    Easier Way to Modify Pose Morph Strength Based on Name?
    2023python
    3 Posts 2 Posters 1.1k Views
    • B Offline
      bentraje
      I can modify the pose morph strength based on name through the following code:
          morph_name = "smile_wide_L"
          morph_value = 0.8
          for i in range( morph_tag.GetMorphCount()):
              descID = tag.GetMorphID(i)
              if tag.GetMorph(i).GetName()==morph_name:
                       tag[descID] = morph_value
      As you can see, it has to loop through several times to get to the actual morph target to be modified.
      Other DCC API just simply do a variation of this:
      morph_object.morph_name = morph_value
      Is there a better way of doing this?
      • i_mazlovI Offline
        i_mazlov @bentraje
        Hi @bentraje,
        Pose morph name is not a unique identifier, meaning that you can theoretically have multiple pose morphs with the same name (even though it doesn't sound practical). Hence you cannot access pose morph in the tag by its name because such indexing is ambiguous.
        If you're sure there're no pose morphs with the same name, then you can create a dictionary that maps pose morph names to its DescIDs and use that instead.
        Ilia
        • B Offline
          bentraje
          @i_mazlov
          Ah yes, my pose morph names are standardized so there should be no duplicated/redundant names.
          And yea, thanks for mentioning the dictionary route. Totally overlooked that.
          That could indeed be an easier way to set/get some values.
          Thanks!
