    Instance Object Link is not working
    3 Posts 3 Posters 778 Views 1 Watching
    • aghiad322A Offline
      aghiad322
      i'm trying to link an object in the instance's reference object but it's not working
      • i_mazlovI Offline
        i_mazlov
        Hello @aghiad322,
        Welcome to the Plugin Café forum and the Cinema 4D development community, it is great to have you with us!
        Getting Started
        Before creating your next postings, we would recommend making yourself accustomed with our Forum and Support Guidelines, as they line out details about the Maxon SDK Group support procedures. Of special importance are:
        • Support Procedures: Scope of Support: Lines out the things we will do and what we will not do.
        • Support Procedures: Confidential Data: Most questions should be accompanied by code but code cannot always be shared publicly. This section explains how to share code confidentially with Maxon.
        • Forum Structure and Features: Lines out how the forum works.
        • Structure of a Question: Lines out how to ask a good technical question. It is not mandatory to follow this exactly, but you follow the idea of keeping things short and mentioning your primary question in a clear manner.
        About your First Question
        There's a great example script that reveals how to work with instance object.
        Regarding your exact scenario, you have to insert the referenced object to the document as well. You can check the following code snippet:
        doc: c4d.documents.BaseDocument  # The active document
            objCube = c4d.BaseList2D(5159)
            objInstance = c4d.InstanceObject()
            objInstance.SetReferenceObject(objCube)
            # objInstance = c4d.BaseList2D(5126)
            # objInstance[c4d.INSTANCEOBJECT_LINK] = objCube
            doc.InsertObject(objInstance)
            doc.InsertObject(objCube)
        Note, commented out you find an equivalent way to create and setup up instance object.
        Ilia
        • M Offline
          m_adam
          Hello @aghiad322,
          without further questions or postings, we will consider this topic as solved by Monday 05/06/2023 and flag it accordingly.
