first time before CreateLayout has been called and as you
                                    haven't defined linkBox as a variable in the class constructor it does not yet exist at that point.
                                      On 12/01/2013 at 12:08, xxxxxxxx wrote:
                                      littledevil, i have pasted the entire code.
                                      You can control it and correct it?
                                      I would like to understand where I'm wrong ...
                                      Thanks for your help 🍺
                                      import os
                                      import sys
                                      from c4d import plugins, utils, bitmaps, gui, documents
                                      PLUGIN_ID = 10000008 # THIS id IS FOR TESTING PUPOSES ONLY!!!
                                      #for GeLoadString values must match with the header file
                                      IDS_ESTENSIONE = 100000
                                      MY_LINKBOX = 100015
                                      class SettingsDialog(gui.SubDialog) :
                                       **        self.linkBox = self.AddCustomGui(MY_LINKBOX, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0)**
                                              self.GroupEnd()
                                          def InitValues(self) :
                                          def Command(self, id, msg) :
                                      class Caleidos(plugins.ToolData) :
                                              self.data = 0
                                          def KeyboardInput(self, doc, data, bd, win, msg) :
                                              key = msg.GetLong(c4d.BFM_INPUT_CHANNEL)
                                              cstr = msg.GetString(c4d.BFM_INPUT_ASC)
                                              if key==c4d.KEY_ESC:
                                                  #do what you want
                                                  #return True to signal that the key is processed
                                              return False
                                      		if msg.GetLong(c4d.BFM_INPUT_CHANNEL)==c4d.BFM_INPUT_MOUSELEFT:
                                      			print "Begin Mouse Left Pressed"
                                      			while True:
                                      				bc = c4d.BaseContainer()
                                      				if gui.GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, bc) :
                                      					if bc.GetLong(c4d.BFM_INPUT_CHANNEL)==c4d.BFM_INPUT_MOUSELEFT:
                                      						print "Mouse Left Pressed"
                                      						device = 0
                                      						doc.StartUndo()
                                      						myobject = **self.linkBox.GetLink()**
                                      						op = myobject
                                      						op_next = doc.GetActiveObject()
                                      							mx += dx
                                      							my += dy
                                      							length = 500000
                                      							if did_intersect:
                                         						if not bc.GetBool(c4d.BFM_INPUT_VALUE) : break
                                      			print "End Mouse Left Pressed"
                                          def AllocSubDialog(self, bc) :
                                              return SettingsDialog(self.data) #always return new instance(self.data)
                                          bmp = bitmaps.BaseBitmap()
                                          fn = os.path.join(dir, "res", "Icon.tif")
                                          bmp.InitWith(fn)
                                          plugins.RegisterToolPlugin(id=PLUGIN_ID, str="Caleidos",info=0, icon=bmp, help="Statusbar Text",dat=Caleidos())
                                        On 12/01/2013 at 13:03, xxxxxxxx wrote:
                                        this obviously won't work. i think you do not really understand what self means in python.
                                        it is similar to this in c# or java. it is a referecne to the actual instance of the class from which
                                        the code is being executed from. you are doing more or less this :
                                        class clsA() :
                                        	def __init__(self, x) :
                                        		self.X = x
                                        class clsB() :
                                        	def someMethod() :
                                        		# raises a runtime error as class b does not have a memeber called X
                                        		print self.X
                                        you have either make your dialog class instance a globally available variable (but this
                                        could be considered as really bad style) :
                                        class clsA() :
                                                self.X = x
                                        class clsB() :
                                            def do (self, classAinstance) :
                                                print classAinstance.X
                                            A = clsA()
                                            B = clsB()
                                            B.do(A)
                                        or you have to make an instance of your GeDialog class a memeber of your
                                        ToolData class.
                                        class ToolDataClass() :
                                                self.dialog = None
                                                self.data = None
                                            def doSomething(self) :
                                                if (self.dialog) :
                                                    print self.Dialog.linkBox.GetLink(document, c4d.Obase)
                                                    print 'dialog has not been raised yet.'
                                                self.Dialog = SettingsDialog(self.data)
                                                return self.Dialog
                                        edit : fixed a typo,  should be if (self.dialog) : of course and not if(self.data) :
                                          ToolData class.
                                                  self.dialog = None
                                                  self.data = None
                                                  if (self.dialog) :
                                                  return self.Dialog
                                          Work!!! I succeeded! littledevil Thanks!!!!!!! 🤝
                                                  if not op_next:
                                                      mx += dx
                                                      my += dy
                                                      if(axis == 1) :
                                                          cursorpos.x = 0
                                                      elif(axis == 2) :
                                                      elif(axis == 3) :
                                                          cursorpos.z = 0
                                            length = 500000
                                                      if did_intersect:
                                            -Nik
                                            an example for snap on point object? thanks 🙂
