    SetDrawParameter & LineZOffset
    37 Posts 0 Posters 26.9k Views
      On 28/09/2006 at 14:56, xxxxxxxx wrote:
      You can also get the node data using something like this (not illegal and it works) :
      MyObject* myo = static_cast<MyObject*>(obj->GetNodeData());
      This allows you to call methods in your ObjectData. Just make sure to check for NULL and heed the advice about virtual functions.
        On 28/09/2006 at 15:30, xxxxxxxx wrote:
        Howdy,
        Well, thanks for all the help, but I may end up abandoning the idea.
        I noticed that the tag's Draw() function gets called three times, and that seems a bit too often to be branching out to each joint just to draw them on top of the polygon mesh. :o(
        Anyway, I am curious to know how the bones are doing it, though.
        Adios,
        Cactus Dan
          On 29/09/2006 at 03:28, xxxxxxxx wrote:
          GetNodeData(), thanks for the hind. I was looking for something like this, but could not find it.
          I still suggest that using a SceneHook will work. It allows more control over when the drawing happens ( highlight pass ) and the draw function should always be called. I'm convinced that bones are drawn this way.
          It would be nice now to know for sure... Mikael ? David ?
            On 29/09/2006 at 09:28, xxxxxxxx wrote:
            Howdy,
            > Quote: Originally posted by Michael Welter on 29Β SeptemberΒ 2006
            Yes, I knew about that. It works well for being able to communicate between your plugin classes, to retrieve pointers to stored data.
            > Quote: _I still suggest that using a SceneHook will work. It allows more control over when the drawing happens ( highlight pass ) and the draw function should always be called. I'm convinced that bones are drawn this way.
            _
            I may give that a try, but maybe for the next update of the plugin. ;o)
            > Quote: It would be nice now to know for sure... Mikael ? David ?
            Yes, I would like to know for sure, too.
            Adios,
            Cactus Dan
              On 04/10/2006 at 11:43, xxxxxxxx wrote:
              It's surely a hack to call the object's Draw() function from the tag's, but I can't see how it could be dangerous. More like code reuse... πŸ™‚
              The Scenehook solution might be the simplest, though, provided that its Draw() function is always called after objects'.
                On 05/10/2006 at 20:24, xxxxxxxx wrote:
                Howdy,
                Thanks Mikael, I'll consider giving that a try when I do another update. ;o)
                Adios,
                Cactus Dan
                  On 06/02/2007 at 13:48, xxxxxxxx wrote:
                  Dan,
                  Did you ever find a solution here and what was it? πŸ™‚
                  I am looking into something similar for my bones while some other related features are added.
                  If you went with a SceneHook, how do you do the drawing? Do you recurse the document's objects for you own and draw them then?
                  Thanks!
                  Robert
                    On 06/02/2007 at 13:58, xxxxxxxx wrote:
                    Howdy,
                    Nope, not yet. :o(
                    Actually, I haven't tried it anymore, and just went on to other things.
                    Adios,
                    Cactus Dan
                      On 06/02/2007 at 14:18, xxxxxxxx wrote:
                      Hello Dan,
                      Nothing huh?
                      Well, if I find a way, it will be posted here. πŸ™‚
                      Thanks!
                        On 06/02/2007 at 14:25, xxxxxxxx wrote:
                        Howdy,
                        Cool, good luck with it.
                        It just seemed like too much to do, and there were more important things for me to solve.
                        Adios,
                        Cactus Dan
                          On 03/06/2007 at 11:10, xxxxxxxx wrote:
                          Howdy,
                          OK, I think I'm going to give this a shot again, but I have no idea how to use a scene hook or how to even set one up. There is no example of a SceneHookData plugin in the SDK project. I've found some bits and pieces of code here on the cafe, but not a complete example.
                          I'm going to see if I can figure this out from the bits and pieces, but I'll welcome any complete example anyone is willing to share. πŸ˜‰
                          Adios,
                          Cactus Dan
                            On 04/06/2007 at 22:56, xxxxxxxx wrote:
                            Howdy,
                            Well, I figured out how to set up the SceneHookData and it works!
                            Seems that if I draw in screen coordinates using the 2D drawing functions, it draws on top of the polygon mesh using the SCENEHOOKDRAW_ACTIVE_PASS flag. Since I'm only drawing lines anyway, that works out great.
                            Adios,
                            Cactus Dan
                              On 05/06/2007 at 12:44, xxxxxxxx wrote:
                              Great news, Dan!
                              Please post a screenshot so we can see the cool results (this could be over at CGTalk if you like).
                                On 05/06/2007 at 13:46, xxxxxxxx wrote:
                                Howdy,
                                Here is the result:
                                I had to write my own dotted line drawing routine, though, using BaseDraw's Point2D() function.
                                Adios,
                                Cactus Dan
                                  On 05/06/2007 at 21:36, xxxxxxxx wrote:
                                  Very nice, Dan. I may have to speak with you on how you accomplished this with a SceneHook in the future. πŸ™‚
                                  Take care,
