    How to access thinkin particles data channels correctly?
    c++2024
    3 Posts 2 Posters 765 Views 1 Watching
    • A Offline
      Aaron
      Hi All,
      There is thinking particles system and it has few named channels such as here:
       Float   [chan   5] DataChannelType    19 DataChannelName mass(Real)
       Float   [chan   6] DataChannelType    19 DataChannelName oldP(Real)
       Float   [chan   8] DataChannelType    19 DataChannelName pscale(Real)
       Float   [chan 10] DataChannelType    19 DataChannelName spriteuv(Real)
       Vector [chan   1] DataChannelType    23 DataChannelName Cd(Vector)
      I get channel info using tps->DataChannelType(chan) and etc.
      19 is DTYPE_REAL, 23 is DTYPE_VECTOR
      But when I try to read the channel value per particle then it returns false and doesn't read the values. For example this request returns false:
        TP_MasterSystem* tps;
        Vector fval(0.0);
        tps->GetData(pid, channel, &fval, DTYPE_VECTOR);
      // nothing is written in fval. I also tried to use GeData, but it didn't help
      Other particle data such as tps->Transform(...), tps->Color(...), tps->Age(...) is returning relevant results.
      Please, can someone show me a valid example of correct TP data channel access?
      • A Offline
        Aaron
        Solved, it works this way:
        Vector v(0.0);
        tps->GetData(pid, channel, &v, ID_GV_VALUE_TYPE_VECTOR);
          ferdinand @Aaron
          Hey @Aaron,
          thank you for sharing your solution!
