    How do you manipulate the points on a spline?
    2023windowspython
    3 Posts 2 Posters 972 Views 1 Watching
    • L Offline
      ll2pakll
      Greetings. Is there any way to manage specific points on a spline? Create, move and delete them?
      I have created a spline with a certain shape, and I want it to be visible not the whole spline, but only a part of it. I want to change the end visible points over time, which will make it look like it is moving in space. I have done this with a "formula", it has parameters for the endpoints and I can change them over time. But using the formula I can't create a spline of the shape I want, and if I convert the formula to a spline and edit it, I find that I can't implement the same movement logic, because I don't understand how I can access the endpoints to create, delete and control their parameters.
      It's a basic script. The second script must be in the file located at the address specified in line 171. It contains the logic of Python tags.
      import math
      import sys
      doc: c4d.documents.BaseDocument
      def open_script_for_python_tag(file_path: str, replacement_dictionary: dict = None):
          Эта функция возвращает открытый файл в котором заменены указанные в replacement_dictionary строки.
          :param file_path: путь к файлу
          :param replacement_dictionary: передаётся словарь в котором ключ это строка которую нужно заменить, а значение это
          строка на которую нужно заменить.
          :return:
          # Открываем файл для чтения
          if replacement_dictionary:
              with open(file_path, "r", encoding="utf8") as file:
                  # Читаем все строки файла в список lines
                  lines = file.readlines()
              # Создаем пустую строку result
              result = ""
              # Проходим по каждой строке в списке lines
              for line in lines:
                  for sours, target in replacement_dictionary.items():
                      # Если строка совпадает с ключом, то она заменяется на значение ключа
                      if line == sours:
                          result += target
                      # Иначе оставляем строку без изменений
                          result += line
              # Возвращаем результат
              return result
              text = file.read()
          return text
      def get_all_objects() -> list[c4d.BaseObject]:
          # функция, которая возвращает все объекты в сцене.
          :return:
          # Создаем пустой список для хранения имен объектов
          objects = []
          # Получаем корневой объект сцены
          root = doc.GetFirstObject()
          # Если сцена не пуста
          if root:
              # Создаем стек для обхода дерева объектов
              stack = [root]
              # Пока стек не пуст
              while stack:
                  # Извлекаем верхний элемент стека
                  obj = stack.pop()
                  # Добавляем его имя в список
                  objects.append(obj)
                  # Если у объекта есть дочерние объекты
                  if obj.GetDown():
                      # Добавляем их в стек
                      stack.append(obj.GetDown())
                  # Если у объекта есть соседние объекты
                  if obj.GetNext():
                      stack.append(obj.GetNext())
          # Возвращаем список имен объектов
          return objects
      def get_all_objects_names():
          Получает имена всех объектов в сцене.
          :return:
          object_names = []
          for object_c4d in get_all_objects():
              object_names.append(object_c4d.GetName())
          return object_names
      def find_all_single_waves() -> list:
          Ищет все объекты одиночных волны в сцене.
          :return:
          # Get the first object in the scene
          obj = doc.GetFirstObject()
          waves = []
          # Loop through all objects in the scene
          while obj:
              # Get the object name
              name = obj.GetName()
              # Check if the name matches the pattern "Wave" followed by a number
              if name.startswith("Wave") and name[5:].isdigit():
                  # Print the object name and its global position
                  waves.append(obj)
              # Get the next object in the scene
              obj = obj.GetNext()
          return waves
      class WaveMove:
          def __init__(self, length: (float, int) = 304, amplitude: (float, int) = 100, velocity: (float, int) = 30,
                       phase: int = 0, name: str = None):
              self.__length = length
              self.__amplitude = amplitude
              self.__velocity = velocity
              self.__phase = phase  # в градусах от 0 до 360
              self.__start_point = 0
              self.__end_point = 10
              self._python_tag = None
              # создаём сплайн формула, который будет представлять волну
              self.wave_obj = c4d.BaseObject(c4d.Osplineformula)
              # если было передано имя волны то сразу называем её указанным именем
              if name:
                  self.wave_obj.SetName(name)
                  # если имя не было передано, то смотрим сколько волн в сцене и исходя из этого нумеруем волну.
                  count_waves_in_scene = len(find_all_single_waves())
                  self.wave_obj.SetName('Wave ' + str(count_waves_in_scene))
              # меняем плоскость расположения волны
              self.wave_obj[c4d.PRIM_PLANE] = c4d.PRIM_PLANE_ZY
              if name == 'Result wave':
                  self.wave_obj[c4d.ID_BASEOBJECT_VISIBILITY_EDITOR] = c4d.OBJECT_OFF
                  self.wave_obj[c4d.ID_BASEOBJECT_VISIBILITY_RENDER] = c4d.OBJECT_OFF
              # добавляем волну в сцену
              doc.InsertObject(self.wave_obj)
              # создаём пользовательские данные которые будут определять параметры волны
              # создаём дневник с названиями и значениями полей пользовательских данных
              self.ud_dict = {"Length wave": self.__length,
                              "Amplitude wave": self.__amplitude,
                              "Velocity wave": self.__velocity,
                              "Phase wave": self.__phase}
              for ud_name, ud_value in self.ud_dict.items():
                  self.create_user_data(ud_name, ud_value)
              # устанавливаем точки начала и конца волны
              self.set_start_point(self.__start_point)
              self.set_end_point(self.__end_point)
              # устанавливаем количество точек в сплайне
              self.wave_obj[c4d.PRIM_FORMULA_SAMPLES] = 100
              # включаем кубическую интерполяцию
              self.wave_obj[c4d.PRIM_FORMULA_CUBIC] = True
              # промежуточные точки = равномерно
              self.wave_obj[c4d.SPLINEOBJECT_INTERPOLATION] = c4d.SPLINEOBJECT_INTERPOLATION_UNIFORM
              # задаём формулу для поля X(t) которое будет определять длину волны
              self.formula_xt = f"100*t"
              self.set_Xt(self.formula_xt)
              # задаём формулу для поля Y(t) которое будет определять амплитуду волны
              self.formula_yt = f"{str(self.__amplitude)}*Sin((t+{str(math.radians(phase))})*{str(self.__length)})"
              self.set_Yt(self.formula_yt)
              # создаём словарь в котором будут содержаться строки, которые нужно заменить в скрипте тега
              self.replacement_dictionary = {
                  "    wave_obj: c4d.BaseObject =\n": f"    wave_obj: c4d.BaseObject = doc.SearchObject('{self.wave_obj.GetName()}')\n"
              self.script_for_tag_path = r'F:\Work_area\YouTube\c4d\scripts\9_script_for_teg_single_wave.py'
              self.create_tag_python()
              # self.create_volume()
          def create_user_data(self, name: str, value: int):
              Создаёт параметр в пользовательских данных
              :param value:
              :param name:
              :return:
              ud = c4d.GetCustomDataTypeDefault(c4d.DTYPE_LONG)
              ud[c4d.DESC_NAME] = name
              self.wave_obj[self.wave_obj.AddUserData(ud)] = value
          def create_tag_python(self):
              Создаёт тег Python в котором будет описываться поведение волны и надевает его на объект формула сплайн волны.
              :return:
              # создаём тег и вешаем его
              self._python_tag: c4d.BaseTag = self.wave_obj.MakeTag(c4d.Tpython)
              # помещаем скрипт в тело тега Python и передаём в него вводные данные
              self._python_tag[c4d.TPYTHON_CODE] = open_script_for_python_tag(
                  replacement_dictionary=self.replacement_dictionary,
                  file_path=self.script_for_tag_path
          def create_volume(self):
              Создаёт sweep и circle что бы появился объём.
              :return:
              sweep = c4d.BaseObject(c4d.Osweep)
              sweep.SetName(f"Sweep {self.get_name()}")
              # создаём окружность
              circle = c4d.BaseObject(c4d.Osplinecircle)
              circle[c4d.PRIM_CIRCLE_RADIUS] = 4
              circle[c4d.SPLINEOBJECT_SUB] = 2
              circle.SetName(f'Circle {self.get_name()}')
              # вставляем пружину и спираль в sweep
              self.wave_obj.InsertUnder(sweep)
              circle.InsertUnder(sweep)
              doc.InsertObject(sweep)
          def set_Xt(self, xt: str):
              устанавливаем поле Xt для формулы
              :param xt:
              :return:
              self.wave_obj[c4d.PRIM_FORMULA_X] = xt
          def set_Yt(self, yt: str):
              устанавливаем поле Yt для формулы
              :param yt:
              :return:
              self.wave_obj[c4d.PRIM_FORMULA_Y] = yt
          def set_start_point(self, value: float):
              Устанавливает точку начала волны
              :param value:
              :return:
              self.wave_obj[c4d.PRIM_FORMULA_TMIN] = value
          def set_end_point(self, value: float):
              Устанавливает точку окончания волны
              :param value:
              :return:
              self.wave_obj[c4d.PRIM_FORMULA_TMAX] = value
          def get_name(self):
              Возвращает имя объекта волны.
              :return:
              return self.wave_obj.GetName()
          def get_Yt(self):
              Возвращает формулу из поля Yt.
              :return:
              return self.wave_obj[c4d.PRIM_FORMULA_Y]
          WaveMove()
      from typing import Optional
      import math
      import sys
          doc: c4d.documents.BaseDocument = op.GetDocument()
          # рассчитываем фактор скорости
          velocity_factor = doc.GetTime().Get() * wave_obj[c4d.ID_USERDATA, 3] * 0.1
          # устанавливаем связи между пользовательскими данными и состоянием волны
          wave_obj[c4d.PRIM_FORMULA_Y] = f"{str(wave_obj[c4d.ID_USERDATA, 2])}*Sin((t+{str(math.radians(wave_obj[c4d.ID_USERDATA, 4]))})*{str(wave_obj[c4d.ID_USERDATA, 1] * 0.01)})"
          wave_obj[c4d.PRIM_FORMULA_TMIN] = velocity_factor
          wave_obj[c4d.PRIM_FORMULA_TMAX] = velocity_factor + 10
          # Update the scene
      • L Offline
        ll2pakll
        I found the answer on my own. It turned out that the methods of point management are in the parent class c4d.SplineObject - c4d.PointObject. It is also necessary to call the .Message(c4d.MSG_UPDATE) method, otherwise the spline is not updated.
        • M Offline
          m_adam
          Hi @ll2pakll,
          I am glad that you solved your issue. Message(c4d.MSG_UPDATE) is indeed required to finalize your spline editing. If you want a complete example on spline editing please take a look at geometry_splineobject.py example.
