    SetDrawParameter & LineZOffset
    37 Posts 0 Posters 26.9k Views
      On 29/09/2006 at 09:28, xxxxxxxx wrote:
      Howdy,
      > Quote: Originally posted by Michael Welter on 29ย Septemberย 2006
      > GetNodeData(), thanks for the hind. I was looking for something like this, but could not find it.
      Yes, I knew about that. It works well for being able to communicate between your plugin classes, to retrieve pointers to stored data.
      > Quote: _I still suggest that using a SceneHook will work. It allows more control over when the drawing happens ( highlight pass ) and the draw function should always be called. I'm convinced that bones are drawn this way.
      _
      I may give that a try, but maybe for the next update of the plugin. ;o)
      > Quote: It would be nice now to know for sure... Mikael ? David ?
      Yes, I would like to know for sure, too.
      Adios,
      Cactus Dan
        On 04/10/2006 at 11:43, xxxxxxxx wrote:
        It's surely a hack to call the object's Draw() function from the tag's, but I can't see how it could be dangerous. More like code reuse... ๐Ÿ™‚
        The Scenehook solution might be the simplest, though, provided that its Draw() function is always called after objects'.
          On 05/10/2006 at 20:24, xxxxxxxx wrote:
          Howdy,
          Thanks Mikael, I'll consider giving that a try when I do another update. ;o)
          Adios,
          Cactus Dan
            On 06/02/2007 at 13:48, xxxxxxxx wrote:
            Dan,
            Did you ever find a solution here and what was it? ๐Ÿ™‚
            I am looking into something similar for my bones while some other related features are added.
            If you went with a SceneHook, how do you do the drawing? Do you recurse the document's objects for you own and draw them then?
            Thanks!
            Robert
              On 06/02/2007 at 13:58, xxxxxxxx wrote:
              Howdy,
              Nope, not yet. :o(
              Actually, I haven't tried it anymore, and just went on to other things.
              Adios,
              Cactus Dan
                On 06/02/2007 at 14:18, xxxxxxxx wrote:
                Hello Dan,
                Nothing huh?
                Well, if I find a way, it will be posted here. ๐Ÿ™‚
                Thanks!
                  On 06/02/2007 at 14:25, xxxxxxxx wrote:
                  Howdy,
                  Cool, good luck with it.
                  It just seemed like too much to do, and there were more important things for me to solve.
                  Adios,
                  Cactus Dan
                    On 03/06/2007 at 11:10, xxxxxxxx wrote:
                    Howdy,
                    OK, I think I'm going to give this a shot again, but I have no idea how to use a scene hook or how to even set one up. There is no example of a SceneHookData plugin in the SDK project. I've found some bits and pieces of code here on the cafe, but not a complete example.
                    I'm going to see if I can figure this out from the bits and pieces, but I'll welcome any complete example anyone is willing to share. ๐Ÿ˜‰
                    Adios,
                    Cactus Dan
                      On 04/06/2007 at 22:56, xxxxxxxx wrote:
                      Howdy,
                      Well, I figured out how to set up the SceneHookData and it works!
                      Seems that if I draw in screen coordinates using the 2D drawing functions, it draws on top of the polygon mesh using the SCENEHOOKDRAW_ACTIVE_PASS flag. Since I'm only drawing lines anyway, that works out great.
                      Adios,
                      Cactus Dan
                        On 05/06/2007 at 12:44, xxxxxxxx wrote:
                        Great news, Dan!
                        Please post a screenshot so we can see the cool results (this could be over at CGTalk if you like).
                          On 05/06/2007 at 13:46, xxxxxxxx wrote:
                          Howdy,
                          Here is the result:
                          I had to write my own dotted line drawing routine, though, using BaseDraw's Point2D() function.
                          Adios,
                          Cactus Dan
                            On 05/06/2007 at 21:36, xxxxxxxx wrote:
                            Very nice, Dan. I may have to speak with you on how you accomplished this with a SceneHook in the future. ๐Ÿ™‚
                            Take care,
