    Position Update
    20 Posts 0 Posters 2.5k Views
      On 15/03/2012 at 06:04, xxxxxxxx wrote:
      Hi Luther,
      Yes it is, I just wondered why you do it this way. 🙂 Yes it is a for-loop, but I wanted to know if you're calling op.GetMg().off within the for loop or not, i.e.
      for i in range(frame) : # same as range(0, frame), better use xrange by the way
          GPos = op.GetMg().off
      and not
      But that would be too obvious I guess, and anyway, even if you're doing that, it won't work... I just tested it and saw that the position is not updated by just setting the document time, and I don't know how to update it .. I know there is a way to do it, but c4d.EventAdd() nor c4d.GeSyncMessage() seem to fix that... sry 😄
      -niklas
        On 15/03/2012 at 06:40, xxxxxxxx wrote:
        In Py SDK, documents -> BaseDocument at the end,
        there is a example how to run thru the document.
        Lennart
          On 15/03/2012 at 07:06, xxxxxxxx wrote:
          Hi Niklas,
          thank you for your reply and your test...
          Anyway, anyone knows the way to update a value in a given frame?
          What is wrong in this code?
          _
          _
              fps     = doc.GetFps()
              frame = doc.GetTime().GetFrame(doc.GetFps())
              obj = op.GetObject()
              Distance = []
              for i in xrange (0, frame) :
                  doc.SetTime(c4d.BaseTime(i,fps))
                  c4d.GeSyncMessage(c4d.EVMSG_TIMECHANGED)
                  GPos = obj.GetAbsPos()
                  Distance.append(GPos)
                  doc.SetTime(c4d.BaseTime(frame,fps))
              print Distance # return a list of the same vector (in this case the position in the current frame)
           _
          _
          _
          _
          Luther
            On 15/03/2012 at 07:09, xxxxxxxx wrote:
            Ops...
            Hi Lennart, I wrote before read your post... I wil read the Sdk soon.
            Thank you
            Luther
              On 15/03/2012 at 10:52, xxxxxxxx wrote:
              @lennart: Ah right! I knew I saw it somewhere! Your mind is genius ;O
                On 15/03/2012 at 11:37, xxxxxxxx wrote:
                Hi Lennart, Niklas,
                Its seems to me that it doesn't works... When I call "c4d.DrawViews" Cinema freeze.
                May be I wrote somenthing wrong...
                Here's my code:
                _
                _
                from c4d import documents
                    fps     = doc.GetFps()
                    Distance = []
                        c4d.StatusSetBar(100*(i-0)/(frame-0))
                        c4d.DrawViews(c4d.DRAWFLAGS_ONLY_ACTIVE_VIEW|c4d.DRAWFLAGS_NO_THREAD|c4d.DRAWFLAGS_NO_REDUCTION|c4d.DRAWFLAGS_STATICBREAK)
                    c4d.EventAdd(c4d.EVENT_ANIMATE)
                    c4d.StatusClear()
                    print Distance
                 _
                _
                  On 15/03/2012 at 12:56, xxxxxxxx wrote:
                  That example is for a Command setup, not runtime/expression.
                  Typically to write to file and/or set keyframes etc.
                  If you need to check object position at different frame(s) from current
                  at runtime you might need to look into/use AnimateObject()
                  Lennart
                    On 15/03/2012 at 13:06, xxxxxxxx wrote:
                    So you want to compute the distance an object traveled within a PythonTag? Why didn't you say so earlier? 😛
                    I don't know why you want to store the distance between each frame in a list, anyway, just create a global-variable and store your data there. Iterating over the full timeline each frame is quite imperformant..
                    import     c4d
                    data = dict( distance = 0,
                               prevPos  = None )
                      position = op.GetOrigin().GetAbsPos()
                      # Check for `None` explicit because `prevPos` could
                      # be `c4d.Vector(0)` which evaluates to `False`, too.
                      if data['prevPos'] is None:
                          pass
                          data['distance'] += (position - data['prevPos']).GetLength()
                      data['prevPos'] = position
                      print data['distance']
                    -Niklas
                      On 15/03/2012 at 13:31, xxxxxxxx wrote:
                      @ Lennart: Thanks for your reply, I will look immediately
                      @ Niklas: wow, you save my life 👍 Thank you!!!!
                        On 15/03/2012 at 13:54, xxxxxxxx wrote:
                        For a bit of trivia in the matter, using the following
                        in a Py Generator (Optimize Cache Off) will animate
                        an animated object per frame and generate a spline of the path
                        and read the total length 🙂
                        Lennart
                        from c4d.utils import SplineLengthData
                            fps           = doc.GetFps()
                            doctime       = doc.GetTime()
                            currentframe = doctime.GetFrame(fps)
                            start        = doc.GetMinTime().GetFrame(fps)
                            end           = doc.GetMaxTime().GetFrame(fps)
                            pspline       = c4d.BaseObject(c4d.Ospline)
                            pspline.ResizeObject(end,0)
                            obj = doc.SearchObject('Cube')# <- Animated Object
                            for i in xrange(end) :
                                doc.AnimateObject(obj,c4d.BaseTime(i, fps),c4d.ANIMATEFLAGS_0)
                                pspline.SetPoint(i,obj.GetAbsPos())
                            pspline.Message(c4d.MSG_UPDATE)
                            sld = SplineLengthData()
                            sld.Init(pspline,0)
                            tot = sld.GetLength()
                            print tot
                            sld.Free()
                            # Place obj back on track again
                            doc.AnimateObject(obj,c4d.BaseTime(currentframe,fps),c4d.ANIMATEFLAGS_0)
                            return pspline
                          On 15/03/2012 at 15:30, xxxxxxxx wrote:
                          wow Lennart,  I'm touched 🙂
                          Thank you so much
                            On 16/03/2012 at 04:21, xxxxxxxx wrote:
                            Hi Lennart,
                            just to know, why this code doesn't work fine now? The "Distance"list store alway the same vector again...
                                fps     = doc.GetFps()
                                Distance = []
                                for i in xrange (frame) :
                                print Distance
                            Luther
                              On 16/03/2012 at 07:00, xxxxxxxx wrote:
                              Please note that you must not call update functions or change the document structure within the execution functions of objects/tags/materials/... this might lead to crashs. From the c4d.threading module:
                              For all threaded functions it's forbidden to:
                              > 1. Add an Event.
                              > 2. Make any changes to materials.
                              > 3. Change the structure of objects attached to the scene.
                              > 4. Change parameters of elements attached to the scene (allowed, but not recommended except for tags).
                              > 5. Call a Draw function.
                              > 6. Perform any GUI functionality (e.g. displaying messages, opening dialogs etc.).
                              > 7. During drawing to do any file operations. (During execution t's allowed.)
                              > 8. Create undos.
                              Cheers, Sebastian
                                On 19/03/2012 at 05:42, xxxxxxxx wrote:
                                Hi Sebastian,
                                thanks for your note. Any suggestion for my last post?
                                Luther
                                  On 21/03/2012 at 15:09, xxxxxxxx wrote:
                                  The AnimateObject() function needs an animated object as far as I know.
                                  That is , key framed in some fashion.
                                  To run it safer, regarding Sebastians notes, do the AnimateObject() function
                                  on a clone of the object (it is not inserted into the doc).
                                  Lennart
