Snap object in mouse input
On 05/01/2013 at 12:00, xxxxxxxx wrote:
Hi
i have used the free script code "SplineDraw" by Scott Ayers
http://sites.google.com/site/scottayersmedia/SplineDraw_Python.zip?attredirects=0My code, move the active object on mouse position.
but the snap not work...
is there a way to snap the active object to another object?
Thanksimport c4d import os import time from c4d import gui, plugins, bitmaps PLUGIN_ID = 1028184 #for GeLoadString values must match with the header file IDS_SPLINEDRAW = 50000 MY_COMBOBUTTON = 100012 MY_EDITNUMBER = 100013 def ArrangeJoints(doc,obj) : #This method will be used to arrange the drawn object in a parent->child tree later on obj = doc.GetFirstObject() child = obj.GetDown() while child: child.SetBit(c4d.BIT_ACTIVE) m = child.GetMg() if child.GetNext() is not None: next = child.GetNext() child.InsertUnder(next) child.SetMg(m) child = child.GetNext() class SettingsDialog(gui.SubDialog) : myDict = {'Axis_Snap':0, 'spacevalue':0} #Create a dictionary that will hold the names & values we'll use to plugin values into the gui items def __init__(self, arg) : self.myDict = arg def InitDialog(self) : bc = c4d.plugins.GetToolData(c4d.documents.GetActiveDocument(),PLUGIN_ID) #Gets the tools container data if needed if bc == None: return False return True def CreateLayout(self) : self.GroupBegin(id=1000, flags=c4d.BFH_SCALEFIT, cols=2, rows=1) self.GroupBorderSpace(10, 10, 10, 10) self.element = self.AddStaticText(id=1001, flags=c4d.BFH_MASK, initw=120, name="Drawing Mode", borderstyle=c4d.BORDER_NONE) self.AddComboBox(MY_COMBOBUTTON, c4d.BFH_CENTER, 150, 15, specialalign=False) #Adds combobox button gizmo to the GUI self.AddChild(MY_COMBOBUTTON, 0, "FaceScreen&i" + str(c4d.RESOURCEIMAGE_MOVE) + "&") #Adds the move icon to the first button option self.AddChild(MY_COMBOBUTTON, 1, "Lock Along Z" ) self.AddChild(MY_COMBOBUTTON, 2, "Lock On Floor") self.AddChild(MY_COMBOBUTTON, 3, "Lock Along X") self.SetLong(MY_COMBOBUTTON, self.myDict['Axis_Snap']) #Sets the button to the value of the Axis_Snap variable self.element = self.AddStaticText(id=1002, flags=c4d.BFH_MASK, initw=120, name="Spacing", borderstyle=c4d.BORDER_NONE) self.AddEditNumberArrows(MY_EDITNUMBER, c4d.BFH_MASK, 20, 0) #width=20, height=0 self.SetReal(MY_EDITNUMBER, self.myDict['spacevalue'], 0.0, 100, 1) #min=0.0, max=0.25, step=.01 self.GroupEnd() return True def InitValues(self) : self.SetLong(MY_COMBOBUTTON, 0) #Sets the combobox to the first option when plugin opens return True def Command(self, id, msg) : if id==MY_COMBOBUTTON: self.myDict['Axis_Snap'] = self.GetLong(MY_COMBOBUTTON) #If the button is changed. Get the new value if id==MY_EDITNUMBER: self.myDict['spacevalue'] = self.GetReal(MY_EDITNUMBER) #If the value is changed. Get the new value return True class SplineDraw(plugins.ToolData) : """Inherit from ToolData to create your own tool""" def __init__(self) : self.data = dict(Axis_Snap=0, spacevalue=0.0) def GetState(self, doc) : if doc.GetMode()==c4d.Mpaint: return 0 return c4d.CMD_ENABLED def KeyboardInput(self, doc, data, bd, win, msg) : key = msg.GetLong(c4d.BFM_INPUT_CHANNEL) cstr = msg.GetString(c4d.BFM_INPUT_ASC) if key==c4d.KEY_ESC: #do what you want #return True to signal that the key is processed return True return False def MouseInput(self, doc, data, bd, win, msg) : mx = msg[c4d.BFM_INPUT_X] my = msg[c4d.BFM_INPUT_Y] device = 0 if msg[c4d.BFM_INPUT_CHANNEL]==c4d.BFM_INPUT_MOUSELEFT: device = c4d.KEY_MLEFT elif msg[c4d.BFM_INPUT_CHANNEL]==c4d.BFM_INPUT_MOUSERIGHT: device = c4d.KEY_MRIGHT else: return True axis = self.data['Axis_Snap'] #Get the Axis_Snap key name from myDict in the subdialog and assign it to a variable spacing = self.data['spacevalue'] #Get the spacevalue key name from myDict in the subdialog and assign it to a variable #Spline stuff here doc.StartUndo() dx = 0.0 dy = 0.0 win.MouseDragStart(button=device, mx=int(mx), my=int(my), flags=c4d.MOUSEDRAGFLAGS_DONTHIDEMOUSE) result, dx, dy, channel = win.MouseDrag() while result==c4d.MOUSEDRAGRESULT_CONTINUE: mx += dx my += dy cursorpos = bd.SW(c4d.Vector(mx,my,400)) #screen to world conversion if(axis == 1) : cursorpos.x = 0 elif(axis == 2) : cursorpos.y = 0 #Constrain drawing along an axis based on the comboButton's value elif(axis == 3) : cursorpos.z = 0 joint = doc.GetActiveObject() #Add joints which we will later convert to a spline doc.AddUndo(c4d.UNDOTYPE_NEW, joint) bc = joint.GetData() joint.SetAbsPos(cursorpos) joint.SetData(bc) joint.Message(c4d.MSG_UPDATE) c4d.DrawViews(c4d.DA_ONLY_ACTIVE_VIEW|c4d.DA_NO_THREAD|c4d.DA_NO_ANIMATION) result, dx, dy, channel = win.MouseDrag() if win.MouseDragEnd()==c4d.MOUSEDRAGRESULT_ESCAPE: print "Hello World" c4d.EventAdd() return True def Draw(self, doc, data, bd, bh, bt, flags) : return c4d.TOOLDRAW_HANDLES|c4d.TOOLDRAW_AXIS def GetCursorInfo(self, doc, data, bd, x, y, bc) : if bc.GetId()==c4d.BFM_CURSORINFO_REMOVE: return True bc.SetString(c4d.RESULT_BUBBLEHELP, plugins.GeLoadString(IDS_SPLINEDRAW)) bc.SetLong(c4d.RESULT_CURSOR, c4d.MOUSE_SPLINETOOLS) return True def AllocSubDialog(self, bc) : return SettingsDialog(self.data) #always return new instance(self.data) if __name__ == "__main__": bmp = bitmaps.BaseBitmap() dir, file = os.path.split(__file__) fn = os.path.join(dir, "res", "Icon.tif") bmp.InitWith(fn) plugins.RegisterToolPlugin(id=PLUGIN_ID, str="SplineDraw",info=0, icon=bmp, help="Statusbar Text",dat=SplineDraw())
On 08/01/2013 at 09:05, xxxxxxxx wrote:
up ^_^
On 08/01/2013 at 09:19, xxxxxxxx wrote:
What do you mean with "the snap does not work"? You are not even trying to snap the
object, just setting it to the cursor position.joint.SetAbsPos(cursorpos)
If you want to to snap to a grid with a spacing of 50 units (just for the sake of example), you
need to adjust the position vector.def snap_value(value, step) :
rest = value % step
on_grid = value - restif rest / float(step) >= 0.5:
on_grid += stepreturn on_grid
def snap_grid(vector, gridsize) :
vector = c4d.Vector(vector)
vector.x = snap_value(vector.x, gridsize)
vector.y = snap_value(vector.y, gridsize)
vector.z = snap_value(vector.z, gridsize)
return vector# ...
gridsize = 50
position = snap_grid(cursorpos)
joint.SetAbsPos(position)See the full code here.
-Niklas
On 08/01/2013 at 09:41, xxxxxxxx wrote:
Thanks NiklasR, excuse my bad English ... I would like to know how to snap the active object on another object...
On 08/01/2013 at 09:45, xxxxxxxx wrote:
And what do you mean with "snapping it to another object"? To what part of the other object?
The other objects' position, points, surface, or whatever?-Nik
On 08/01/2013 at 09:56, xxxxxxxx wrote:
Surface
On 08/01/2013 at 10:15, xxxxxxxx wrote:
You need to use the c4d.utils.GeRayCollider class to find an intersection on the surface of the
destination-object, intersected by the line defined by the mouse-position in global space and
the camera position.op = doc.GetActiveObject()
op_next = op.GetNext()
if not op_next:
return True# Convert op_next to a polygon object.
# Simplified here, just for demonstration purpose.
op_next = op_next.GetCache()
if not op_next or not op_next.CheckType(c4d.Opolygon) :
print "Cache is not existent or is not a polygon object."
mx += dx
my += dy
cursorpos = bd.SW(c4d.Vector(mx,my,500)) #screen to world conversion
if(axis == 1) :
cursorpos.x = 0
elif(axis == 2) :
elif(axis == 3) :
cursorpos.z = 0cam_pos = bd.GetSceneCamera(doc).GetAbsPos()
collider = c4d.utils.GeRayCollider()
collider.Init(op_next)length = 500000
direction = -(cam_pos - cursorpos).GetNormalized()did_intersect = collider.Intersect(cam_pos, direction, length)
if did_intersect:
position = collider.GetNearestIntersection()['hitpos']
print "Intersection at", position
print "No intersection."
position = cursorposdoc.AddUndo(c4d.UNDOTYPE_CHANGE, op)
op.SetAbsPos(position)
op.Message(c4d.MSG_UPDATE)c4d.DrawViews(c4d.DA_ONLY_ACTIVE_VIEW|c4d.DA_NO_THREAD|c4d.DA_NO_ANIMATION)
result, dx, dy, channel = win.MouseDrag()-Nik
On 08/01/2013 at 10:25, xxxxxxxx wrote:
what do you mean with surface snapping
1. snap onto the polygon polygon centers, which is basically just a weighted
point snapping. get the vectors between your snap position and the points of your
snapping objects, select the three shortest vectors out of that list, get the polygon,
use the points to calc the center.2. actually snap onto the closest point on a polygon (in a retopo fashion). you would
have to dig yourself through this. i have actually done this once, but i cannot share
the code but i still have the links i relied on then. you hvae basically do everything like
for no. 1 and then solve the the closest point in triangle problem.http://www.geometrictools.com/Documentation/DistancePoint3Triangle3.pdf
http://www.gamedev.net/topic/552906-closest-point-on-triangle/
http://www.blackpawn.com/texts/pointinpoly/default.htmledit : ok that is also a way. i am usally not so good at this wrap your head arround math stuff,
but won't a camera 'normal' based snapping lead to funny results ? the point which is sitting
perpendicular on the viewplane does not have to be closest point, which at least I would
associate with polygon snapping. i would call it view dependent obstacle snapping or something
like that or am i missing something here (again) ? -
On 08/01/2013 at 10:42, xxxxxxxx wrote:
Hi Ferdinand,
I'm not sure what you mean with "camera 'normal' based snappin lead to funny results". Possibly
I just should get some sleep, but would you mind to elaborate a little bit more on what you are
talking about?Thanks for the resources, I've always been interested into that topic but these links are new
to me!-Nik
On 08/01/2013 at 10:48, xxxxxxxx wrote:
Thank you so much for your help, now everything is much more understandable ^_^
Thanks NiklasR and Thanks littledevil
On 08/01/2013 at 10:53, xxxxxxxx wrote:
as I already said this might be based on a misconeption of your code,
but this is what is was talking about. (awesome paint pic inc.) :the red line is what your code will return for my understanding, the green line is
the closest point on surface. at least i would consider the red result as unwanted
or 'funny'.edit : i hope this does make any sense for someone else than me
if not op_next:
mx += dx
my += dy
if(axis == 1) :
cursorpos.x = 0
elif(axis == 2) :
elif(axis == 3) :
if did_intersect:
I again disorder
I wanted that the active object changed the axis alignment, as the normal to the surfaced intersection?
example:the current code
my request:
The axis changed by surface normal...
On 09/01/2013 at 11:48, xxxxxxxx wrote:
What about trying it yourself?
Slight tip: The dictionary returned by GeRayCollider.GetNearestIntersection() contains information
like what polygon was interesected. You can then compute the normal of that polygon and rotate
the destination object accordingly.@ littledevil :
Well, we don't want the closes point on the surface, do we? I'm sorry, I don't see why the green
line is the one we would like to use instead of the red line.. :// I also don't get how you would
come to that green line, I don't see any relation to the camera position or view-direction or similar.Hope that doesn't sound offending or so, because that was not my intention. I always
appreciate constructive criticism or questions.
Best,
-Niklas -
On 09/01/2013 at 12:13, xxxxxxxx wrote:
NiklasR we are successful! Thank you for your precious help
On 12/01/2013 at 03:43, xxxxxxxx wrote:
i have modified the **op_next **with Linkbox but... no work...
The object is not recognized...I've never had much luck with the linkbox
MY_LINKBOX = 100014
self.GroupBegin(id=1000, flags=c4d.BFH_SCALEFIT, cols=1, rows=1)
self.element = self.AddStaticText(id=1001, flags=c4d.BFH_MASK, initw=120, name="Inserire Oggetto:", borderstyle=c4d.BORDER_NONE)
self.linkBox = self.AddCustomGui(MY_LINKBOX, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0)
self.GroupEnd()
return Truedef MouseInput(self, doc, data, bd, win, msg) :
device = 0
return Trueop = doc.GetActiveObject()
op_next = self.linkBox.GetLink()
if not op_next:
return Truewin.MouseDragStart(button=device, mx=int(mx), my=int(my), flags=c4d.MOUSEDRAGFLAGS_DONTHIDEMOUSE)
mx += dx
my += dycursorpos = bd.SW(c4d.Vector(mx,my,500)) #screen to world conversion
if did_intersect:
position = collider.GetNearestIntersection()["hitpos"]
result, dx, dy, channel = win.MouseDrag() -
On 12/01/2013 at 07:22, xxxxxxxx wrote:
try :
op_next = self.linkBox.GetLink(c4d.documents.GetActiveDocument(), c4d.Obase)
try :
"object has no attribute 'linkBox'"....
I am beginning to think that linkbox they hate meThanks littledevil, you are a generous person, always ready to help all friends in this forum
On 12/01/2013 at 10:37, xxxxxxxx wrote:
could be some kind of call order problem. try something like this
class myclass(c4d.Something) : def __init__(self) : self.linkBox = None def CreateLayout(self, *args) : self.linkBox = Something def AnotherMethod(self) : if (not self.linkBox) : return False else: x = self.linkBox.Do(blah)
MouseInput might be called the first time before CreateLayout has been called and as you
haven't defined linkBox as a variable in the class constructor it does not yet exist at that point. -
On 12/01/2013 at 12:08, xxxxxxxx wrote:
littledevil, i have pasted the entire code.
You can control it and correct it?
I would like to understand where I'm wrong ...
Thanks for your helpimport os import sys import c4d from c4d import plugins, utils, bitmaps, gui, documents PLUGIN_ID = 10000008 # THIS id IS FOR TESTING PUPOSES ONLY!!! #for GeLoadString values must match with the header file IDS_ESTENSIONE = 100000 MY_LINKBOX = 100015 class SettingsDialog(gui.SubDialog) : def CreateLayout(self) : self.GroupBegin(id=1000, flags=c4d.BFH_SCALEFIT, cols=1, rows=1) self.GroupBorderSpace(10, 10, 10, 10) self.element = self.AddStaticText(id=1001, flags=c4d.BFH_MASK, initw=120, name="Inserire Oggetto:", borderstyle=c4d.BORDER_NONE) ** self.linkBox = self.AddCustomGui(MY_LINKBOX, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0)** self.GroupEnd() return True def InitValues(self) : return True def Command(self, id, msg) : return True class Caleidos(plugins.ToolData) : def __init__(self) : self.data = 0 def KeyboardInput(self, doc, data, bd, win, msg) : key = msg.GetLong(c4d.BFM_INPUT_CHANNEL) cstr = msg.GetString(c4d.BFM_INPUT_ASC) if key==c4d.KEY_ESC: #do what you want #return True to signal that the key is processed return True return False def MouseInput(self, doc, data, bd, win, msg) : if msg.GetLong(c4d.BFM_INPUT_CHANNEL)==c4d.BFM_INPUT_MOUSELEFT: print "Begin Mouse Left Pressed" while True: bc = c4d.BaseContainer() if gui.GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSELEFT, bc) : if bc.GetLong(c4d.BFM_INPUT_CHANNEL)==c4d.BFM_INPUT_MOUSELEFT: print "Mouse Left Pressed" mx = msg[c4d.BFM_INPUT_X] my = msg[c4d.BFM_INPUT_Y] device = 0 if msg[c4d.BFM_INPUT_CHANNEL]==c4d.BFM_INPUT_MOUSELEFT: device = c4d.KEY_MLEFT elif msg[c4d.BFM_INPUT_CHANNEL]==c4d.BFM_INPUT_MOUSERIGHT: device = c4d.KEY_MRIGHT else: return True doc.GetActiveObject() doc.StartUndo() myobject = **self.linkBox.GetLink()** op = myobject op_next = doc.GetActiveObject() win.MouseDragStart(button=device, mx=int(mx), my=int(my), flags=c4d.MOUSEDRAGFLAGS_DONTHIDEMOUSE) result, dx, dy, channel = win.MouseDrag() while result==c4d.MOUSEDRAGRESULT_CONTINUE: mx += dx my += dy cursorpos = bd.SW(c4d.Vector(mx,my,500)) #screen to world conversion cam_pos = bd.GetSceneCamera(doc).GetAbsPos() collider = c4d.utils.GeRayCollider() collider.Init(op_next) length = 500000 direction = -(cam_pos - cursorpos).GetNormalized() did_intersect = collider.Intersect(cam_pos, direction, length) if did_intersect: position = collider.GetNearestIntersection()["hitpos"] print "Intersection at", position else: print "No intersection." position = cursorpos doc.AddUndo(c4d.UNDOTYPE_CHANGE, op) op.SetAbsPos(position) op.Message(c4d.MSG_UPDATE) c4d.DrawViews(c4d.DA_ONLY_ACTIVE_VIEW|c4d.DA_NO_THREAD|c4d.DA_NO_ANIMATION) result, dx, dy, channel = win.MouseDrag() if not bc.GetBool(c4d.BFM_INPUT_VALUE) : break print "End Mouse Left Pressed" def AllocSubDialog(self, bc) : return SettingsDialog(self.data) #always return new instance(self.data) if __name__ == "__main__": bmp = bitmaps.BaseBitmap() dir, file = os.path.split(__file__) fn = os.path.join(dir, "res", "Icon.tif") bmp.InitWith(fn) plugins.RegisterToolPlugin(id=PLUGIN_ID, str="Caleidos",info=0, icon=bmp, help="Statusbar Text",dat=Caleidos())
On 12/01/2013 at 13:03, xxxxxxxx wrote:
this obviously won't work. i think you do not really understand what self means in python.
it is similar to this in c# or java. it is a referecne to the actual instance of the class from which
the code is being executed from. you are doing more or less this :class clsA() : def __init__(self, x) : self.X = x class clsB() : def someMethod() : # raises a runtime error as class b does not have a memeber called X print self.X
you have either make your dialog class instance a globally available variable (but this
could be considered as really bad style) :class clsA() : def __init__(self, x) : self.X = x class clsB() : def do (self, classAinstance) : print classAinstance.X def main() : A = clsA() B = clsB() B.do(A)
or you have to make an instance of your GeDialog class a memeber of your
ToolData class.class ToolDataClass() : def __init__(self) : self.dialog = None self.data = None def doSomething(self) : if (self.dialog) : print self.Dialog.linkBox.GetLink(document, c4d.Obase) else: print 'dialog has not been raised yet.' def AllocSubDialog(self, bc) : self.Dialog = SettingsDialog(self.data) return self.Dialog
edit : fixed a typo, should be if (self.dialog) : of course and not if(self.data) :
