    How does C4DAtom.GetHDirty(c4d.HDIRTYFLAGS_OBJECT_HIERARCHY) work?
    Scheduled Pinned Locked Moved Bugs
    windowspython2024
    4 Posts 2 Posters 1.5k Views 2 Watching
    • DunhouD Online
      Dunhou
      Hi community,
      My understanding is that C4DAtom.GetHDirty(c4d.HDIRTYFLAGS_OBJECT_HIERARCHY) can track the document dirty with when a new object is created( hierarchy changed of course ), but if I delete objects, the dirty count will not change, but if I reload python plugin, it can worked again.
      I didn't know if I misunderstand this method, why that happened?
      Cheers~
      DunHou
      Win11 23H2 + C4D 2024.5.1
      Codes:
      import typing
      doc: c4d.documents.BaseDocument  # The active document
      op: typing.Optional[c4d.BaseObject]  # The selected object, can be None.
      class Dialog (c4d.gui.GeDialog):
          def CreateLayout(self) -> bool:
          def CoreMessage(self, mid: int, data: c4d.BaseContainer) -> bool:
              if mid == c4d.EVMSG_CHANGE:
                  print(doc.GetHDirty(c4d.HDIRTYFLAGS_OBJECT_HIERARCHY))
              return super().CoreMessage(mid, data)
          global dlg
          dlg = Dialog()
          dlg.Open(c4d.DLG_TYPE_ASYNC)
      Video:
      https://boghma.com
      https://github.com/DunHouGo
      • M Offline
        m_adam
        Hi @Dunhou thanks for contacting us, after investigating it's seems there is a bug that freeze the dirty count once you had an object hierarchy, and delete the complete object hierarchy. Then after this operation the dirty count stop to work. This also impact object with children, their dirty count stop at 1.
        Reloading Python make it works, because since few version, it create a new documents and refresh everything under the hood and its just a "workaround".
        So thanks a lot for reporting it to us, I've created an internal bug for it, let's see what's the outcome of it.
        • M m_adam moved this topic from Cinema 4D SDK on
        • DunhouD Online
          Dunhou
          woops, I try lots of stuff to debug this, hope it can fix soon. will use old way to track new objects for now.
          https://boghma.com
          • M Offline
            m_adam
            Hi just to let you know that the bug has been fixed, this will be available in one of the next releases. I will post on this topic once the fix is available.
