    How can I get the Inexclude date changed when drag or use straw?
    windowspython2024
    3 Posts 2 Posters 853 Views 1 Watching
    • DunhouD Offline
      Dunhou
      Hi community,
      I create a InExcludeData GUI ,but I cann't find the msg of the drop event, can we get the data change when we drop a object or use the straw tool?
      • get a drag object data in first Gadget
      • get object who select by the straw of the newt Gadget
      Cheers~
      DunHou
      https://boghma.com
      https://github.com/DunHouGo
      • i_mazlovI Offline
        i_mazlov @Dunhou
        Hi DunHou,
        Your question would have been making more sense with the code snippet showing the context.
        Assuming that you're operating in the GeDialog rather than in the Description, you can make use of GeDialog.Command(), which catches the user clicks on the gadget (you'd need to check for the id of your InExclude gadget). At this point you can access the InExclude object via msg[c4d.BFM_ACTION_VALUE].
        Unfortunatelly, there's no built-in event that gives you the list of objects, so you need to keep track of what has been changed after user's interaction yourself.
        Ilia
        DunhouD 1 Reply Last reply Reply Quote 0
        • DunhouD Offline
          Dunhou @i_mazlov
          Thanks @i_mazlov ,
          The msg[c4d.BFM_ACTION_VALUE] is all I want, Thanks for that.
          Cheers~
          DunHou
          https://boghma.com
