    Create folder in Volume Builder
    windowspython2023
    3 Posts 2 Posters 755 Views 1 Watching
    • D Offline
      datamilch
      hi there,
      i am trying to add a folder/group to the object list of a volume builder.
      but i have no idea how. there is nothing in the the documentation and no examples either.
      is this even possible?
      as an alternative i could probably nest multiple volume builders, but folders would be more elegant i think.
      the current test code:
          # create objects
          null = c4d.BaseObject( c4d.Onull )
          cube = c4d.BaseObject( c4d.Ocube )
          hole = c4d.BaseObject( c4d.Ocylinder )
          hole[c4d.PRIM_CYLINDER_HEIGHT] = 300
          # create volume builder
          vb = c4d.BaseObject( c4d.Ovolumebuilder )
          vm = c4d.BaseObject( c4d.Ovolumemesher )
          # insert into scene
          doc.InsertObject( null )
          cube.InsertUnderLast( null )
          hole.InsertUnderLast( null )
          vm.InsertUnderLast( null )
          vb.InsertUnderLast( vm )
          # insert into volume builder
          vb.AddSceneObject( cube )
          vb.AddSceneObject( hole )
          vb.SetBoolMode( 1, c4d.BOOLTYPE_DIFF )
          c4d.CallCommand(100004748) # unfold all
      • i_mazlovI Offline
        i_mazlov @datamilch
        Hi @datamilch,
        Even though technically creating a folder inside the volume builder is possible (please check the code snippet below), you should do this at your own risk as I'm pretty sure this is not intended to be used from our public API this way.
        I will bring this topic up to the corresponding developer, once he is back from vacation, but I cannot give you any promises.
        Hence, I'm leaving all related follow up topics (e.g. how to rename the folder or how to put the object inside the folder, etc..) without any solution, as there's no good solution for it at the moment (if there's even any 😐 )
        Ilia
        The code showing how to create folder inside the VolumeBuilder:
            cube = c4d.BaseObject(c4d.Ocube)
            vb = c4d.BaseObject(c4d.Ovolumebuilder)
            doc.InsertObject(cube)
            doc.InsertObject(vb)
            vb.AddSceneObject(cube)
            data = { 'descid': c4d.ID_VOLUMEBUILDER_ADDMISCBUTTON }
            ID_VOLUMELIST_ADDFOLDER = 2  # this ID is excluded from our public API
            vb[c4d.ID_VOLUMEBUILDER_ADDMISCBUTTON] = ID_VOLUMELIST_ADDFOLDER
            vb.Message(c4d.MSG_DESCRIPTION_CHECKUPDATE, data)
        D 1 Reply Last reply Reply Quote 0
        • D Offline
          datamilch @i_mazlov
          hi @i_mazlov,
          thanks for the answer. good to know about this status / limitation.
          for my current case I found a solution without folders..
