    BitmapButton in Resource file
    2024c++
    8 Posts 2 Posters 2.2k Views
    • J Offline
      JohnThomas
      Hello.
      I'm currently trying to create a FieldLayer plugin that is using a resource file for the creation of its description. Everything is working properly with the exception of a BitmapButton that does not seem to be sending any kind of message that it has been pressed.
      Here is the line from the resource file that I am creating the BitmapButton.
      BITMAPBUTTON ID_EXECUTERUN {BUTTON;}
      Inside of Message I Have the MSG_DESCRIPTION_GETBITMAP to set the image for the bitmap.
      if (type == MSG_DESCRIPTION_GETBITMAP)
      		DescriptionGetBitmap* dgb = static_cast<DescriptionGetBitmap*>(t_data);
      		Int32 ID = dgb->_descId[0].id;
      		AutoAlloc<BaseBitmap> bm;
      		Filename bg;
      		if (ID == ID_EXECUTERUN )
      			bg = GeGetPluginPath() + Filename("res") + Filename("Icons") + Filename("Execute.png");
      			bm->Init(bg);
      			AutoAlloc<BaseBitmap> bm2;
      			bm2->Init(bm->GetBw() / 2, bm->GetBh() / 2);
      			bm->ScaleIt(bm2, 256, TRUE, TRUE);
      			dgb->_bmp = bm2.Release();
      There was a forum post that was dealing with the same issue, but the solution offered in the post does not seem to be working. I put prints in both the SetDParameter function as well as the MSG_DESCRIPTION_COMMAND message and neither one is ever being printed, all of the other controls I have are working properly.
      Is there something fundamental that I'm missing that is preventing it from catching that the button is being pressed?
      Any help would be greatly appreciated.
      John Thomas
      • i_mazlovI Offline
        i_mazlov @JohnThomas
        Hi John Thomas,
        There's nothing fundamental you're missing here. The solution from this old thread should work just fine. Please have a look at the NodeData::SetDParameter() Manual namely the DESCFLAGS_SET::USERINTERACTION flag you need to check against.
        The code snippet you've attached shows the unrelated part of your code. The important function where the problem is likely to happen is the SetDParameter() function.
        By the way, you can register icons using the RegisterIcon() function and use it directly in your code instead of populating the file path by multiple string concatenations. Just make sure you've registered the image before the plugin registration happens.
        Ilia
        • J Offline
          JohnThomas
          Thanks for the response.
          My SetDParamter function is defined with this code.
          Bool ExampleFieldLayer::SetDParameter(GeListNode* node, const DescID& id, const GeData& t_data, DESCFLAGS_SET& flags)
          	switch (id[0].id)
          		case 1006: // ID_EXECUTERUN
          			if (flags & DESCFLAGS_SET::USERINTERACTION)
          				ApplicationOutput("Running SetDParameter");
          			break;
          	return SUPER::SetDParameter(node, id, t_data, flags);
          And at no point am I getting a print from the BitmapButton being pressed.
          John Thomas
          • J Offline
            JohnThomas
            Any ideas, my GetDParameter is defined with this code.
            Bool ExampleFieldLayer::GetDParameter(const GeListNode* node, const DescID& id, GeData& t_data, DESCFLAGS_GET& flags) const
            	Int32 ID = id[0].id;
            	if (ID == 1006)
            		Int32 dirty = 0;
            		maxon::WeakRawPtr<const GeListNode> weakPtr(node);
            		if (weakPtr.Get())
            			GeListNode* convert = MAXON_REMOVE_CONST(weakPtr.Get());
            			BaseList2D* convertObject = static_cast<BaseList2D*>(convert);
            			BitmapButtonStruct bbs(convertObject, id, dirty);
            			t_data = GeData(bbs, CUSTOMDATATYPE_BITMAPBUTTON);
            			flags |= DESCFLAGS_GET::PARAM_GET;
            	return SUPER::GetDParameter(node, id, t_data, flags);
            • i_mazlovI Offline
              i_mazlov
              Hi John,
              Your thread has slipped from my table, I'm sorry for that. This thread is next in my list.
              Ilia
              • i_mazlovI Offline
                i_mazlov @i_mazlov
                Hi John,
                Please again excuse the delayed answer!
                I've checked the Bitmap button specifically and it looks like if one creates it dynamically, they are normally using SetCallback() function for registering the "clicked" callback. However, if you're loading your bitmap from the resource file, you can react on the "clicked" event by checking for the MSG_DESCRIPTION_COMMAND message in the Message() function. Could you please try using the code snippet below out, if it works for you?
                Ilia
                Bool YourFieldLayerDataClass::Message(GeListNode *node, Int32 type, void *t_data)
                	iferr_scope_handler { return false; };
                		DescriptionGetBitmap *dgp = (DescriptionGetBitmap*)t_data;
                		if (!dgp) return false;
                		if (dgp->_descId[0].id == /* YOUR_BITMAPBUTTON_ID */)
                			if (!dgp->_bmp)
                				// Your icon loading routine
                				if (!dgp->_bmp) return false;
                	else if (type == MSG_DESCRIPTION_COMMAND)
                		DescriptionCommand *dc = (DescriptionCommand*)t_data;
                		if (!dc) return false;
                		if (dc->_descId[0].id == /* YOUR_BITMAPBUTTON_ID */)
                			// Bitmap button has been clicked
                	return SUPER::Message(node, type, t_data);
                J 1 Reply Last reply Reply Quote 0
                • J Offline
                  JohnThomas @i_mazlov
                  @i_mazlov Thanks for the response.
                  I tried utilizing the code and I am not getting any response when I try running it.
                  John Thomas
                  • i_mazlovI Offline
                    Hi @JohnThomas,
                    sorry again for a long delay in the answer.
                    Now I see that in this specific setup when the bitmap button is used inside the field layer plugin, the message MSG_DESCRIPTION_COMMAND is not propagated to the field layer plugin, which sounds like a bug to me. I've checked the code and it's likely due to the field layer data object being somewhat special comparing to others. I will double check this with a corresponding developer, once he's back from parental leave, and create a bug report for this to be fixed.
                    Unfortunately, I cannot offer you any workaround for this before it's fixed.
                    Ilia
