    Hide the illumination group in node materials
    c++
    2 Posts 2 Posters 687 Views 1 Watching
    • B Offline
      bojidar
      Hi
      Is there a way to hide the illumination group that comes from the standard Cinema4D Mmaterial for node materials? If I remember correctly it was still visible in Redshift until recently and it was removed, so is there some magic way of doing that or is it currently not possible?
        ferdinand @bojidar
        Hey @bojidar,
        Thank you for reaching out to us.
        I assume you are talking about NodeMaterial cases, i.e., a material realized by the Nodes API.
        Something like a NodeMaterial does not actually exist under the hood. A NodeMaterial is just a modified Material (i.e., the type Mmaterial) where pretty much everything except for the Viewport (and previously Illumination) tab is being hidden. This is done by us overriding GetDDescription in Material. By default not the whole illumination tab is hidden, but only everything below the check box "Portal" (don't ask me why). I just had a look: And for Redshift we recently added a section in Material::GetDescription where we check for a material being part of the Redshift node space and then hide the full tab. Since third parties do not own/overwrite Material, their node material then looks different, without them being able to change that (here at the example of V-Ray):
        For me it looks a bit like that we unintentionally left that group there. Maybe physical render node materials were/are still using that? But at least I do not see a reason why light portals and polygon lights must be standardized in this manner (we hide that group except for physical).
        I would recommend reaching out to us with a mail and the request to remove that "feature", i.e., make this more a program management than a programming thing. I cannot guarantee that we will do this, as there might be some special material management reasons why this has been done, but the starting point would be to have a PM discussion.
