    "Vector Curl" on Volume Builder?
    python2024
    3 Posts 2 Posters 922 Views 1 Watching
    • justinleducJ Offline
      justinleduc
      Hey guys,
      This is a quick one: I can't seem to be able to add a "Vector Curl" filter to my Volume Builder. No matter my settings, I always get a "Volume Filter" that is set to "Smooth".
      Here is the relevant portion of my code:
      # Create Null container
      nullContainer = c4d.BaseObject(c4d.Onull)
      nullContainer.SetName('Vectors Direction')
      doc.InsertObject(nullContainer)
      # Create volume builder object
      volumeBuilder = c4d.BaseObject(c4d.Ovolumebuilder)
      # Volume builder settings
      volumeBuilder[c4d.ID_BASELIST_NAME] = "Volume Builder 01"
      volumeBuilder[c4d.ID_VOLUMEBUILDER_VOLUMETYPE] = 2
      volumeBuilder[c4d.ID_VOLUMEBUILDER_GRID_SIZE] = 0.5
      # Volume filter
      volumeBuilderFilterCurl = c4d.BaseObject(c4d.Ovolumefilter)
      # Volume filter settings
      volumeBuilderFilterCurl[c4d.ID_VOLUMEFILTER_VECTOR_FILTER_TYPE] = 1
      volumeBuilder.InsertUnder(nullContainer)
      clonedActiveObject.InsertUnder(volumeBuilder)
      volumeBuilderFilterCurl.InsertUnder(volumeBuilder)
      Any help/insight would be greatly appreciated.
      Thank you!
      Justin
      • i_mazlovI Offline
        i_mazlov
        Hi Justin,
        Thank you for reaching out to us and providing your question with the explanatory code snippet, highly appreciated!
        Regarding your question, there are two points to mention:
        Firstly, you are using constant 1 for the c4d.ID_VOLUMEFILTER_VECTOR_FILTER_TYPE parameter, which targets "normalize" type rather than "curl" type (which corresponds to value 0). I suggest using the literal constants instead, e.g. change the line in your code from
        to
        volumeBuilderFilterCurl[c4d.ID_VOLUMEFILTER_VECTOR_FILTER_TYPE] = c4d.ID_VOLUMEFILTER_VECTOR_FILTER_TYPE_CURL
        You can find the full parameter list on the page: volumes/description/ovolumefilter.h
        Secondly, you forgot to set the volume filter type to vector. Just add the following line after initializing the filter object:
        volumeBuilderFilterCurl[c4d.ID_VOLUMEFILTER_VOLUME_TYPE] = c4d.ID_VOLUMEFILTER_VOLUME_TYPE_VECTOR
        This parameter is not referenced in python docs (sometimes it can happen), so it is worth double checking in the C++ documentation: ovolumefilter.h File Reference
        Ilia
          justinleduc
          Hey @i_mazlov, thank you so much for your incredibly helpful and thorough reply. This is exactly what I was looking for.
          Thanks again! I really appreciate it!
