    TempUVHandle always None! Why?
    r21pythonwindows
    3 Posts 2 Posters 849 Views 1 Watching
    • ThomasBT Offline
      ThomasB
      I am not able to get the TempUVHandle from an active UVWTag in R21.
      It returns always "None".
      In the following script I created a simple plane in a TempDoc and took the cache and inserted it into the TempDoc. It already has a UVW-Tag, then I have set the object active and so the UVWTag....
      My Code:
          temp = c4d.documents.BaseDocument()
          plane = c4d.BaseObject(c4d.Oplane)
          temp.InsertObject(plane)
          temp.ExecutePasses(bt=None, animation=False, expressions=False, caches=True, flags=c4d.BUILDFLAGS_NONE)
          plane_cache = plane.GetCache().GetClone()
          if plane_cache is None:
              raise Exception("no cache")
          temp.InsertObject(plane_cache)
          uvw_tag = plane_cache.GetTag(c4d.Tuvw)
          temp.SetActiveTag(uvw_tag)
          temp.SetActiveObject(plane_cache)
          handle = c4d.modules.bodypaint.GetActiveUVSet(temp, c4d.GETACTIVEUVSET_UVWS)
          print(handle)
      # Execute main()
      if __name__=='__main__':
      Thanks,
      T.B
      • i_mazlovI Offline
        i_mazlov @ThomasB
        Hi @ThomasB,
        Please note that R21 is generally out of scope of full support on this forum. I've tried your code with the oldest C4D version I have (which is R25) and I cannot reproduce your issue.
        However, looking in your code it seems like you might need an additional handling for the case when the texture view is not open, please have a look at the comment in our example: call_uv_command_r18.py .
        You can also find some useful information on a similar thread, where Ferdinand gave some insights about GetActiveUVSet function: GetActiveUVSet() returns None if multiple UVs are active?.
        Ilia
        ThomasBT 1 Reply Last reply Reply Quote 0
        • ThomasBT Offline
          ThomasB @i_mazlov
          @i_mazlov
          Thank you very much for the hint with the texture view and for the helpful links.
          The second thread I have already read, but was not able to find the solution so far. I study these examples. Thank you.
          Thanks,
          T.B
