    Include same container multiple times in .res
    2024pythonc++
    2 Posts 2 Posters 784 Views
    • CJtheTigerC Offline
      CJtheTiger
      Hello coders.
      I'd like to include the Oprimitiveaxis container multiple times in the .res file of my ObjectData plugin where the first inclusion should be called the same as the default Orientation while the second inclusion should be called something else like Alternative Orientation. To access both values in my plugin code they of course need separate IDs as well.
      For the first inlcusion I can simply do this in the .res file:
      CONTAINER omyobject
      	NAME Omyobject;
      	INCLUDE Obase;
      	INCLUDE Oprimitiveaxis;
      and access it via:
      orientation = op[c4d.PRIM_AXIS]
      What would I need to do to include this a second and possibly even more times? Is this even possible? In my head I'd have to define an alternative name and ID right with the INCLUDE statement. Or do I simply have copy and paste the CYCLE myself?
      Best regards,
      Daniel
      • i_mazlovI Offline
        i_mazlov @CJtheTiger
        Hi Daniel,
        You cannot include multiple containers and keep their IDs different. There's no special arguments for the INCLUDE statement that can optimize this workflow for you.
        In your case having your own implementation of CYCLE would be the solution you're looking for.
        Ilia
