    Type Error when inserting geometry from a loaded file
    python2023windows
    3 Posts 2 Posters 802 Views 1 Watching
    • D Offline
      datamilch
      Hi there,
      I'm getting a strange TypeError:
      TypeError: descriptor 'InsertObject' for 'c4d.documents.BaseDocument' objects doesn't apply to a 'c4d.BaseObject' object
      When I print the object I want to insert I get a normal output:
      <c4d.BaseObject object called helper - cutplane/Null with ID 5140 at 2616415521856>
      The plugin is quite complex at this point, so I try to post only the relevant parts of the code. It's a dialog plugin. Checking for the Main Thread sais True.
      Not sure if I made some obvious mistake ...
      the file structure:
      main.pyp
      src-folder ---- helper py
      in the helper py there are a few classes, that are simplified in the following code:
      class Cutplane:
          class Helper:
              def load_file(self, filename: str = ''):
                  folder_path  = os.path.dirname(os.path.abspath(__file__))
                  file_path    = os.path.join( folder_path, filename )
                  loaded_doc = documents.LoadDocument( file_path, c4d.SCENEFILTER_OBJECTS )
                  loaded_obj = loaded_doc.GetFirstObject().GetClone()
                  c4d.documents.KillDocument(loaded_doc)
                  return loaded_obj
              def load_helper(self):
                  loaded_obj = self.load_file("helper_cutplane_01.c4d")
                  doc = c4d.documents.BaseDocument
                  print(loaded_obj)
                  print(c4d.threading.GeIsMainThread())
                  doc.InsertObject( loaded_obj )
      • i_mazlovI Offline
        i_mazlov @datamilch
        Hi @datamilch ,
        Thank you for a well structured question!
        Please check the line:
        where you assign class type to variable doc instead of the class instance. I assume you meant there
        doc = c4d.documents.BaseDocument()
        Ilia
        D 1 Reply Last reply Reply Quote 0
        • D Offline
          datamilch @i_mazlov
          @i_mazlov thanks ilia!!!
          ok that was truly obvious 😬
          actually had to use 'c4d.documents.GetActiveDocument()' to make it work in my case ...
