    How to evenly distribute objects of different 'width'
    pythons26windows
    6 Posts 3 Posters 2.3k Views
    • H Offline
      HerrMay
      Hi guys,
      so, right now I'm at a point where think I give in. After spending hours after hours fiddeling around with matrcies, global and local positions I came to the conclusion I need someones help.
      What I'm trying to achieve.
      I'm currently prototyping a script that evenly distributes objects with potentially different widths. Quite similiar to the align tools known from Photoshop, Illustrator, etc.
      So far I have a solution that works only for objects aligned to the world frame, i.e. as soon as the objects are rotated this works no longer.
      I suspect that I somehow have to translate my computations in relation to the global transform of the objects in question. Right now I'm running out of ideas how to do so.
      I really hope someone can provide some insight here.
      I have attached the scene file as well as a screenshot illustrating the situation. Please find the code I'm using below.
      Sebastian
      distribute.c4d
      from typing import Optional
      import itertools
      doc: c4d.documents.BaseDocument  # The active document
      op: Optional[c4d.BaseObject]  # The active object, None if unselected
          objs = doc.GetActiveObjects(0)
          if not objs:
          # Store the x component of selected objs' positions
          positions = [
              obj.GetMg().off.x
              for obj in reversed(objs)
          # Store the x component of selected objs' radius
          radii = [
              obj.GetRad().x
          # Store the x component of selected objs' diameter
          diameters = [
              radius * 2
              for radius in radii
          # Compute positions so that they sit next to each other without a gap
          stacked = [
              diameter - radius
              for diameter, radius in zip(itertools.accumulate(diameters), radii)
          count = len(radii)
          width = sum(diameters)
          span = min(positions) - radii[0], max(positions) + radii[-1]
          start, end = span
          difference =  end - start - width
          spacing = difference / (count-1)
          # Compute the final position for selected objs
          positions = [
              start + position + (spacing * i)
              for i, position in enumerate(stacked)
          print("." * 79)
          print(radii)
          print(diameters)
          print(stacked)
          print(width)
          print(span)
          print(spacing)
          print(positions)
          print("." * 79)
          doc.StartUndo()
          # Set the final position computed before
          for obj, posx in zip(reversed(objs), positions):
              doc.AddUndo(c4d.UNDOTYPE_CHANGE, obj)
              mg = obj.GetMg()
              mg.off = c4d.Vector(posx, mg.off.y, mg.off.z)
              obj.SetMg(mg)
          doc.EndUndo()
      • i_mazlovI Offline
        i_mazlov
        Hi Sebastian,
        Your question lies in the algorithmic field and hence according to our guidelines is generally out of scope of our support. I would suggest you checking our Matrix Manual to get better understanding of how transforms work in Cinema4D.
        Regarding the subject, it's likely that you don't properly handle object positions. You collect only X-components of object positions, whilst your expected result (as far as I correctly understood your goal) requires addressing position projections on the line between first and last objects.
        Please find below a draft (and not optimized) code snippet that presumably does what you're trying to achieve. The main difference from your code is in new positions calculation. Namely, I'm taking the direction vector and then position objects along it while keeping correct distances (or better say projections) from the first object.
        Note, the code doesn't reflect to object size changes that come from the Transform: Scale property (as well as Freeze Transform: Scale). You will need to address them yourself. Additionally, calculation of actual objects' bounding box can sometimes be quite tricky. Please, familiarize yourself with one of related threads: How to get the bounding box for the whole scene
        Ilia
        	obj: c4d.BaseObject
        	if not objs or len(objs) < 3:
        	# Sort objects along required axis
        	objs.sort(key=lambda o: o.GetMg().off.x)
        	objMgs: list[c4d.Matrix] = [obj.GetMg() for obj in objs]
        	# .GetRad() gives you radii in local space (i.e. transform matrix invariant)
        	radii: list[float] = [o.GetRad().x for o in objs]
        	# Calculate unit direction vector for ray starting at the position of objs[0]
        	dir: c4d.Vector = (objMgs[-1].off - objMgs[0].off).GetNormalized()
        	# Project object positions onto direction vector
        	alignAxisPositions = [c4d.Vector.Dot(mg.off, dir) for mg in objMgs]
        	# Get scalar-positions of left and right points
        	left = alignAxisPositions[0] - radii[0]
        	right = alignAxisPositions[-1] + radii[-1]
        	objectsCount = len(objs)
        	objectsWidth = sum(radii) * 2
        	# Calculate spacing in between of objects
        	spacing = ((right - left) - objectsWidth) / (objectsCount - 1)
        	# Calculate new c4d.Vector positions for the objects
        	objNewPositions: list[c4d.Vector] = [objMgs[0].off]
        	for idx in range(1, objectsCount):
        		distanceFromPreviousObject: float = radii[idx - 1] + radii[idx] + spacing
        		previousPosition: c4d.Vector = objNewPositions[idx - 1]
        		objNewPositions.append(previousPosition + dir * distanceFromPreviousObject)
        	# Actually move objects
        	doc.StartUndo()
        	for obj, newPos in zip(objs, objNewPositions):
        		objMg = obj.GetMg()
        		objMg.off = newPos
        		obj.SetMg(objMg)
        	doc.EndUndo()
        • H Offline
          HerrMay
          Hi @i_mazlov,
          thank you for the explanation as well as the code sample. That really pointed me in the right direction. Especially the projection part along with the topic about bounding box calculations.
          Since GetRad() is oriented with the object I can not really use that for a "bounding box". I then thought I could use the custom class @ferdinand provided here. Well, turns out that this fails as soon as the axis of an object is no longer in the center of the points.
          So I ended up starting at @ferdinand example and building my own bounding box via iterating object points. This finally gave me a bounding box that "always" sits in the "center" of an object - no matter where the axis lives or it that object has "rotated points".
          So far so good. However, I noticed that the code you provided - though meant as a starting point and no optimized implementation - produces different results for the same objects when these objects are rearranged.
          To have a better understanding what I'm talking about, could you be so kind and have a look at the attached scene file?
          You will find that the spacing between objects is not always evenly distributed. I wonder why that is as there is e.g. no scaling involved. Just simple cubes with a different order of positions.
          Thank you for you support.
          Sebastian
          distribute.c4d
          • i_mazlovI Offline
            i_mazlov
            Hi Sebastian,
            Great that you made progress with the bounding box calculation!
            Regarding the distribution part. Yes, the inconsistency comes from taking into account only X-component of GetRad() while operating on objects in all 3 dimensions (and then checking the results again in the X-projection view).
            You need to comprehend the exact result that you'd like to have, or in other words ask yourself a question, what does it mean for the objects to be "evenly distributed"?
            1. Along which axis you'd like to distribute them?
            2. What's the metric for the "width" of the object, is it enough to grab xyz-bounding box of the object (pic 1, left) or you need to calculate bounding box that's aligned with the axis of objects distribution (pic 1, right)? As you can see on the picture the bbox size can vary drastically.
            3. What does "evenly" mean: same spacing between consequent "right" and "left" positions or same distance between object positions, or same distance between centers of object's bounding box? If first or third, check question #2.
            Picture 1. Purple - axis of distribution, Half-transparent - bounding box. Left - bounding box in world coordinates, Right - bounding box aligned with the distribution axis
            The path you would follow would stay the same as in the example:
            1. Define the axis of distribution.
            2. (Optionally) Rotate objects to be aligned with the axis of distribution
            3. Project objects onto this ray.
            4. Calculate correct spacing (refer to previous set of questions)
            5. Redistribute aligned objects with the correct spacing along the axis
            Regarding the script, you can try calculating radii based on maximum of bbox size rather than just X-component, but it would still not be an optimal solution since there're so many unknowns in the problem statement. Just change the line:
            to the following
            radiiVector: list[c4d.Vector] = [o.GetRad() for o in objs]
            radii: list[float] = [max(r.x, r.y, r.z) for r in radiiVector]
            Ilia
            • G Offline
              gsmetzer
              I was able to create the same outcome with this script in a python generator and sever cube objects as children of the generator. Everything works great and I am able to change width and offset the axis and all my child objects stack nicely side by side. This is very similar to the popular Autolayout effect in Figma.
              Unfortunately I cannot get the correct center from utils.BBox so if one of my child objects is a hierarchy I can't get the correct outcomes.
              This code might be a bit easier to read for python juniors like myself.
                  parent = op
                  child = parent.GetChildren()
                  count = len(child)             #number of assets
                  layout = c4d.Vector( 0 ,0 , 0 )
                  padding = op[c4d.ID_USERDATA,3]
                  for i in range(0,count):  #loop through all children
                      box = c4d.utils.GetBBox(child[i], child[i].GetMg())  #BBox is a tuple with (center,radius)
                      pre = c4d.utils.GetBBox(child[i-1], child[i-1].GetMg())  #BBox is a tuple with (center,radius)
                      center = child[i].GetMp()
                      preCenter = child[i-1].GetMp()
                      layout += box[1] - center + pre[1] + preCenter + padding
                      child[i][c4d.ID_BASEOBJECT_ABS_POSITION,c4d.VECTOR_X] = layout.x
                      continue
              • i_mazlovI Offline
                i_mazlov @gsmetzer
                Hi @gsmetzer,
                please have a look at the related thread (How to get the bounding box for the whole scene) where your issue was explained in details by @ferdinand
                @ferdinand said in How to get the bounding box for the whole scene:
                a BaseObject will also not include its descendants in its bounding box computation
                So, one must carry out such computations oneself
                Ilia
