    Controlling drag&drop using MSG_DESCRIPTION_CHECKDRAGANDDROP
    2024python
    5 Posts 3 Posters 1.7k Views 1 Watching
    • CJtheTigerC Offline
      CJtheTiger
      Hello coders. Me again.
      In a Python ObjectData plugin I added a LINK parameter. I want all BaseObjects except for the plugin object itself to be droppable in here. So I put this in my .res file:
      LINK OMYOBJECT_LINK { ACCEPT { Obase; } }
      According to the documentation of MSG_DESCRIPTION_CHECKDRAGANDDROP I should listen to this message and if I want the drop to not be acceptable I should return False. So this is in my code:
      def Message(self, node: GeListNode, type: int, data: object) -> bool:
          if type == c4d.MSG_DESCRIPTION_CHECKDRAGANDDROP:
              return False
      Just to try it out I always return False. And that's where my issue is: I can still drop any object in there. It is limited to BaseObjects so the ACCEPT { Obase; } seems to work but returning False seems to not prevent the user from dropping something in the link.
      What am I doing wrong?
      I tried removing ACCEPT { Obase; } from the .res file to no effect.
      As an addition: How do I control what the picker of a LINK is allowed to pick? Since it's technically not a drag&drop action it should be something other than MSG_DESCRIPTION_CHECKDRAGANDDROP right?
      • S Offline
        spedler
        In addition to ACCEPT the LINK gui also has a REFUSE statement. You can use that to exclude your plugin ID.
        Steve
        CJtheTigerC 1 Reply Last reply Reply Quote 1
          CJtheTiger @spedler
          Hello @spedler,
          Thanks, this totally works.
          However this refuses to take any of my plugin objects, while in the end I only want to refuse the current plugin object; I still want to be able to drag other instances of my plugin object in there.
          So in the end I'd still like to solve this using advanced logic in the MSG_DESCRIPTION_CHECKDRAGANDDROP message.
          Best regards,
          Daniel
          • M Offline
            m_adam
            Hi @CJtheTiger, you were close regarding MSG_DESCRIPTION_CHECKDRAGANDDROP as written in the documentation, you need to set the value of the `resul field of the dictionary like so:
                def Message(self, node: c4d.GeListNode, type: int, data: object) -> bool:
                        gadgetId = data["id"]
                        dragedObj = data["element"]
                        data["result"] = dragedObj != node
              CJtheTiger @m_adam
              Hi @m_adam,
              thanks a lot, that did the trick.
              To close this topic off here's a snippet to allow other objects but not the current object to be dropped in there:
                      relevant_id = c4d.DescID(c4d.YOUR_PARAM) # Use the ID of the parameter of your object that you want to check.
                      current_id: c4d.DescID = data['id']
                      if relevant_id.IsPartOf(current_id)[0]:
                          dragged_element = data["element"]
                          is_same_object = node == dragged_element
                          data['result'] = not is_same_object
              Daniel
