    Still can't get a 64bit version compiled
    42 Posts 0 Posters 41.2k Views
      On 28/09/2006 at 07:25, xxxxxxxx wrote:
      Not sure what do you means, but just add __C4D_64BIT below WIN64. (with 2 lines on begining __C4D_64BIT)
      After this the errors must disapear.
      I use C4D 9.6 SDK!
      Remo
        On 28/09/2006 at 07:41, xxxxxxxx wrote:
        Howdy,
        Well, that didn't seem to work.
        The version I have may be 9.0, I don't know for sure because I'm on a 32bit machine trying to do a crossplatform compile and downloaded the 64bit demo quite some time ago when VS 2005 was in beta. I couldn't get it to work back then and when I decided to try again a little while back the beta had expired.
        I just recently upgrade to the VS 2005 Standard, so I can try again. Maybe I need to get rid of that older 64bit demo and download the latest one and start fresh?
        Adios,
        Cactus Dan
          On 29/09/2006 at 08:44, xxxxxxxx wrote:
          Howdy,
          OK, I'm a little confused now. I just deleted the older 64bit version 9 from my hard drive, and went to download the latest 64bit. But, I read on Maxon's site that the 64bit was included with the 9.6 update. So I look in my 9.6 update and sure enough there it is!
          So my question now is, how do I set up a 64bit compile for the cinema4dsdk project without screwing up the 32 bit project and the api? (remember, I'm on a 32bit machine)
          Adios,
          Cactus Dan
            On 29/09/2006 at 09:19, xxxxxxxx wrote:
            Howdy,
            OK, nevermind. I just made a copy of the folder and put it in another location and named it "Cinema 4D 9.6 64bit", just to keep it separate from the rest.
            And now, I have successfully compiled the cinema4dsdk project for 64bit. Yee-Ha! 🐵
            Adios,
            Cactus Dan
              On 29/09/2006 at 15:08, xxxxxxxx wrote:
              Dan,
              Great to hear! Now get to work! 😉
                On 29/09/2006 at 15:38, xxxxxxxx wrote:
                Howdy,
                Hehe, I'm on it. ;o)
                Adios,
                Cactus Dan
                  On 16/05/2007 at 06:13, xxxxxxxx wrote:
                  Howdy Dan,
                  can you tell me how this all works on a 32-bit platform? I cannot get it to work. In the configuration manager I don´t even get the x64 platform option. What do I need to get this running?
                    On 16/05/2007 at 06:22, xxxxxxxx wrote:
                    Howdy,
                    It seems that when installing MS Visual Studio 2005 Standard on a 32 bit machine, the default installation is 32 bit only. I had to go back and select the option to also install the 64 bit. That was something I missed the first time I installed, and had to reinstall it. 😞
                    Adios,
                    Cactus Dan
                      On 16/05/2007 at 06:27, xxxxxxxx wrote:
                      oh sh**. Thanks, I think I have also chosen 32-bit only back then. Argh..ok, I try a reinstallation. 🙂 Thanks so far!
                        On 16/05/2007 at 07:08, xxxxxxxx wrote:
                        Even on the 64-bit systems you have to be sure to select 64-bit for the install - at least I had this with VS2003. Maybe VS2005 now installs default for the target install system (?).
                        Good luck, Samir! 🙂
                          On 16/05/2007 at 07:09, xxxxxxxx wrote:
                          hmm, when I reinstall, I don´t get an option for 64-Bit in my express installation. Was it the Visual C++ express installation where this happened or is it the platform SDK that you mean?
                            On 16/05/2007 at 07:12, xxxxxxxx wrote:
                            Howdy,
                            AH! The "Express" version doesn't have the 64bit option. You need at least the "Standard" version. 😞
                            Adios,
                            Cactus Dan
                              On 16/05/2007 at 07:37, xxxxxxxx wrote:
                              As Cactus Dan says. :E
                                On 16/05/2007 at 07:42, xxxxxxxx wrote:
                                no problem robert, I was too lazy in the past to buy the standard version. Now that´s a good reason to finally do so. 😄 thx!
                                  On 16/05/2007 at 07:47, xxxxxxxx wrote:
                                  Howdy,
                                  There was an upgrade from MSVC++.net 2003 to MSVC++ 2005 Standard that saved me some money on it. 😉
                                  You may also have some sort of upgrade option.
                                  Adios,
                                  Cactus Dan
                                    On 16/05/2007 at 07:54, xxxxxxxx wrote:
                                    thanks for the hint. I´ll be checking on this. 🙂
                                      On 12/06/2007 at 10:53, xxxxxxxx wrote:
                                      Ok, now got my Standard installed (woosh, 5 fu*** CDs and a Service Pack update of 500 MB. Sigh, I miss the good ol C64 days. 🙂
                                      Anyway, it now works to get that compiler to do what it needs. But I get a C4311 error in the TreeView Function GetId()
                                      The migration docs say:
                                      "Watch out for type cast warnings. E.g. the line LONG converted_ptr = (LONG)&data; will result in a warning warning C4311: 'type cast' : pointer truncation from 'BaseContainer *' to 'LONG'.. You need to change this code to VLONG converted_ptr = (VLONG)&data;."
                                      And I am sure that I changed the function in my code correctly. Here it is:
                                      virtual VLONG GetId(void *root, void *userdata, void *obj)
                                           return (VLONG)obj;
                                      But I still get the error? The activeobject sdk example uses it in the same way.
                                      Anybody a clue why it´s not working?
                                      Thanks!
                                        On 12/06/2007 at 10:59, xxxxxxxx wrote:
                                        That's odd. Here's how I do it - note no typecasting to VLONG though:
                                        #ifdef WIN64
                                        VLONG GetId(void* root, void* userdata, void* obj)
                                             return ((RuntimeItem* )obj)->GetID();
                                        #else
                                          On 12/06/2007 at 11:12, xxxxxxxx wrote:
                                          Howdy,
                                          Hmmmm, that is odd because that is exactly the same as the SDK example.
                                          Did the SDK project compile fine?
                                          Adios,
                                          Cactus Dan
                                            On 12/06/2007 at 11:15, xxxxxxxx wrote:
                                            Hmm, maybe your LONG value will be casted automatically to VLONG at occurance. As my object has no ID value (cannot simply add it due to stability reasons unfortunately) so I cannot use it.
                                            But as I said, the activeobject example also uses a direct cast of the pointer and it works for me in a R10 32-bit compile. 😕
                                            @Cactus: Will try a sdk compile.
