    BaseDraw.DrawTexture Issue
    2025python
    3 Posts 2 Posters 1.3k Views
    • FlavioDinizF Offline
      FlavioDiniz
      Hi !
      In an attempt to circumvent a bug in the DrawHUDText and DrawMultipleHUDText (link below), I'm trying to use the DrawTexture function, but now we have two issues.
      (https://developers.maxon.net/forum/topic/15394/drawhudtext-issue-with-viewport-camera-navigation)
      1 - The first issue is the mouse cursor doesn't orbit to the object in the viewport, it's like the text is being drawn in the whole screen and the camera is orbiting around the text... I tested several Zdepth settings. no luck.
      2 - The second issue is the lag, notice the difference in C4D 2023 and 2025 in the video below (problem is also present in 2024).
      So far I noticed the lag (and the camera orbit issue) on the DrawHUDText, DrawMultipleHUDText and DrawTexture functions. Other simple functions like DrawPoint2D, DrawLine2D and DrawLine does't have issues.
      The code I'm using on a tag is:
      from c4d import plugins, bitmaps, documents
          pass
      def draw(bd) -> bool:
          bh = c4d.plugins.BaseDrawHelp(bd, doc)
          bd.LineZOffset(2)
          bd.SetMatrix_Screen()
          text = "My Tex asssssssssssssssssssdasdasdt"
          cm = c4d.bitmaps.GeClipMap()
          cm.Init(0, 0, 32)
          cm.BeginDraw()
          width = cm.TextWidth(text)
          height = cm.TextHeight()
          cm.EndDraw()
          cm.Destroy()
          cm.Init(width, height, 32)
          cm.BeginDraw()
          cm.SetColor(255, 255, 255, 255)
          cm.TextAt(0,0,text)
          cm.EndDraw()
          bd.SetLightList(c4d.BDRAW_SETLIGHTLIST_NOLIGHTS)
          xpos=255
          ypos=255
          padr = [(c4d.Vector(xpos,ypos,0)), (c4d.Vector(xpos+width,ypos,0)), (c4d.Vector(xpos+width,ypos+height,0)), (c4d.Vector(xpos,ypos+height,0))]
          cadr = [(c4d.Vector(1,1,1)), (c4d.Vector(1,1,1)), (c4d.Vector(1,1,1)), (c4d.Vector(1,1,1))]
          vnadr = [(c4d.Vector(0,0,1)), (c4d.Vector(0,0,1)), (c4d.Vector(0,0,1)), (c4d.Vector(0,0,1))]
          uvadr = [(c4d.Vector(0,0,0)), (c4d.Vector(1,0,0)), (c4d.Vector(1,1,0)),(c4d.Vector(0,1,0))]
          cmbmp = bitmaps.BaseBitmap()
          cmbmp = cm.GetBitmap()
          alpha = bmp.GetInternalChannel()               #Get at the RGBA channels of the bitmap copy
          alpha = bmp.AddChannel(True, False)
          bd.SetDepth(False)
          bd.DrawTexture(bmp,padr,cadr,vnadr,uvadr,4,c4d.DRAW_ALPHA_NORMAL,c4d.DRAW_TEXTUREFLAGS_0)
      There's nothing special on the code, we can also see the issue with a simpler code:
          pass
      def draw(bd: c4d.BaseDraw) -> bool:
          bd = doc.GetActiveBaseDraw()
          bd.DrawHUDText(200,200,"TESTING TEXT")
          return c4d.DRAWRESULT_OK
      I'm also attaching my C4D file:
      draw_hud_text_issue2.c4d
      That said, is there any working way to write text to the viewport with Python ?
      Thanks in advance !
      Flavio Diniz
      • i_mazlovI Offline
        i_mazlov @FlavioDiniz
        Hi Flavio Diniz,
        Thank you for providing an extensive description of your issue.
        I've updated the original thread about the DrawHUDText issue. I don't see the orbiting center issue anymore after applying the change to the python tag code, namely adding the following early exit condition to the draw function:
            if bd.GetDrawPass() != c4d.DRAWPASS_OBJECT or bd.GetDrawParam(c4d.BASEDRAW_IS_PICK_OBJECT):
        The same thing stands for the lag issue - I cannot reproduce it with the patched python tag code.
        Ilia
          FlavioDiniz
          Fantastic @i_mazlov !
          Both issues are solved, thank you so much !
          Flavio Diniz
          • i_mazlovI i_mazlov forked this topic on
