    Copy children to selection with GetClone()
    python2024
    3 Posts 2 Posters 1.1k Views 1 Watching
    • John_DoJ Offline
      John_Do
      Hi all,
      I'm writing a script to copy the children objects of an "active" object to other selected objects using the GetClone() function, but I can't get it to work as intended, I feel I'm missing something obvious. The intent is to copy deformers from the active object to all others (but I don't want to limit the function to deformers).
          doc.StartUndo()
          objs = doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_SELECTIONORDER)
          if len(objs) >= 2:
              # Get the last selected object
              active = objs.pop(-1)
              # --------------------------------- Method A --------------------------------- #
              # Get the deformers
              deformers = [i.GetClone(c4d.COPYFLAGS_NO_BITS) for i in active.GetChildren()]
              # Copy deformer to selection
              if deformers:
                  for o in objs:
                      for d in deformers[::-1]:
                          doc.InsertObject(d, parent=o)
                          doc.AddUndo(c4d.UNDOTYPE_NEW, d)
              # --------------------------------- Method B --------------------------------- #
              # # Get the deformers
              # deformers = [i for i in active.GetChildren()]
              # if deformers:
              #     for o in objs:
              #         for d in deformers[::-1]:
              #             doc.InsertObject(d.GetClone(c4d.COPYFLAGS_NO_BITS), parent=o)
              #             doc.AddUndo(c4d.UNDOTYPE_NEW, d)
          doc.EndUndo()
      The method A kinda works but do only one copy and stop without error. I didn't see anything meaningful after printing the lists content in various steps of the script, everything seems ok from my understanding.
      The method B kinda works too and successfully copy deformers on all the selected objects but the undo is very buggy ( multiple steps rather than one as intended, delete deformers on the active object).
      Also the newly inserted objects open the hierarchies in the OM, is it because it's the default behavior of C4D when creating child objects ? Do I have to toggle BIT_OFOLD manually ?
      Thanks !
        ferdinand @John_Do
        Hey @John_Do,
        Thank you for reaching out to us. We will answer on Monday in more detail as you have just missed our morning meeting where we assign topics. But when I look at your code, it seems like you are inserting your deformers multiple times.
        if deformers:
            for o in objs:
        Without having run your script, this reads to me like you are inserting each element of deformers len(objs) times. A node can only be inserted once into a scene or really bad things are going to happen. Python has a fail-safe for this as it calls node.Remove in the implementation of most insertion methods. When you pair this with your undo, wonky results are not surprising I would say. When you want to insert your deformers multiple times, you must clone them for each insertion.
        • John_DoJ Offline
          John_Do
          Hi @ferdinand, thanks for the feedback, I've got it working with your suggestion. The method B was correct but the undo part was wrong ( the undo step was applied on the original objects instead of the new ones, thus leading to a mess when performing an undo). I also added the bit part to keep new objects folded in the OM. Here is the code :
          # CopyDeformers
              doc.StartUndo()
              if len(objs) >= 2:
                  # Get the deformers
                  # Copy deformers to selection
                  if deformers:
                      for o in objs:
                              dcopy = d.GetClone(c4d.COPYFLAGS_NO_BITS)
                              doc.InsertObject(dcopy, parent=o)
                              doc.AddUndo(c4d.UNDOTYPE_NEW, dcopy)
                          o.SetBit(c4d.BIT_MFOLD)
              doc.EndUndo()
