    Setting the name of a maxon.GraphNode via Python
    2023python
    3 Posts 2 Posters 1.0k Views 1 Watching
    • PoliigonP Offline
      Poliigon
      I happily admit, I suck with the maxon node interface.
      Still, I achieved most of what I needed. But what seemed to me like the most trivial part, I seem not to be able to accomplish.
      I would like to set the name of a (true) maxon.GraphNode (similar to the user clicking the node title and renaming it).
      I found this attribute maxon.NODE.BASE.NAME, but I'm not really sure, where to use it.
      Any help would be much appreciated.
      Thanks in advance,
      Andreas
      Poliigon Software Engineering
      • M Offline
        m_adam
        Hey Andreas, hope everything is fine on your end ! šŸ™‚
        Regarding name you can achieve that by calling GraphNode.SetValue with maxon.NODE.BASE.NAME.
        Find bellow an example that set the name of all the selected nodes to "New Name"
        import maxon
            # Retrieve the selected BaseMaterial
            mat = doc.GetActiveMaterial()
            if mat is None:
                raise ValueError("There is no selected BaseMaterial")
            # Retrieve the reference of the material as a node material.
            nodeMaterial = mat.GetNodeMaterialReference()
            if nodeMaterial is None:
                raise ValueError("Cannot retrieve node material reference")
            # Retrieve the current node space Id
            nodespaceId = c4d.GetActiveNodeSpaceId()
            # Retrieve the Nimbus reference for a specific node space
            nimbusRef = mat.GetNimbusRef(nodespaceId)
            if nimbusRef is None:
                raise ValueError("Cannot retrieve the nimbus ref for that node space")
            # Retrieve the graph corresponding to that node space.
            graph = nimbusRef.GetGraph()
            if graph is None:
                raise ValueError("Cannot retrieve the graph of this nimbus ref")
            # Get the root of the GraphNode
            root = graph.GetRoot()
            # Get all selected node
            # To modify a graph, modification must be done inside a transaction. After
            # modifications are done, the transaction must be committed.
            with graph.BeginTransaction() as transaction:
                for selectedNode in maxon.GraphModelHelper.GetSelectedNodes(graph, maxon.NODE_KIND.NODE):
                    # There is currently an issue affecting some datatype like string, Id, InternedId
                    # So when you set such a datatype it is mandatory to copy the value first to a new variable since SetValue will move the data
                    # Do no use stringValue after SetValue have been called, its data may be gone due to the issue
                    stringValue = maxon.String("New Name")
                    selectedNode.SetValue(maxon.NODE.BASE.NAME, stringValue)
                    print(selectedNode)
                transaction.Commit()
            # Pushes an update event to Cinema 4D
        I would also really advice you to take a look at Open source wrapper for Octane/Redshift/Arnold in Cinema 4D you will probably find it handy and is also a great resource to learn the nodes API!
        Have a nice weekend.
        • PoliigonP Offline
          Poliigon
          Hey Maxime,
          thanks for the quick answer.
          Actually I thought, I had tried SetValue() with that ID. But either I did something wrong or I tried something else... anyway, thanks.
          Just checked: Yes, I did something wrong. I stupidly just passed a string instead of a maxon.String. With the latter it works, not that I doubted your proposal.
          Maybe would be good, if SetValue() could throw an error, if a wrong type gets passed instead of just doing nothing.
          Also thanks for the pointer to Dunhou's project, I was already aware. Nice project! And indeed I peeked into it regarding some Arnold peculiarities...
          Andreas
