    How to connect new ports and node ports in the group?
    python2024
    7 Posts 3 Posters 2.1k Views 1 Watching
    • ? Offline
      A Former User
      I would appreciate it if you could demonstrate the correct way to connect the red lines in the chart.
      import maxon
      from redshift_api import redshift_id as rsID
      def create_psr():
          mat = doc.GetActiveMaterial()
          if mat is None:
              raise ValueError("There is no selected BaseMaterial")
          nodeMaterial = mat.GetNodeMaterialReference()
          if nodeMaterial is None:
              raise ValueError("Cannot retrieve node material reference")
          nodespaceId = c4d.GetActiveNodeSpaceId()
          nimbusRef = mat.GetNimbusRef(nodespaceId)
          if nimbusRef is None:
              raise ValueError("Cannot retrieve the nimbus ref for that node space")
          graph = nimbusRef.GetGraph()
          if graph is None:
              raise ValueError("Cannot retrieve the graph of this nimbus ref")
          root = graph.GetRoot()
          nodes = []
          root.GetChildren(nodes, maxon.NODE_KIND.NODE)
          with graph.BeginTransaction() as transaction:
              TexNodeID: maxon.Id = maxon.Id(rsID.StrNodeID("texturesampler"))
              rsmathabsvectorID: maxon.Id = maxon.Id(rsID.StrNodeID("rsmathabsvector"))
              rsmathabsID: maxon.Id = maxon.Id(rsID.StrNodeID("rsmathabs"))
              TexNode: maxon.GraphNode = graph.AddChild(maxon.Id(), TexNodeID)
              P_rsmathabsvector: maxon.GraphNode = graph.AddChild(maxon.Id(), rsmathabsvectorID)
              S_rsmathabsvector: maxon.GraphNode = graph.AddChild(maxon.Id(), rsmathabsvectorID)
              R_rsmathabs: maxon.GraphNode = graph.AddChild(maxon.Id(), rsmathabsID)
              TexNodeScaleInputPort: maxon.GraphNode = TexNode.GetInputs().FindChild(
                  rsID.StrPortID("texturesampler", "scale"))
              TexNodeOffsetInputPort: maxon.GraphNode = TexNode.GetInputs().FindChild(
                  rsID.StrPortID("texturesampler", "offset"))
              TexNodeRotateInputPort: maxon.GraphNode = TexNode.GetInputs().FindChild(
                  rsID.StrPortID("texturesampler", "rotate"))
              P_rsmathabsvectorOutPort: maxon.GraphNode = P_rsmathabsvector.GetOutputs().FindChild(
                  rsID.StrPortID("rsmathabsvector", "out"))
              S_rsmathabsvectorOutPort: maxon.GraphNode = S_rsmathabsvector.GetOutputs().FindChild(
              R_rsmathabOutPort: maxon.GraphNode = R_rsmathabs.GetOutputs().FindChild(
                  rsID.StrPortID("rsmathabs", "out"))
              P_rsmathabsvectorInputPort: maxon.GraphNode = P_rsmathabsvector.GetInputs().FindChild(
                  rsID.StrPortID("rsmathabsvector", "input"))
              S_rsmathabsvectorInputPort: maxon.GraphNode = S_rsmathabsvector.GetInputs().FindChild(
              R_rsmathabInputPort: maxon.GraphNode = R_rsmathabs.GetInputs().FindChild(
                  rsID.StrPortID("rsmathabs", "input"))
              P_rsmathabsvectorOutPort.Connect(TexNodeScaleInputPort, modes=maxon.WIRE_MODE.NORMAL, reverse=False)
              S_rsmathabsvectorOutPort.Connect(TexNodeOffsetInputPort, modes=maxon.WIRE_MODE.NORMAL, reverse=False)
              R_rsmathabOutPort.Connect(TexNodeRotateInputPort, modes=maxon.WIRE_MODE.NORMAL, reverse=False)
              GroupNodes = []
              GroupNodes.append(TexNode)
              GroupNodes.append(P_rsmathabsvector)
              GroupNodes.append(S_rsmathabsvector)
              GroupNodes.append(R_rsmathabs)
              TexNodeScaleOutPort: maxon.GraphNode = TexNode.GetInputs().FindChild(
              groupRoot = maxon.GraphNode()
              groupRoot = graph.MoveToGroup(groupRoot, maxon.Id("PSRgroupID"), GroupNodes)
              P_InputPort =  maxon.GraphModelHelper.CreateInputPort(groupRoot, "scaleid", "缩放")
              S_InputPort =  maxon.GraphModelHelper.CreateInputPort(groupRoot, "offsetid", "偏移")
              R_InputPort = maxon.GraphModelHelper.CreateInputPort(groupRoot, "rotateid", "旋转")
              PSR_OutputPort = maxon.GraphModelHelper.CreateOutputPort(groupRoot, "psrid", "输出")
              transaction.Commit()
      • i_mazlovI Offline
        i_mazlov @Guest
        Hello @君心Jay,
        Welcome to the Plugin Café forum and the Cinema 4D development community, it is great to have you with us!
        Getting Started
        Before creating your next postings, we would recommend making yourself accustomed with our Forum and Support Guidelines, as they line out details about the Maxon SDK Group support procedures. Of special importance are:
        • Support Procedures: Scope of Support: Lines out the things we will do and what we will not do.
        • Support Procedures: Confidential Data: Most questions should be accompanied by code but code cannot always be shared publicly. This section explains how to share code confidentially with Maxon.
        • Forum Structure and Features: Lines out how the forum works.
        • Structure of a Question: Lines out how to ask a good technical question. It is not mandatory to follow this exactly, but you should follow the idea of keeping things short and mentioning your primary question in a clear manner.
        About your First Question
        First of all there is no "correct" way of doing that. The pattern you should use depend on the context of your goal.
        For example, looking at your code snippet it seems that the easiest way for you to make these connections would be to first connect the graph with the outside nodes and then use the MoveToGroup function, which would rewire the connections for you automatically.
        This is, however, not the general case. If you would really like to manually wire these ports, you would simply need to find them inside the group and connect them normally using Connect function. The pitfall here is that once you move your sub-graph to the group, it changes its path. This basically means that you'd need to find these nodes using FindNodesByAssetId or GetInnerNodes functions.
        Please refer to the draft sketch below that shows both approaches (you need to comment/uncomment corresponding function call in main()).
        Ilia
        Draft sketch:
        import maxon
        doc: c4d.documents.BaseDocument
        mat: c4d.BaseMaterial
        nimbusRef: maxon.NimbusBaseInterface
        graph: maxon.GraphModelInterface
            global doc, mat, nimbusRef, graph
            nimbusRef = mat.GetNimbusRef(c4d.GetActiveNodeSpaceId())
            easy_way()
            # manual_wiring()
        class rsID:
            def StrNodeID(id: str) -> str:
                return "com.redshift3d.redshift4c4d.nodes.core." + id
            def StrPortID(nodeId: str, portId: str) -> str:
                return "com.redshift3d.redshift4c4d.nodes.core." + nodeId + "." + portId
        def easy_way():
                # The outside value node
                valNode: maxon.GraphNode = graph.AddChild(maxon.Id(), maxon.Id("net.maxon.node.type"))
                valPortOutput: maxon.GraphNode = valNode.GetOutputs().FindChild("out")
                # The inside ABS node
                absNode: maxon.GraphNode = graph.AddChild(maxon.Id(), maxon.Id(rsID.StrNodeID("rsmathabs")))
                absPortInput: maxon.GraphNode = absNode.GetInputs().FindChild(rsID.StrPortID("rsmathabs", "input"))
                absPortOutput: maxon.GraphNode = absNode.GetOutputs().FindChild(rsID.StrPortID("rsmathabs", "out"))
                # Existing Standard material node
                stdMatNodes: list[maxon.GraphNode] = []
                maxon.GraphModelHelper.FindNodesByAssetId(graph, maxon.Id(rsID.StrNodeID("standardmaterial")), True, stdMatNodes)
                matNode: maxon.GraphNode = stdMatNodes[0]
                matPortOpac: maxon.GraphNode = matNode.GetInputs().FindChild(rsID.StrPortID("standardmaterial", "opacity_color"))
                # Connect everything in place
                valPortOutput.Connect(absPortInput)
                absPortOutput.Connect(matPortOpac)
                # Move to group -> rewiring is handled automatically
                graph.MoveToGroup(maxon.GraphNode(), maxon.Id("PSRgroupID"), [absNode])
        def manual_wiring():
                # Move to group straight away
                groupRoot = graph.MoveToGroup(maxon.GraphNode(), maxon.Id("PSRgroupID"), [absNode])
                # Create group ports
                groupPortInputOutside: maxon.GraphNode =  maxon.GraphModelHelper.CreateInputPort(groupRoot, "group_input_id", "grpInput")
                groupPortOutputOutside: maxon.GraphNode =  maxon.GraphModelHelper.CreateOutputPort(groupRoot, "group_output_id", "grpOutput")
                # Connect group to the outside nodes
                valPortOutput.Connect(groupPortInputOutside)
                groupPortOutputOutside.Connect(matPortOpac)
                # Find innder node
                innerNodes: list[maxon.GraphNode] = []
                maxon.GraphModelHelper.FindNodesByAssetId(graph, maxon.Id(rsID.StrNodeID("rsmathabs")), True, innerNodes)
                absNodeInner: maxon.GraphNode = innerNodes[0]
                # Find inner node ports
                absNodeInnerInput: maxon.GraphNode = absNodeInner.GetInputs().FindChild(rsID.StrPortID("rsmathabs", "input"))
                absNodeInnerOutput: maxon.GraphNode = absNodeInner.GetOutputs().FindChild(rsID.StrPortID("rsmathabs", "out"))
                # Connect inner node ports to group ports
                groupPortInputOutside.Connect(absNodeInnerInput)
                absNodeInnerOutput.Connect(groupPortOutputOutside)
        DunhouD 1 Reply Last reply Reply Quote 2
        • DunhouD Offline
          Dunhou @i_mazlov
          Hi @i_mazlov , thanks for the great answer.
          I would like to further inquire about this issue:
          1. if there are more than one "same id" nodes, how to make sure that the child of innerNodes list is the node we want, I test GraphNode.GetParent() and didn't return the "Group node" but return a path "Root", and I didn't found a method to check if a GraphNode is a child of a Group, how do we do that?
          2. If we use GraphNode.GetInnerNodes(), is it a better choice for this case, and if there some hidden danger for this?
                  # Find innder node
                  groupRoot.GetInnerNodes(maxon.NODE_KIND.NODE,False,innerNodes)
          Thanks for your time!
          Cheers~
          DunHou
          https://boghma.com
          https://github.com/DunHouGo
          DunhouD i_mazlovI 2 Replies Last reply Reply Quote 0
          • DunhouD Offline
            Dunhou @Dunhou
            Hi there,
            Taking inspiration from this topic, I added UniTransform to the my RenderFlow plugin and added AddUniTransform to my renderEngine library, those will be add on the next update.
            Here is a quick preview, have fun.
            Cheers~
            DunHou
            https://boghma.com
            • ? Offline
              A Former User
              I've learned a lot
              Cheers~
              君心Jay
              • i_mazlovI Offline
                i_mazlov @Dunhou
                Hi, @Dunhou ,
                Regarding your questions.
                Nodes cannot have the same ID, so you can easily distinguish them by it (GetId() function) or search for it with FindNodesById() function. The way you determine if current node is what you're looking for depends on the criteria you apply to this node. For example, you can filter nodes by their AssetId (using FindNodesByAssetId() function call as I showed above) or you can filter them by name (FindNodesByName()), or you can list nodes by some arbitrary condition (or set of conditions) using ListAllNodes().
                The GetParent() function should do this for you, for example:
                        absNode: maxon.GraphNode = graph.AddChild(maxon.Id(), maxon.Id("com.redshift3d.redshift4c4d.nodes.core.rsmathabs"))
                        groupRoot: maxon.GraphNode = graph.MoveToGroup(maxon.GraphNode(), maxon.Id("myFancyGroupId"), [absNode])
                        absNode = groupRoot.FindChild(absNode.GetId())
                        print(groupRoot.GetId())
                        print(absNode.GetParent().GetId())
                Yes, probably reducing the scope to node's children would be more efficient here. I assume in this particular case FindChild() function would have been the best choice. However, you wouldn't notice any performance difference on such a small graph.
                Ilia
                DunhouD 1 Reply Last reply Reply Quote 0
                • DunhouD Offline
                  Dunhou @i_mazlov
                  Hi @i_mazlov ,
                  Thanks for your time, sorry for my bad that I use a confusing word for "id", I should say "asset id", but as you said, I can use ID to check this, for some reason, I overlooked this for a moment.
                  And the GetParent(), I found out that the culprit is GetSelectedNodes(), I use this to get a selected node(abs bode) but the return is "group", so what ever I try the return is 'Root'.
                  Thanks for all your works!
                  Cheers~
                  DunHou
                  https://boghma.com
