    VolumeData::AttachVolumeDataFake() in latest C4D 2024 API
    2024c++
    3 Posts 2 Posters 973 Views 2 Watching
    • fwilleke80F Offline
      fwilleke80
      I noticed that, with the last C4D 2024 update, VolumeData::AttachVolumeDataFake() has two new parameters: Int32 fakeCurrentThreadIdx and Int32 fakeThreadCount. These are not documented, and not shown in the code snippet.
      Are these to fix the known issues with sampling a BaseShader from multiple threads (https://developers.maxon.net/forum/topic/12521/sample-a-shader-in-3d-space/15?_=1702535567135)? Will they allow me to sample multi-threaded again? What if I don't want to rewrite that code and decide to just continue sampling my shader single-threaded, do I just have to pass 0 as fakeCurrentThreadIdx and 1 as fakeThreadCount?
      Frank
      www.frankwilleke.de
      Only asking personal code questions here.
      M 1 Reply Last reply Reply Quote 0
      • M Offline
        m_adam @fwilleke80
        Hi frank, thanks for reporting, documentation will be adjusted.
        • fakeCurrentThreadIdx: Previously this value was stored in renderdata.RDATA_VDFAKE_CURRENTTHREAD. Now the parameter is passed directly for speedup.
        • fakeThreadCount: Previously this value was stored in renderdata.RDATA_VDFAKE_THREADCOUNT. Now the parameter is passed directly for speedup.
        So it's only for speedup reason it does not fix your issue with TexData.
        @fwilleke80 said in VolumeData::AttachVolumeDataFake() in latest C4D 2024 API:
        Correct.
          fwilleke80
          Super, thank you!
          www.frankwilleke.de
