    Position Update
    20 Posts 0 Posters 2.5k Views
      On 15/03/2012 at 10:52, xxxxxxxx wrote:
      @lennart: Ah right! I knew I saw it somewhere! Your mind is genius ;O
        On 15/03/2012 at 11:37, xxxxxxxx wrote:
        Hi Lennart, Niklas,
        Its seems to me that it doesn't works... When I call "c4d.DrawViews" Cinema freeze.
        May be I wrote somenthing wrong...
        Here's my code:
        _
        _
        from c4d import documents
            fps     = doc.GetFps()
            frame = doc.GetTime().GetFrame(doc.GetFps())
            obj = op.GetObject()
            Distance = []
            for i in xrange (0, frame) :
                c4d.StatusSetBar(100*(i-0)/(frame-0))
                doc.SetTime(c4d.BaseTime(i,fps))
                c4d.DrawViews(c4d.DRAWFLAGS_ONLY_ACTIVE_VIEW|c4d.DRAWFLAGS_NO_THREAD|c4d.DRAWFLAGS_NO_REDUCTION|c4d.DRAWFLAGS_STATICBREAK)
                GPos = obj.GetAbsPos()
                c4d.GeSyncMessage(c4d.EVMSG_TIMECHANGED)
                Distance.append(GPos)
            doc.SetTime(c4d.BaseTime(frame,fps))
            c4d.EventAdd(c4d.EVENT_ANIMATE)
            c4d.StatusClear()
            print Distance
         _
        _
          On 15/03/2012 at 12:56, xxxxxxxx wrote:
          That example is for a Command setup, not runtime/expression.
          Typically to write to file and/or set keyframes etc.
          If you need to check object position at different frame(s) from current
          at runtime you might need to look into/use AnimateObject()
          Lennart
            On 15/03/2012 at 13:06, xxxxxxxx wrote:
            So you want to compute the distance an object traveled within a PythonTag? Why didn't you say so earlier? 😛
            I don't know why you want to store the distance between each frame in a list, anyway, just create a global-variable and store your data there. Iterating over the full timeline each frame is quite imperformant..
            import     c4d
            data = dict( distance = 0,
                       prevPos  = None )
              position = op.GetOrigin().GetAbsPos()
              # Check for `None` explicit because `prevPos` could
              # be `c4d.Vector(0)` which evaluates to `False`, too.
              if data['prevPos'] is None:
                  pass
                  data['distance'] += (position - data['prevPos']).GetLength()
              data['prevPos'] = position
              print data['distance']
            -Niklas
              On 15/03/2012 at 13:31, xxxxxxxx wrote:
              @ Lennart: Thanks for your reply, I will look immediately
              @ Niklas: wow, you save my life 👍 Thank you!!!!
                On 15/03/2012 at 13:54, xxxxxxxx wrote:
                For a bit of trivia in the matter, using the following
                in a Py Generator (Optimize Cache Off) will animate
                an animated object per frame and generate a spline of the path
                and read the total length 🙂
                Lennart
                from c4d.utils import SplineLengthData
                    fps           = doc.GetFps()
                    doctime       = doc.GetTime()
                    currentframe = doctime.GetFrame(fps)
                    start        = doc.GetMinTime().GetFrame(fps)
                    end           = doc.GetMaxTime().GetFrame(fps)
                    pspline       = c4d.BaseObject(c4d.Ospline)
                    pspline.ResizeObject(end,0)
                    obj = doc.SearchObject('Cube')# <- Animated Object
                    for i in xrange(end) :
                        doc.AnimateObject(obj,c4d.BaseTime(i, fps),c4d.ANIMATEFLAGS_0)
                        pspline.SetPoint(i,obj.GetAbsPos())
                    pspline.Message(c4d.MSG_UPDATE)
                    sld = SplineLengthData()
                    sld.Init(pspline,0)
                    tot = sld.GetLength()
                    print tot
                    sld.Free()
                    # Place obj back on track again
                    doc.AnimateObject(obj,c4d.BaseTime(currentframe,fps),c4d.ANIMATEFLAGS_0)
                    return pspline
                  On 15/03/2012 at 15:30, xxxxxxxx wrote:
                  wow Lennart,  I'm touched 🙂
                  Thank you so much
                    On 16/03/2012 at 04:21, xxxxxxxx wrote:
                    Hi Lennart,
                    just to know, why this code doesn't work fine now? The "Distance"list store alway the same vector again...
                        fps     = doc.GetFps()
                        Distance = []
                        for i in xrange (frame) :
                        print Distance
                    Luther
                      On 16/03/2012 at 07:00, xxxxxxxx wrote:
                      Please note that you must not call update functions or change the document structure within the execution functions of objects/tags/materials/... this might lead to crashs. From the c4d.threading module:
                      For all threaded functions it's forbidden to:
                      > 1. Add an Event.
                      > 2. Make any changes to materials.
                      > 3. Change the structure of objects attached to the scene.
                      > 4. Change parameters of elements attached to the scene (allowed, but not recommended except for tags).
                      > 5. Call a Draw function.
                      > 6. Perform any GUI functionality (e.g. displaying messages, opening dialogs etc.).
                      > 7. During drawing to do any file operations. (During execution t's allowed.)
                      > 8. Create undos.
                      Cheers, Sebastian
                        On 19/03/2012 at 05:42, xxxxxxxx wrote:
                        Hi Sebastian,
                        thanks for your note. Any suggestion for my last post?
                        Luther
                          On 21/03/2012 at 15:09, xxxxxxxx wrote:
                          The AnimateObject() function needs an animated object as far as I know.
                          That is , key framed in some fashion.
                          To run it safer, regarding Sebastians notes, do the AnimateObject() function
                          on a clone of the object (it is not inserted into the doc).
                          Lennart
