    Dynamically Add Massign to Material in Material Editor
    c++
    2 Posts 2 Posters 157 Views 1 Watching
    • E Offline
      ECHekman
      I currently use INCLUDE Massign in my .res file. However i would like to do this dynamically so that I can change the order at which it is placed in the Material Editor and Attribute Editor. Is there a way to do this?
      Additionally Also is there a way to hide settings from the Obaselist group or hide settings in the Material Editor but keep them in the Attribute editor?
        ferdinand @ECHekman
        Hey @ECHekman,
        There is no INCLUDE which you could call programmatically in GetDDescription, but there is Description::LoadDescription. When Cinema 4D is asking you to update a certain part of your description, you could try to call it on your description instance but not with its id, but Massign. This is however very likely to fail or cause crashes, because your description is already being processed, I never tried this myself though.
        Another approach could be to allocate a dummy description, then load your resource (e.g., Massign) into that dummy description, to then copy parameters bit by bit into your active/actual description passed into GetDDescription.
        But the whole approach of a 'dynamic include' is a bit backwards without context why it has to be this way. Because when you dynamically include something, this also means you have to remove existing data where it shall not be included anymore. Which is possible but unnecessary extra work. Also copying a whole partial description is not a great idea performance wise, GetDDescription is being called a lot.
        The better approach would be to just include your partial description in your res file in the a place where it might appear and then dynamically change the parent of that container. As this workflow would be the common dynamic description workflow.
        No, both managers are more or less just a DescriptionCustomGui, they will always show the same data, unless you have access to the implementation (which you do not). When you would implement your own material dialog, with your own DescriptionCustomGui in it, you could mangle what is shown in this particular description view to your liking, there are multiple methods to highlight, filter, and modify a description on that class. To operate this dialog you would then set this description GUI to the material, shader or whatever BaseList2D you want to display, and then either filter or outright modify the description which is being displayed.
