    How to access the "root" Scene Nodes graph
    python2024
    3 Posts 2 Posters 615 Views 1 Watching
    • K Offline
      kng_ito
      I am trying to access some nodes in Scene Nodes graph with python.
      For node-based objects like Nodes Modifier, I can use BaseList2D.GetNimbusRef() to access the graph, but I don't know how to get into the "root" Scene Nodes graph. Is there an invisible BaseList2D that holds the root Scene Nodes graph and I can use the same way from that object?
      The code below is how I did it for node-based objects to access their nodes. I hope there is a way to access the root Scene Nodes graph in a similar way.
      import maxon
          nbr = op.GetNimbusRef("net.maxon.neutron.nodespace")
          graph = nbr.GetGraph()
          root = graph.GetRoot()
          # Iterate over the direct children of the graph root.
          nodesList = []
          root.GetChildren(nodesList, maxon.NODE_KIND.NODE)
          for node in nodesList:
              print(node)
      I would appreciate any examples or tips you could give me. Thank you.
        ferdinand @kng_ito
        Hey @kng_ito,
        Thank you for reaching out to us. The "root" element of the document bound scene nodes graph is a scene hook. In case you are unfamiliar with that concept, SceneHookData is a plugin type of scene elements that are present by default in every scene. Scene hooks do not have any relation to scene nodes, it is just a coincidence that they both have the word "scene" in their name.
        We have this C++ example for how to do it, and here I did the same in Python. There is also GraphDescription.CreateGraph which can be used to retrieve graphs for given items. E.g., when you pass it a BaseDocument, it will return the document bound scene nodes graph for you.
        K 1 Reply Last reply Reply Quote 1
        • K Offline
          kng_ito @ferdinand
          Hi @ferdinand ,
          Thanks as always for your clear answers, It solved the problem for me!
