    Get All Nodes inside an Xpresso Tag?
    2023python
    3 Posts 2 Posters 1.3k Views 1 Watching
    • B Offline
      bentraje
      Is there a way to get all nodes inside the xpresso tag?
      I tried checking the documentation and the forum and I don't get any relevant hits.
      It's for the workaround on this thread (https://developers.maxon.net/forum/topic/12246/how-do-i-return-the-connected-port-from-the-input-port/1)
      Regards,
      Ben
      • B Offline
        bentraje
        Ah my bad. It's just the same for objects in object manager.
        Here is the code for reference:
        def GetAllNodes(gvNode=None, nodeList=None):
                if nodeList is None:
                    nodeList = list()
                    gvNode = nodemaster.GetRoot()
                while gvNode:
                    nodeList.append(gvNode)
                    GetAllNodes(gvNode.GetDown(), nodeList)
                    gvNode = gvNode.GetNext()
                if len(nodeList) > 1:
                    nodeList = nodeList[1:] # Remove the Xgroup
                return nodeList
        geo_obj = doc.SearchObject("Cube")
        exp_tag = geo_obj.GetTag(1001149) #Get Expresso
        nodemaster = exp_tag.GetNodeMaster()
        node_list = GetAllNodes()
        • M Offline
          m_adam
          Hi yes, GvNode are BaseList2D and GeListNode, like material, object, tags.
          There is the same discussion going on, so you may find it interesting Issue collecting all the shaders in a material.
